I am working on a program where during some point I need to swap 2 numbers. These 2 numbers belong to a array declared locally in the kernel, here is the declaration
__global__ void dosomework(int *p)
int store[10];
// populate store :: verified works correctly
work(store)
// access store value in CPU after copying it to p
__device__ void work(int *a)
if (a[j+1] < a[j])
swap(a[j+1],a[j]);
// copied this from the sdk
__device__ void swap(int & a, int & b)
int tmp = a;
a = b;
b = tmp;
Problem is that the swap does not work, I get wrong values if I do it. However, if I comment the call to swap, the array elements are in order (i have confirmed this)
Can anyone help me out ?
My assumptions::
int store[10] is local for each thread and so are all variables I use in the function, hence no race condition between threads
call to function() with parameter store should also not cause problems
Thanks a lot,
