With the same setup as mentioned in the issue above I am getting this issue when running the infer command
Logs here…
tao text_classification infer -e /specs/nlp/text_classification/infer.yaml -r /results/nlp/text_classification/infer/ -m /results/nlp/text_classification/train/checkpoints/trained-model.tlt -g 1 -k $KEY
2021-09-01 09:40:27,870 [INFO] root: Registry: [‘nvcr.io’]
2021-09-01 09:40:27,971 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the “user”:“UID:GID” in the
DockerOptions portion of the “/home/ubuntu/.tao_mounts.json” file. You can obtain your
users UID and GID by using the “id -u” and “id -g” commands on the
terminal.
[NeMo W 2021-09-01 09:40:31 experimental:27] Module <class ‘nemo.collections.nlp.modules.common.megatron.megatron_bert.MegatronBertEncoder’> is experimental, not ready for production and is not fully supported. Use at your own risk.
[NeMo W 2021-09-01 09:40:34 experimental:27] Module <class ‘nemo.collections.nlp.modules.common.megatron.megatron_bert.MegatronBertEncoder’> is experimental, not ready for production and is not fully supported. Use at your own risk.
[NeMo I 2021-09-01 09:40:35 tlt_logging:20] Experiment configuration:
restore_from: /results/nlp/text_classification/train/checkpoints/trained-model.tlt
exp_manager:
task_name: infer
explicit_log_dir: /results/nlp/text_classification/infer/
input_batch:
- by the end of no such thing the audience , like beatrice , has a watchful affection
for the monster .
- director rob marshall went out gunning to make a great one .
- uneasy mishmash of styles and genres .
- I love exotic science fiction / fantasy movies but this one was very unpleasant
to watch . Suggestions and images of child abuse , mutilated bodies (live or dead)
, other gruesome scenes , plot holes , boring acting made this a regretable experience
, The basic idea of entering another person’s mind is not even new to the movies
or TV (An Outer Limits episode was better at exploring this idea) . i gave it 4
/ 10 since some special effects were nice .
encryption_key: ‘*********’
[NeMo W 2021-09-01 09:40:35 exp_manager:26] Exp_manager is logging to `/results/nlp/text_classification/infer/``, but it already exists.
[NeMo W 2021-09-01 09:40:37 modelPT:193] Using /tmp/tmpr24pl3kf/tokenizer.vocab_file instead of tokenizer.vocab_file.
Using bos_token, but it is not set yet.
Using eos_token, but it is not set yet.
[NeMo W 2021-09-01 09:40:37 modelPT:1202] World size can only be set by PyTorch Lightning Trainer.
File “/opt/conda/lib/python3.8/site-packages/hydra/_internal/utils.py”, line 198, in run_and_report
return func()
File “/opt/conda/lib/python3.8/site-packages/hydra/_internal/utils.py”, line 347, in
lambda: hydra.run(
File “/opt/conda/lib/python3.8/site-packages/hydra/_internal/hydra.py”, line 107, in run
return run_job(
File “/opt/conda/lib/python3.8/site-packages/hydra/core/utils.py”, line 127, in run_job
ret.return_value = task_function(task_cfg)
File “/tlt-nemo/nlp/text_classification/scripts/infer.py”, line 83, in main
File “/opt/conda/lib/python3.8/posixpath.py”, line 142, in basename
p = os.fspath(p)
TypeError: expected str, bytes or os.PathLike object, not NoneType
During handling of the above exception, another exception occurred:
File “/tlt-nemo/nlp/text_classification/scripts/infer.py”, line 113, in
File “/opt/conda/lib/python3.8/site-packages/nemo/core/config/hydra_runner.py”, line 98, in wrapper
_run_hydra(
File “/opt/conda/lib/python3.8/site-packages/hydra/_internal/utils.py”, line 346, in _run_hydra
run_and_report(
