I am on an Xavier NX with Jetpack 5.0.2.
I’m attempting to stream multiple cameras over a single video stream with nvmultistreamtiler. I intend to send the stream via udpsink and receive via udpsrc on the client. Here is my example pipe line string for how I am trying to send the video stream:
gst-launch-1.0 nvarguscamerasrc sensor-id=0 tnr-mode=2 tnr-strength=1 wbmode=0 ! 'video/x-raw(memory:NVMM),width=1920,height=1080,format=(string)NV12,framerate=(fraction)30/1' ! m.sink_0 nvarguscamerasrc sensor-id=1 tnr-mode=2 tnr-strength=1 wbmode=0 ! 'video/x-raw(memory:NVMM),width=1920,height=1080,format=(string)NV12,framerate=(fraction)30/1' ! m.sink_1 nvstreammux name=m batch-size=4 width=1920 height=1080 ! nvmultistreamtiler width=1920 height=1080 interpolation-method=2 rows=1 columns=2 ! queue ! nvv4l2h264enc iframeinterval=1 ! queue ! rtph264pay pt=96 config-interval=1 ! udpsink host=192.168.1.171 port=7331 sync=0
On the client end, here is how I’m attempting to receive and display the video stream:
gst-launch-1.0 -v udpsrc port=7331 ! application/x-rtp,media=video,encoding=H264,payload=96 ! rtph264depay ! avdec_h264 ! autovideosink sync=0
I am able to send/receive a single camera just fine via methods similar to the above. However, once I try to use multistreamtiler, the stream essentially sends a single frame and dies. Here is the output from the server:
Setting pipeline to PAUSED ...
Opening in BLOCKING MODE
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
Redistribute latency...
NvMMLiteBlockCreate : Block : BlockType = 4
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3280 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3280 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 1
Camera mode = 2
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
Camera index = 0
Camera mode = 2
seconds to Run = 0
H264: Profile = 66, Level = 0
NVMEDIA: Need to set EMC bandwidth : 846000
NVMEDIA_ENC: bBlitMode is set to TRUE
On the receive side, I see a single frame of video, along with the following text output on the command line:
reed@motherbrain:~$ gst-launch-1.0 -v udpsrc port=7331 ! application/x-rtp,media=video,encoding=H264,payload=96 ! rtph264depay ! avdec_h264 ! autovideosink sync=0
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = application/x-rtp, media=(string)video, encoding=(string)H264, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264
/GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0.GstPad:sink: caps = application/x-rtp, media=(string)video, encoding=(string)H264, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264
/GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0.GstPad:src: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)01424028ffe1000b67424028965403c0113f2a01000468ce3c80, level=(string)4, profile=(string)constrained-baseline
/GstPipeline:pipeline0/avdec_h264:avdec_h264-0.GstPad:sink: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)01424028ffe1000b67424028965403c0113f2a01000468ce3c80, level=(string)4, profile=(string)constrained-baseline
/GstPipeline:pipeline0/avdec_h264:avdec_h264-0.GstPad:src: caps = video/x-raw, format=(string)I420, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)25/1
/GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0.GstGhostPad:sink.GstProxyPad:proxypad0: caps = video/x-raw, format=(string)I420, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)25/1
/GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0/GstXvImageSink:autovideosink0-actual-sink-xvimage.GstPad:sink: caps = video/x-raw, format=(string)I420, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)25/1
/GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0.GstGhostPad:sink: caps = video/x-raw, format=(string)I420, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)25/1
I have gotten similar pipleines to work in the past on Nvidia Jetson, however that was a different version of JetPack and involved the bufapi options on nvarguscamerasrc which don’t exist in Jetpack 5.02.
Any help is appreciated, thanks in advance.
