Suboptimal PyTorch Performance on Jetson Orin Nano Super
Issue
According to the Jetson Orin Nano datasheet, the module delivers 17 TFLOPS FP16 performance in Super mode (MAXN_SUPER).
We benchmarked pure GEMM workloads ([8192×8192] × [8192×8192]) using PyTorch 2.7 (installed in NGC dockers) and observed significantly lower throughput than specified:
Format Achieved % of Spec vs. TensorRT*
FP16 7.9 TFLOPS 46% ~25% slower
BF16 9.1 TFLOPS 54% ~13% slower
*TensorRT achieves ~10.5 TFLOPS on identical matrix sizes (see Related Issues).
Two specific concerns:
  1. PyTorch vs. TensorRT gap: The 25-40% performance deficit compared to TensorRT suggests PyTorch’s ATen/cuDNN operators lack Jetson-specific optimizations (e.g., SM87 tuning).
  2. FP16 underperforms BF16: Counter-intuitively, FP16 (7.9 TFLOPS) trails BF16 (9.1 TFLOPS) despite Orin’s native FP16 support, indicating potential kernel selection or tensor core utilization issues.
Could you provide guidance on obtaining PyTorch builds specifically optimized for Jetson Orin (e.g., with cuDNN/cuBLAS tuning for SM87), or recommend compilation flags to approach the 17 TFLOPS specification?
Related Issues
Performance discrepancy: TensorRT achieves ~10 TFLOPS vs. 17 TFLOPS spec on Orin Nano (Super mode)
Hardware
Jetson Orin Develop Kit (Official)
Software
Jetpack:6.2 (L4T 36.4.3)
Docker Env: nvcr.io/nvidia/pytorch:25.06-py3-igpu
Pytorch(inside the docker image):2.7
CUDA(inside the docker image):12.8
Steps to Reproduce
1. Save the benchmark script bench_gemm.py
#!/usr/bin/env python3
MatMul benchmark — preallocate A,B,C and always use torch.matmul(..., out=C).
Assumes torch.matmul(..., out=...) is supported (PyTorch >= 2.6 as requested).
Usage examples:
  python matmul_prealloc_out_only.py --dtype bfloat16 --device cuda --N 8192 --repeats 1000
  python matmul_prealloc_out_only.py --dtype float16 --device cuda --N 4096 --repeats 100
Notes:
  - FLOPs counted as 2 * N**3 per matmul.
  - This script intentionally does NOT test fallback paths; it always uses out=.
import argparse
import sys
import time
import math
import gc
import torch
def bytes_per_element(dtype: torch.dtype):
    # reliable element size
    return torch.tensor([], dtype=dtype).element_size()
def humanize_bytes(n: int) -> str:
    for unit in ['B','KB','MB','GB','TB']:
        if abs(n) < 1024.0:
            return f"{n:3.2f}{unit}"
        n /= 1024.0
    return f"{n:.2f}PB"
def parse_args():
    p = argparse.ArgumentParser()
    p.add_argument("--N", type=int, default=8192, help="Matrix size (N x N)")
    p.add_argument("--repeats", type=int, default=1000, help="How many matmuls to run")
    p.add_argument("--device", choices=["cuda","cpu","auto"], default="cuda")
    p.add_argument("--dtype", choices=["float32","float16","bfloat16","float64"], default="bfloat16")
    p.add_argument("--warmups", type=int, default=10)
    p.add_argument("--no_sync_each_iter", action="store_true",
                   help="Do NOT synchronize each iteration (faster but less strict).")
