Hi Jason
Thanks for your clarification/suggestion. Well i know that this is not a perfect solution but i think its the best for this moment.
Nvidia Quadro K5200 is a capable card and the specs for workstation is:
Windows 2012 with Citrix Xenapp bare metal installation
I will go with 2 x Workstation with above specs and I know that i don’t get the same scalability as i will when using virtualization but there is a problem because Hyper-v doesn’t support GPU pass-through yet and clients don’t respond well to suggestions to change hypervisor.
Just remember that every session in XenApp will require CPU resource for ctxgfx.exe to encode the stream into h264 for HDX.
Be aware that it’s likely to affect scalability expectations. Your CPU has 6 cores, so depending on the intensity of the load you could have a CPU bottleneck.
There’s a video of mine at the link below that shows the effect of running high FPS apps on the VM’s resources (youtube in this case).
