Hello developers,
I’m fighting with VS 2010. I’m not able to compile my code.
I followed the “getting started guide for windows” and the only thing I changed are the the target device setting in the compiler properties to compute_30,sm_30.
Actually I have two different cu-sourcecode files in my project, one I can compile without any problems but for the other I’m getting the error message: systaxerror ‘<’. Strangely in the beginning I had the problem that ThreadIdx and BlockIdx were undefined, so I included device_launch_parameters.h.
However, I hope someone of you will give me an advice how to overcome this issue.
Here comes my code (is a demosaicing algorithm)
#include "stdafx.h" //includes cuda_runtimes.h & device_launch_parameters.h. and some otheres
/*-------RG ccd BGRA output ----------------------------*/
__global__ void bayerRG(const cv::gpu::DevMem2Db in, cv::gpu::PtrStepb out, const int ImgWidth, const int ImgHeight)
// Note called for every pair, so x/y are for start of cell so need x+1,Y+1 for right/bottom pair
// R G
// G B
// src
int x = 2 * ((blockIdx.x*blockDim.x) + threadIdx.x);
int y = 2 * ((blockIdx.y*blockDim.y) + threadIdx.y);
// could be faster if it would be copied to shared momery before
uchar r,g,b;
// 'R'
r = (in.ptr(y)[x]);
g = (in.ptr(y)[x-1]+in.ptr(y)[x+1]+(in.ptr(y-1)[x]+in.ptr(y+1)[x]))/4;
b = (in.ptr(y-1)[x-1]+in.ptr(y-1)[x+1]+(in.ptr(y+1)[x-1]+in.ptr(y+1)[x+1]))/4;
((uchar4*)out.ptr(y))[x] = make_uchar4( b,g,r,0xff);
// 'G' in R
r = (in.ptr(y)[x]+in.ptr(y)[x+2])/2;
g = (in.ptr(y)[x+1]);
b = (in.ptr(y-1)[x+1]+in.ptr(y+1)[x+1])/2;
((uchar4*)out.ptr(y))[x+1] = make_uchar4( b,g,r,0xff);
// 'G' in B
r = (in.ptr(y)[x]+in.ptr(y+2)[x])/2;
g = (in.ptr(y+1)[x]);
b = (in.ptr(y+1)[x-1]+in.ptr(y+1)[x+1])/2;
((uchar4*)out.ptr(y+1))[x] = make_uchar4( b,g,r,0xff);
// 'B'
r = (in.ptr(y)[x]+in.ptr(y)[x+2]+in.ptr(y+2)[x]+in.ptr(y+2)[x+2])/4;
g = (in.ptr(y+1)[x]+in.ptr(y+1)[x+2]+in.ptr(y)[x+1]+in.ptr(y+2)[x+1])/4;
b = (in.ptr(y+1)[x+1]);
((uchar4*)out.ptr(y+1))[x+1] = make_uchar4( b,g,r,0xff);
extern "C" bool Cuda_BayerRG2BGR(const DevMem2Db img, DevMem2Db out, int DeviceID = 0, cudaStream_t stream = NULL)
dim3 threads(16,16);
dim3 grid((img.cols/2)/(threads.x), (img.rows/2)/(threads.y));
int width = img.cols;
int height = img.rows;
if (stream == NULL)
bayerRG<<<grid,threads>>>(img, out, width, height);
else
bayerRG<<<grid, threads, DeviceID, stream>>>(img, out, width, height);
cudaThreadSynchronize();
return true;
Thank u in advance
cheers greg
