执行 sudo apt-get update 时报错
执行 sudo apt-get update 后,提示许多错误,如下图所示:
Index of /ubuntu xenial-security/main arm64 Packages
404 Not Found [IP: 91.189.91.81 80]
以及:
Can’t download http://security.ubuntu.com/ubuntu/dists/xenial-security/main/binary-arm64/Packages 404 Not Found [IP: 91.189.91.81 80]
我猜测是ubuntu arm64源受损了。
因此,我寻求一份 适用于 Jetson AGX Orin 32GB 的 ubuntu arm64源,谢谢。
Hi 1930920921,
The sources for Jetson device have been specified in /etc/apt/sources.list.d/nvidia-l4t-apt-source.list.
You can run sudo apt update to update your packages, but do not run sudo apt upgrade on Jetson device.
Xenial 是Ubuntu 16.04的代號 AGX Orin最舊也只支援20.04 你是做了什麼操作才會跑出16.04的repo?
還有請確認你是用哪一版JetPack才能知道你要用哪一包APT repo
