Originally published at: Taking Computational Fluid Dynamics to the Next Level with the NVIDIA H200 Tensor Core GPU | NVIDIA Technical Blog
Computational fluid dynamics (CFD) is used in industry and academia to address a wide range of use cases, including external aerodynamics, internal flows, heat transfer, combustion, reacting flows, free-surface flows, multiphase flows, and aero-acoustics. CFD solvers are commonly used to simulate external aerodynamics, which helps reduce drag and improve fuel efficiency, leading to lower emissions…