    return p.parse_args()
def dtype_from_str(s: str):
    return {
        "float32": torch.float32,
        "float16": torch.float16,
        "bfloat16": torch.bfloat16,
        "float64": torch.float64
    }[s]
def main():
    args = parse_args()
    N = args.N
    repeats = args.repeats
    warmups = args.warmups
    sync_each = not args.no_sync_each_iter
    # device selection
    if args.device == "auto":
        device = "cuda" if torch.cuda.is_available() else "cpu"
    else:
        device = args.device
        if device == "cuda" and not torch.cuda.is_available():
            print("CUDA not available; falling back to CPU.", file=sys.stderr)
            device = "cpu"
    device_t = torch.device(device)
    dtype = dtype_from_str(args.dtype)
    bpe = bytes_per_element(dtype)
    mat_bytes = N * N * bpe
    total_needed = mat_bytes * 3  # A,B,C
    print(f"Benchmark settings: N={N}, repeats={repeats}, dtype={dtype}, device={device}")
    print(f"Estimated per-matrix: {humanize_bytes(mat_bytes)}; A+B+C ~= {humanize_bytes(total_needed)}")
    # If CUDA, check GPU memory to avoid OOM
    if device == "cuda":
        dev = torch.cuda.current_device()
        props = torch.cuda.get_device_properties(dev)
        total_gpu_mem = props.total_memory
        print(f"CUDA device: {torch.cuda.get_device_name(dev)}, total memory: {humanize_bytes(total_gpu_mem)}")
        if total_needed > total_gpu_mem:
            print("ERROR: Estimated required GPU memory for A,B,C exceeds total GPU memory. Aborting.", file=sys.stderr)
            print("Try smaller N or use a lower precision (e.g., float16) or use CPU.", file=sys.stderr)
            sys.exit(1)
    else:
        try:
            import psutil
            avail = psutil.virtual_memory().available
            print(f"System available memory: {humanize_bytes(avail)}")
            if total_needed > avail * 0.9:
                print("WARNING: estimated memory footprint is large relative to available system memory.", file=sys.stderr)
        except Exception:
            pass
    # Preallocate A, B, C on device
    print("Preallocating A, B, C on device...")
    A = torch.empty((N, N), dtype=dtype, device=device_t)
    B = torch.empty((N, N), dtype=dtype, device=device_t)
    C = torch.empty((N, N), dtype=dtype, device=device_t)  # output (will be used via out=)
    # Initialize A and B:
    # Some dtypes (e.g., bfloat16) may not support in-place normal_ on device reliably,
    # so create a float32 temp on device then cast/copy into A/B.
    torch.manual_seed(12345)
    temp = torch.empty((N, N), dtype=torch.float32, device=device_t)
    temp.normal_()
    if dtype == torch.float32:
        A.copy_(temp)
        B.copy_(temp)  # using same distribution; you can randomize differently if desired
    else:
        A.copy_(temp.to(dtype))
        B.copy_(temp.to(dtype))
    del temp
    # ensure allocations and initializations are finished
        torch.cuda.synchronize()
    # Warm-up iterations
    print(f"Warm-up {warmups} iterations (not counted)...")
    for i in range(warmups):
        torch.matmul(A, B, out=C)
        if sync_each and device == "cuda":
    # Timed runs using CUDA events (kernel time) or perf_counter for CPU
    flops_per = 2 * (N ** 3)
    total_flops = flops_per * repeats
    print("Starting timed runs...")
        starter = torch.cuda.Event(enable_timing=True)
        ender = torch.cuda.Event(enable_timing=True)
        starter.record()
        for i in range(repeats):
            if sync_each:
        ender.record()
        elapsed_ms = starter.elapsed_time(ender)
        total_seconds = elapsed_ms / 1000.0
    else:
        t0 = time.perf_counter()
            # attempt to keep memory steady
            gc.collect()
        total_seconds = time.perf_counter() - t0
    secs_per = total_seconds / repeats
    gflops = total_flops / total_seconds / 1e9
    print("\n=== RESULTS ===")
    print(f"Matrix size: {N} x {N}")
    print(f"Dtype: {dtype}, device: {device}")
    print(f"Repeats: {repeats}, warmups: {warmups}")
    print(f"FLOPs per matmul (2*N^3): {flops_per:,}")
    print(f"Total FLOPs: {total_flops:,}")
    print(f"Total time: {total_seconds:.6f} s")
    print(f"Time per matmul: {secs_per:.9f} s")
    print(f"Achieved: {gflops:,.3f} GFLOPS ({gflops/1000:.6f} TFLOPS)")
if __name__ == "__main__":
    main()
2. Setup docker env
the latest image that Orin + Jetpack 6.2 can run is pytorch:25.06-py3-igpu
sudo docker pull  nvcr.io/nvidia/pytorch:25.06-py3-igpu
sudo jetson_clocks
sudo docker run -it --runtime nvidia -v $PWD:$PWD -w $PWD --ipc host --net host nvcr.io/nvidia/pytorch:25.06-py3-igpu
3. Perform benchmark
python3 bench_gemm.py --dtype float16
python3 bench_gemm.py --dtype bfloat16
Additional Findings
During the aforementioned benchmarks, the VDD_IN input current hits its limit (reaches maximum draw).
