In order to adapt the LT6911UXE HDMI to MIPI chip, we made the following changes to the device tree:
tegra-capture-vi {
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
e2832_vi_in0: endpoint {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&e2832_csi_out0>;
host1x@13e00000 {
/* Delete existing VI node to avoid conflicts */
// /delete-node/ vi;
nvcsi@15a00000 {
num-channels = <1>;
#size-cells = <0>;
channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e2832_csi_in0: endpoint@0 {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&e2832_out0>;
port@1 {
reg = <1>;
e2832_csi_out0: endpoint@1 {
remote-endpoint = <&e2832_vi_in0>;
i2c@3180000 {
clock-frequency = <400000>;
status = "okay";
e2832@2b {
compatible = "uih,lt6911uxe";
reset-gpios = <&tegra_main_gpio TEGRA194_MAIN_GPIO(T, 5) GPIO_ACTIVE_LOW>;
/* I2C device address */
reg = <0x2b>;
/* V4L2 device node location */
devnode = "video0";
/* Physical dimensions of sensor */
physical_w = "3.674";
physical_h = "2.738";
sensor_model = "e2832";
mode0 { // E2832_1280x720_60Fps
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
discontinuous_clk = "yes";
dpcm_enable = "false";
cil_settletime = "0";
active_w = "1280";
active_h = "720";
mode_type = "yuv";
pixel_phase = "uyvy";
csi_pixel_bit_depth = "16";
readout_orientation = "0";
// line_length = "1650";
inherent_gain = "1";
// /*mclk_multiplier = "24";*/
pix_clk_hz = "74082000";
horz_front_porch="110";
horz_sync="40";
horz_back_porch="220";
vert_front_porch="5";
vert_sync="5";
vert_back_porch="20";
// gain_factor = "16";
// framerate_factor = "1000000";
// exposure_factor = "1000000";
// min_gain_val = "16"; /* 1.00x */
// max_gain_val = "170"; /* 10.66x */
// step_gain_val = "1";
// default_gain = "16"; /* 1.00x */
// min_hdr_ratio = "1";
// max_hdr_ratio = "1";
// min_framerate = "2000000"; /* 2.0 fps */
// max_framerate = "60000000"; /* 60.0 fps */
// step_framerate = "1";
// default_framerate = "60000000"; /* 60.0 fps */
// min_exp_time = "13"; /* us */
// max_exp_time = "683709"; /* us */
// step_exp_time = "1";
// default_exp_time = "16667"; /* us */
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e2832_out0: endpoint {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&e2832_csi_in0>;
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
num_csi_lanes = <2>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <16>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <750000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
status = "ok";
modules {
module0 {
badge = "e2832_ltx6911";
position = "bottom";
orientation = "1";
drivernode0 {
/* Declare PCL support driver (classically known as guid) */
pcl_id = "v4l2_sensor";
/* Driver v4l2 device name */
devname = "e2832 2-002b";
/* Declare the device-tree hierarchy to driver instance */
proc-device-tree = "/proc/device-tree/i2c@3180000/e2832@2b";
After loading the driver everything looks fine and you can even generate the /dev/video0 node. But when we use nvarguscamerasrc to get the data, we get the following error:
gst-launch-1.0 nvarguscamerasrc ! "video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=(fraction)60/1" ! nvvidconv ! nv3dsink sync=0 -vvv
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:751 No cameras available
/GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)60/1
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=(fraction)60/1, format=(string)RGBA
/GstPipeline:pipeline0/GstNv3dSink:nv3dsink0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=(fraction)60/1, format=(string)RGBA
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)60/1
Got EOS from element "pipeline0".
Execution ended after 0:00:00.028872832
Setting pipeline to NULL ...
