From documentation, it is said, that MMAP and DMABUF are supported for encoder output plane, but when using
encoder->output_plane.setupPlane(V4L2_MEMORY_MMAP, 10, true, false)
I obtain the following error :
Error while mapping buffer at output plane
[ERROR] (NvV4l2ElementPlane.cpp:496) <my_encoder> Output Plane:Error in VIDIOC_REQBUFS at output plane: Device or resource busy
. So what is the issue ? I should only use DMABUF as memory type for output plane or I should add some things to set up output plane with MMAP type?
Regards,