However, the combined power draw of VDD_CPU_GPU_CV (11.7W) and VDD_SOC (5.8W) totals 17.5W, leaving a 6.9W discrepancy (24.4W - 17.5W) compared to the VDD_IN power.
Is this power distribution expected behavior? Could this discrepancy be related to the suboptimal performance observed?
The issue at hand involves a discrepancy in the performance of the Jetson Orin Nano module, specifically in terms of its ability to deliver the specified 17 TFLOPS FP16 performance in Super mode. The benchmarking results show that the module is only able to achieve 7.9 TFLOPS FP16 performance, which is significantly lower than the specified value.
There are two specific concerns raised in the issue:
  1. The performance deficit compared to TensorRT, which suggests that PyTorch’s ATen/CuDNN operators may lack Jetson-specific optimizations, such as SM87 tuning.
  2. The counterintuitive result that FP16 performance trails BF16 performance, despite the Orin module’s native FP16 support, indicating potential kernel selection or tensor core utilization issues.
To address these concerns, the following guidance is provided:
  1. Obtaining PyTorch builds specifically optimized for Jetson Orin:
    • It is recommended to use the latest version of PyTorch, which includes optimizations for the Jetson Orin module.
    • The user can also try building PyTorch from source, using the --cuda-arch flag to specify the SM87 architecture, which is specific to the Jetson Orin module.
    • Additionally, the user can try using the --use-cudnn flag to enable cuDNN support, which may provide better performance.
  2. Compilation flags to approach the 17 TFLOPS specification:
    • The user can try using the following compilation flags to optimize the performance of the PyTorch build:
      • -O3 to enable level 3 optimization
      • -march=sm_87 to specify the SM87 architecture
      • -mtune=sm_87 to tune the performance for the SM87 architecture
      • -fPIC to enable position-independent code generation
      • -fvisibility=hidden to reduce the visibility of symbols
  3. Power distribution discrepancy:
    • The power distribution discrepancy observed in the benchmarking results may be related to the suboptimal performance observed.
    • It is recommended to investigate the power management settings and ensure that the module is configured to operate within the specified power limits.
In comparison to TensorRT, which achieves 10.5 TFLOPS on identical matrix sizes, the PyTorch build used in the benchmarking results may lack specific optimizations for the Jetson Orin module. It is recommended to try using the latest version of PyTorch, building from source with the recommended compilation flags, and enabling cuDNN support to approach the 17 TFLOPS specification.
In terms of related issues, the performance discrepancy between TensorRT and PyTorch may be related to the lack of Jetson-specific optimizations in the PyTorch build. Additionally, the power distribution discrepancy observed in the benchmarking results may be related to the suboptimal performance observed.
To reproduce the issue, the user can follow the steps outlined in the issue, including saving the benchmark script, setting up the Docker environment, and performing the benchmark. The additional findings provided in the issue, including the input current reaching maximum draw and the combined power draw of 11.7W and 5.8W totaling 17.5W, may be related to the suboptimal performance observed.
It’s expected that TensorRT has better performance compared to PyTorch.