Freeing pipeline ...
lt6911uxe.ko just like this:
static const struct of_device_id lt6911uxe_of_match[] = {
{ .compatible = "uih,lt6911uxe", },
MODULE_DEVICE_TABLE(of, lt6911uxe_of_match);
static const u32 ctrl_cid_list[] = {
TEGRA_CAMERA_CID_SENSOR_MODE_ID,
static const int lt6911uxe_60fps[] = {
60,
static const int lt6911uxe_30fps[] = {
30,
struct lt6911uxe {
struct i2c_client *i2c_client;
struct v4l2_subdev *sd;
u16 fine_integ_time;
u32 frame_length;
struct camera_common_data *s_data;
struct tegracam_device *tc_dev;
static const struct camera_common_frmfmt lt6911uxe_frmfmt[] = {
// {{1920, 1080}, lt6911uxe_60fps, 1, 0, 0},
// {{3840, 2160}, lt6911uxe_60fps, 1, 0, 1},
{{1280, 720}, lt6911uxe_60fps, 1, 0, 0},
static const struct regmap_config sensor_regmap_config = {
.reg_bits = 16,
.val_bits = 8,
.cache_type = REGCACHE_RBTREE,
static int lt6911uxe_open(struct v4l2_subdev *sd, struct v4l2_subdev_fh *fh)
struct i2c_client *client = v4l2_get_subdevdata(sd);
printk("%s: %d \n", __func__, __LINE__);
return 0;
static int lt6911uxe_set_group_hold(struct tegracam_device *tc_dev, bool val)
/* lt6911uxe does not support group hold */
return 0;
/* As soon as the reset pin is released, the bridge starts streaming */
static int lt6911uxe_start_streaming(struct tegracam_device *tc_dev)
struct camera_common_data *s_data = tc_dev->s_data;
struct camera_common_power_rail *pw = s_data->power;
struct lt6911uxe *priv = (struct lt6911uxe *)s_data->priv;
struct v4l2_subdev *sd = priv->sd;
if (pw->reset_gpio) {
if (gpio_cansleep(pw->reset_gpio))
gpio_set_value_cansleep(pw->reset_gpio, 1);
else
gpio_set_value(pw->reset_gpio, 1);
/* Add By Ali*/
stream_switch(sd, true); // Write register to stream on
return 0;
static int lt6911uxe_stop_streaming(struct tegracam_device *tc_dev)
gpio_set_value_cansleep(pw->reset_gpio, 0);
else
gpio_set_value(pw->reset_gpio, 0);
/* Add By Ali*/
// stream_switch(sd, false);
return 0;
static int lt6911uxe_set_mode(struct tegracam_device *tc_dev)
/* Width and Height taken care of by the firmware */
return 0;
static inline int lt6911uxe_read_reg(struct camera_common_data *s_data,
u16 addr, u8 *val)
int err = 0;
u32 reg_val = 0;
err = regmap_read(s_data->regmap, addr, ®_val);
*val = reg_val & 0xff;
return err;
static inline int lt6911uxe_write_reg(struct camera_common_data *s_data,
u16 addr, u8 val)
return 0;
static int lt6911uxe_power_get(struct tegracam_device *tc_dev)
struct device *dev = tc_dev->dev;
struct camera_common_pdata *pdata = s_data->pdata;
struct clk *parent;
int err = 0;
if (!pdata) {
dev_err(dev, "pdata missing\n");
return -EFAULT;
/* Sensor MCLK (aka. INCK) */
if (pdata->mclk_name) {
pw->mclk = devm_clk_get(dev, pdata->mclk_name);
if (IS_ERR(pw->mclk)) {
dev_err(dev, "unable to get clock %s\n",
pdata->mclk_name);
return PTR_ERR(pw->mclk);
if (pdata->parentclk_name) {
parent = devm_clk_get(dev, pdata->parentclk_name);
if (IS_ERR(parent)) {
dev_err(dev, "unable to get parent clock %s",
} else
clk_set_parent(pw->mclk, parent);
/* analog 3.3v */
if (pdata->regulators.avdd)
err |= camera_common_regulator_get(dev, &pw->avdd, pdata->regulators.avdd);
if (err) {
dev_err(dev, "%s: unable to get regulator(s)\n", __func__);
goto done;
/* dig 1.2v */
if (pdata->regulators.dvdd)
