I waited for the fix overnight (thank you to the team(s) that helped resolve it) and then started the process here: System Recovery — DGX Spark User Guide
Things seemed fine until it started and now I see “Failed to mount after 10 attempts”. I’ run through the steps again, resetting to factory defaults, ensure secure boot is enabled, restoring factory keys, and then booting from the USB. No luck.
The reason I’m having to recover is that I was a victim of the “DO NOT ATTEMPT UPDATES OR SETUP” only being communicated on the forums, so of course I set mine up as soon as it came in. The issue I had when I first set it up was where boot would get stuck at “. . . autorun DONE.” I saw other posts about it also.
