I have following below specs of my laptop can anyone help me to redirect which cudnn and cuda toolkit will work, I am tired of this installation, i tried with 11 and 12 version but nothing worked as gpu is still not getting detected.
I have uninstalled evrything and going for reinstallation, need guidance for that.
Laptop specs:
os: windows 11
GPU: RTX 3060 (16 GB)
Sorry for this naive question, very new to Data science.
Hi ,
We recommend you to check the supported features from the below link.
These support matrices provide a look into the supported platforms, features, and hardware capabilities of the NVIDIA TensorRT 8.6.1 APIs, parsers, and layers.
You can refer below link for all the supported operators list.
For unsupported operators, you need to create a custom plugin to support the operation
<!--- SPDX-License-Identifier: Apache-2.0 -->
# Supported ONNX Operators
TensorRT 8.6 supports operators up to Opset 17. Latest information of ONNX operators can be found [here](https://github.com/onnx/onnx/blob/master/docs/Operators.md)
TensorRT supports the following ONNX data types: DOUBLE, FLOAT32, FLOAT16, INT8, and BOOL
> Note: There is limited support for INT32, INT64, and DOUBLE types. TensorRT will attempt to cast down INT64 to INT32 and DOUBLE down to FLOAT, clamping values to `+-INT_MAX` or `+-FLT_MAX` if necessary.
See below for the support matrix of ONNX operators in ONNX-TensorRT.
## Operator Support Matrix
| Operator | Supported | Supported Types | Restrictions |
| Abs | Y | FP32, FP16, INT32 |
| Acos | Y | FP32, FP16 |
| Acosh | Y | FP32, FP16 |
| Add | Y | FP32, FP16, INT32 |
This file has been truncated. show original