err |= camera_common_regulator_get(dev, &pw->dvdd, pdata->regulators.dvdd);
if (err) {
goto done;
/* vdd 1.8v */
if (pdata->regulators.iovdd)
err |= camera_common_regulator_get(dev, &pw->avdd, pdata->regulators.iovdd);
if (err) {
goto done;
/* Reset or ENABLE GPIO */
pw->reset_gpio = pdata->reset_gpio;
err = gpio_request(pw->reset_gpio, "cam_reset_gpio");
if (err < 0) {
dev_err(dev, "%s: unable to request reset_gpio (%d)\n", __func__, err);
goto done;
done:
pw->state = SWITCH_OFF;
return err;
static int lt6911uxe_power_put(struct tegracam_device *tc_dev)
if (unlikely(!pw))
return -EFAULT;
if (likely(pw->dvdd))
devm_regulator_put(pw->dvdd);
if (likely(pw->avdd))
devm_regulator_put(pw->avdd);
if (likely(pw->iovdd))
devm_regulator_put(pw->iovdd);
pw->dvdd = NULL;
pw->avdd = NULL;
pw->iovdd = NULL;
if (likely(pw->reset_gpio))
gpio_free(pw->reset_gpio);
return 0;
static struct camera_common_pdata *lt6911uxe_parse_dt(
struct device_node *np = dev->of_node;
struct camera_common_pdata *board_priv_pdata;
const struct of_device_id *match;
struct camera_common_pdata *ret = NULL;
int err = 0;
int gpio;
if (!np)
return NULL;
match = of_match_device(lt6911uxe_of_match, dev);
if (!match) {
dev_err(dev, "Failed to find matching dt id\n");
return NULL;
board_priv_pdata = devm_kzalloc(dev,
sizeof(*board_priv_pdata), GFP_KERNEL);
if (!board_priv_pdata)
return NULL;
gpio = of_get_named_gpio(np, "reset-gpios", 0);
if (gpio < 0) {
if (gpio == -EPROBE_DEFER)
ret = ERR_PTR(-EPROBE_DEFER);
dev_err(dev, "reset-gpios not found\n");
goto error;
board_priv_pdata->reset_gpio = (unsigned int)gpio;
err = of_property_read_string(np, "mclk", &board_priv_pdata->mclk_name);
if (err)
dev_err(dev, "mclk absent,assuming sensor driven externally\n");
err = of_property_read_string(np, "avdd-reg",
&board_priv_pdata->regulators.avdd);
err |= of_property_read_string(np, "iovdd-reg",
&board_priv_pdata->regulators.iovdd);
err |= of_property_read_string(np, "dvdd-reg",
&board_priv_pdata->regulators.dvdd);
if (err)
dev_dbg(dev, "avdd, iovdd and/or dvdd reglrs. not present, \
assume sensor powered independently\n");
board_priv_pdata->has_eeprom =
of_property_read_bool(np, "has-eeprom");
return board_priv_pdata;
error:
devm_kfree(dev, board_priv_pdata);
return ret;
static int lt6911uxe_power_on(struct camera_common_data *s_data)
int err = 0;
struct device *dev = s_data->dev;
if (pdata && pdata->power_on) {
err = pdata->power_on(pw);
if (err)
dev_err(dev, "%s failed.\n", __func__);
else
pw->state = SWITCH_ON;
return err;
else
usleep_range(10, 20);
if (pw->avdd) {
err = regulator_enable(pw->avdd);
if (err)
goto lt6911uxe_avdd_fail;
if (pw->iovdd) {
err = regulator_enable(pw->iovdd);
if (err)
goto lt6911uxe_iovdd_fail;
/* Need to wait for atleat 1 ms before turning up 1.2v */
usleep_range(1000, 1200);
if (pw->dvdd) {
err = regulator_enable(pw->dvdd);
if (err)
goto lt6911uxe_dvdd_fail;
return 0;
lt6911uxe_dvdd_fail:
regulator_disable(pw->iovdd);
lt6911uxe_iovdd_fail:
regulator_disable(pw->avdd);
lt6911uxe_avdd_fail:
return -ENODEV;
static int lt6911uxe_power_off(struct camera_common_data *s_data)
int err = 0;
if (pdata && pdata->power_off) {
err = pdata->power_off(pw);
if (err) {
return err;
} else {
else
if (pw->dvdd)
