I am trying to stream the cufft_c2c_radix2 source to create a pipeline to increase performance for a very intensive application requiring 512 point FFTs to be computed in the nanosecond scale.
For some reason streams arent working, and in fact increase computation time. Can any one help with this?
Cheers
#include <stdio.h>
#include <cutil.h>
#include <cufft_c2c_radix2.cu>
#define VALUES
#define Check( condition ) {if( (condition) != 0 ) { printf( "\n FAILURE in %s, line %d\n", __FILE__, __LINE__ );}}
__global__ void init_array(int *g_data, int *factor, int num_iterations)
int idx = blockIdx.x * blockDim.x + threadIdx.x;
for(int i=0;i<num_iterations;i++)
g_data[idx] += *factor; // non-coalesced on purpose, to burn time
int correct_data(int *a, const int n, const int c)
for(int i = 0; i < n; i++)
if(a[i] != c)
printf("%d: %d %d\n", i, a[i], c);
return 0;
return 1;
int main(int argc, char *argv[])
int cuda_device = 0;
const int nstreams =2 ; // number of streams for CUDA calls
int nreps = 10;
int Runtimes = 1;// number of times each experiment is repeated
int n = 512; // number of float2s in the data set
int batch = 32 * 1024;
dim3 threads, blocks; // kernel launch configuration
float elapsed_time, time_memcpy, time_kernel; // timing variables
int WorkingMemoryBlock = (n*batch/nstreams);
int TotalMemoryBlock = (n*batch);
int niterations; // number of iterations for the loop inside the kernel
int MemoryBlocks = 2;
if( argc > 1 )
cuda_device = atoi( argv[1] );
// check the compute capability of the device
int num_devices=0;
CUDA_SAFE_CALL( cudaGetDeviceCount(&num_devices) );
if(0==num_devices)
printf("your system does not have a CUDA capable device\n");
return 1;
// check if the command-line chosen device ID is within range, exit if not
if( cuda_device >= num_devices )
printf("choose device ID between 0 and %d\n", num_devices-1);
return 1;
cudaSetDevice( cuda_device );
cudaDeviceProp device_properties;
CUDA_SAFE_CALL( cudaGetDeviceProperties(&device_properties, cuda_device) );
if( (1 == device_properties.major) && (device_properties.minor < 1))
printf("%s does not have compute capability 1.1 or later\n\n", device_properties.name);
if(device_properties.minor > 1)
niterations = 5;
else
niterations = 1; // reduced workload for compute capability 1.0 and 1.1
printf("running on: %s\n\n", device_properties.name );
// allocate host memory (pinned is required for achieve asynchronicity)
cData *out;
CUDA_SAFE_CALL( cudaMallocHost((void**)&out, TotalMemoryBlock*sizeof(float2)) );
cData *in = 0;
CUDA_SAFE_CALL( cudaMallocHost((void**)&in, TotalMemoryBlock*sizeof(float2)) );
// allocate device memory
cData *d_in = 0; // pointers to data and init value in the device memory
CUDA_SAFE_CALL( cudaMalloc((void**)&d_in, TotalMemoryBlock*sizeof(float2)) );
//CUDA_SAFE_CALL( cudaMalloc((void**)&d_out, TotalMemoryBlock*sizeof(float2) ));
for (int i=0; i<n; i++)
in[i].x = 0;
in[i].y = 0;
out[i].x = 6;
out[i].y = 0;
in[0].x = 8;
in[513].y = 8;
// allocate and initialize an array of stream handles
cudaStream_t *streams = (cudaStream_t*) malloc(nstreams * sizeof(cudaStream_t));
for(int i = 0; i <= nstreams; i++)
CUDA_SAFE_CALL( cudaStreamCreate(&(streams[i])) );
// create CUDA event handles
cudaEvent_t start_event, stop_event;
CUDA_SAFE_CALL( cudaEventCreate(&start_event) );
CUDA_SAFE_CALL( cudaEventCreate(&stop_event) );
//Stride Information
cufftStride_st Strides;
Strides.ibStride = n;
Strides.ieStride = 1;
Strides.obStride = n;
Strides.oeStride = 1;
threads=dim3(n/2,1);
blocks=dim3((batch/nstreams),1);
// time non-streamed execution for reference
threads=dim3(n/2, 1);
blocks=dim3(batch, 1);
cudaEventRecord(start_event, 0);
for(int k = 0; k < nreps; k++)
Check(cudaMemcpy(d_in, in, TotalMemoryBlock* sizeof(float2) , cudaMemcpyHostToDevice));
cufft_c2c_radix2 <<< blocks, threads ,n*sizeof(float2)>>>(n, (float)TP/n, 9, d_in,d_in,-1,Strides);
Check(cudaMemcpy(out, d_in, TotalMemoryBlock* sizeof(float2), cudaMemcpyDeviceToHost));
// cudaStreamSynchronize(Stream[0]);
cudaEventRecord(stop_event, 0);
cudaEventSynchronize(stop_event);
CUDA_SAFE_CALL( cudaEventElapsedTime(&elapsed_time, start_event, stop_event) );
printf("Per FFT Full non-streamed:\t%.2f \n", elapsed_time / batch/ nreps *1000);
// time execution with nstreams streams
for ( int i=0; i<n; i++)
in[i].x = 0;
in[i].y = 0;
out[i].x = 6;
out[i].y = 0;
in[0].x = 8;
in[513].y = 8;
//Check(cudaMemcpy(d_out, in, WorkingMemoryBlock*nstreams* sizeof(float2) , cudaMemcpyHostToDevice));
//cudaStreamSynchronize( streams[0] );
//Check( cudaMemcpy(d_in , in , WorkingMemoryBlock*nstreams*sizeof(float2) , cudaMemcpyHostToDevice));
for(int i = 0; i < nstreams; i++)
Check( cudaMemcpyAsync(d_in +(i * WorkingMemoryBlock), in +(i * WorkingMemoryBlock), WorkingMemoryBlock*sizeof(float2) , cudaMemcpyHostToDevice,i));
//cudaStreamSynchronize( streams[i] );
cufft_c2c_radix2 <<< blocks, threads ,n*sizeof(float2),i >>>(n, TP/n, 9, d_in + (i * WorkingMemoryBlock),d_in + (i*WorkingMemoryBlock),-1,Strides);
Check( cudaMemcpyAsync( out +(i * WorkingMemoryBlock),d_in +(i * WorkingMemoryBlock), (WorkingMemoryBlock*sizeof(float2)), cudaMemcpyDeviceToHost, i) );
printf("Per FFT %d streams:\t%.2f \n", nstreams, elapsed_time / batch/nreps*1000);
// check whether the output is correct
#ifdef VALUES
printf("-------------------------------\n");
printf( "[%5.0d]: %2.1f \n",511,out[511].x);
printf( "[%5.0d]: %2.1f \n",1023,out[1023].y);
#endif
// release resources
cudaStreamDestroy(streams[i]);
cudaEventDestroy(start_event);
cudaEventDestroy(stop_event);
cudaFreeHost(out);
cudaFreeHost(in);
//cudaFree(d_out);
cudaFree(d_in);
CUT_EXIT(argc, argv);
return 0;
