For some reason, I would like Linux to detect and use 30GB memory not 32GB.
2GB would be allocated for some other way.
Kernel command ‘mem=30gb
’ is not effective to me.
Where should I touch?
Thanks,
Thanks,
You mean primary (DRAM) or secondary(EMMC) memory?
DRAM it is!
Thanks,
you can add memory to reserved memory which linux kernel will not touch anymore
https://www.kernel.org/doc/Documentation/devicetree/bindings/reserved-memory/reserved-memory.txt
there are already reserved memory examples in dts file. you can add yours.
Thanks, @Bibek
I would try that.