regulator_disable(pw->dvdd);
if (pw->iovdd)
if (pw->avdd)
return 0;
static int lt6911uxe_board_setup(struct lt6911uxe *priv)
struct camera_common_data *s_data = priv->s_data;
int err = 0;
err = camera_common_mclk_enable(s_data);
if (err) {
dev_err(dev, "error turning on mclk (%d)\n", err);
goto done;
err = lt6911uxe_power_on(s_data);
if (err) {
dev_err(dev, "error during power on sensor (%d)\n", err);
goto err_power_on;
err_power_on:
camera_common_mclk_disable(s_data);
done:
return err;
static struct tegracam_ctrl_ops lt6911uxe_ctrl_ops = {
.set_group_hold = lt6911uxe_set_group_hold,
static const struct v4l2_subdev_internal_ops lt6911uxe_subdev_internal_ops = {
.open = lt6911uxe_open,
static struct camera_common_sensor_ops lt6911uxe_common_ops = {
.numfrmfmts = ARRAY_SIZE(lt6911uxe_frmfmt),
.frmfmt_table = lt6911uxe_frmfmt,
.power_on = lt6911uxe_power_on,
.power_off = lt6911uxe_power_off,
.write_reg = lt6911uxe_write_reg,
.read_reg = lt6911uxe_read_reg,
.parse_dt = lt6911uxe_parse_dt,
.power_get = lt6911uxe_power_get,
.power_put = lt6911uxe_power_put,
.set_mode = lt6911uxe_set_mode,
.start_streaming = lt6911uxe_start_streaming,
.stop_streaming = lt6911uxe_stop_streaming,
static int lt6911uxe_probe(struct i2c_client *client,
const struct i2c_device_id *id)
struct device *dev = &client->dev;
struct lt6911uxe *priv;
int err;
dev_err(dev, "probing lt6911uxe v4l2 sensor at addr 0x%0x\n", client->addr);
if (!IS_ENABLED(CONFIG_OF) || !client->dev.of_node)
return -EINVAL;
priv = devm_kzalloc(dev, sizeof(struct lt6911uxe), GFP_KERNEL);
if (!priv)
return -ENOMEM;
tc_dev = devm_kzalloc(dev, sizeof(struct tegracam_device), GFP_KERNEL);
if (!tc_dev)
return -ENOMEM;
priv->i2c_client = tc_dev->client = client;
tc_dev->dev = dev;
strncpy(tc_dev->name, "lt6911uxe", sizeof(tc_dev->name));
tc_dev->dev_regmap_config = &sensor_regmap_config;
tc_dev->sensor_ops = <6911uxe_common_ops;
tc_dev->v4l2sd_internal_ops = <6911uxe_subdev_internal_ops;
tc_dev->tcctrl_ops = <6911uxe_ctrl_ops;
err = tegracam_device_register(tc_dev);
if (err) {
dev_err(dev, "tegra camera driver registration failed\n");
return err;
priv->tc_dev = tc_dev;
priv->s_data = tc_dev->s_data;
priv->sd = &tc_dev->s_data->subdev;
tegracam_set_privdata(tc_dev, (void *)priv);
err = lt6911uxe_board_setup(priv);
if (err) {
tegracam_device_unregister(tc_dev);
dev_err(dev, "board setup failed\n");
return err;
err = tegracam_v4l2subdev_register(tc_dev, true);
if (err) {
dev_err(dev, "tegra camera subdev registration failed\n");
return err;
stream_switch(priv->sd, true);
dev_err(dev, "detected lt6911uxe sensor\n");
return 0;
static int lt6911uxe_remove(struct i2c_client *client)
struct camera_common_data *s_data = to_camera_common_data(&client->dev);
tegracam_v4l2subdev_unregister(priv->tc_dev);
tegracam_device_unregister(priv->tc_dev);
return 0;
static const struct i2c_device_id lt6911uxe_id[] = {
{ "uih,lt6911uxe", 0 },
MODULE_DEVICE_TABLE(i2c, lt6911uxe_id);
static struct i2c_driver lt6911uxe_i2c_driver = {
.driver = {
.name = "uih,lt6911uxe",
.owner = THIS_MODULE,
.of_match_table = of_match_ptr(lt6911uxe_of_match),
.probe = lt6911uxe_probe,
.remove = lt6911uxe_remove,
.id_table = lt6911uxe_id,
module_i2c_driver(lt6911uxe_i2c_driver);