File “/opt/conda/lib/python3.8/site-packages/hydra/_internal/utils.py”, line 237, in run_and_report
assert mdl is not None
AssertionError
2021-09-01 09:40:47,348 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
(taoenv) ubuntu@ip-172-31-14-240:~/jarvis_quickstart_v1.0.0-b.1$ cd ~/tao
(taoenv) ubuntu@ip-172-31-14-240:~/tao$ ls
data results specs
(taoenv) ubuntu@ip-172-31-14-240:~/tao$ cd data
(taoenv) ubuntu@ip-172-31-14-240:~/tao/data$ ls
NLU-Evaluation-Data-master NLU-Evaluation-Data-processed SST-2 my_domain_classification sst2
(taoenv) ubuntu@ip-172-31-14-240:~/tao/data$ cd NLU-Evaluation-Data-processed/
(taoenv) ubuntu@ip-172-31-14-240:~/tao/data/NLU-Evaluation-Data-processed$ ls
dict.intents.csv dict.slots.csv intent_labels.csv slot_labels.csv test.tsv test_intent_stats.tsv test_slot_stats.tsv test_slots.tsv train.tsv train_intent_stats.tsv train_slot_stats.tsv train_slots.tsv
(taoenv) ubuntu@ip-172-31-14-240:~/tao/data/NLU-Evaluation-Data-processed$ cd …/…/…/
(taoenv) ubuntu@ip-172-31-14-240:~$ cd jarvis_quickstart_v1.0.0-b.1/
(taoenv) ubuntu@ip-172-31-14-240:~/jarvis_quickstart_v1.0.0-b.1$ tao text_classification infer -e /specs/nlp/text_classification/infer.yaml -r /results/nlp/text_classification/infer/ -m /results/nlp/text_classification/finetune/checkpoints/finetuned-model.tlt -g 1 -k $KEY
2021-09-01 09:57:17,349 [INFO] root: Registry: [‘nvcr.io’]
2021-09-01 09:57:17,448 [WARNING] tlt.components.docker_handler.docker_handler:
terminal.
[NeMo W 2021-09-01 09:57:20 experimental:27] Module <class ‘nemo.collections.nlp.modules.common.megatron.megatron_bert.MegatronBertEncoder’> is experimental, not ready for production and is not fully supported. Use at your own risk.
[NeMo W 2021-09-01 09:57:24 experimental:27] Module <class ‘nemo.collections.nlp.modules.common.megatron.megatron_bert.MegatronBertEncoder’> is experimental, not ready for production and is not fully supported. Use at your own risk.
[NeMo I 2021-09-01 09:57:24 tlt_logging:20] Experiment configuration:
restore_from: /results/nlp/text_classification/finetune/checkpoints/finetuned-model.tlt
exp_manager:
task_name: infer
input_batch:
for the monster .
encryption_key: ‘********’
[NeMo W 2021-09-01 09:57:24 exp_manager:26] Exp_manager is logging to `/results/nlp/text_classification/infer/``, but it already exists.
[NeMo W 2021-09-01 09:57:27 modelPT:193] Using /tmp/tmpdzz4go9b/tokenizer.vocab_file instead of tokenizer.vocab_file.
[NeMo W 2021-09-01 09:57:28 modelPT:1202] World size can only be set by PyTorch Lightning Trainer.
return func()
lambda: hydra.run(
return run_job(
File “/opt/conda/lib/python3.8/site-packages/omegaconf/dictconfig.py”, line 317, in getitem
self._format_and_raise(
File “/opt/conda/lib/python3.8/site-packages/omegaconf/base.py”, line 95, in _format_and_raise
format_and_raise(
File “/opt/conda/lib/python3.8/site-packages/omegaconf/_utils.py”, line 629, in format_and_raise
_raise(ex, cause)
File “/opt/conda/lib/python3.8/site-packages/omegaconf/_utils.py”, line 610, in _raise
raise ex # set end OC_CAUSE=1 for full backtrace
omegaconf.errors.ConfigKeyError: Key ‘class_labels’ is not in struct
full_key: class_labels
reference_type=Optional[Dict[Union[str, Enum], Any]]
object_type=dict
_run_hydra(
run_and_report(
AssertionError
2021-09-01 09:57:38,209 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
(taoenv) ubuntu@ip-172-31-14-240:~/jarvis_quickstart_v1.0.0-b.1$ tao text_classification infer -e /specs/nlp/text_classification/infer.yaml -r /results/nlp/text_classification/infer/ -m /results/nlp/text_classification/train/checkpoints/trained-model.tlt -g 1 -k $KEY
2021-09-01 10:00:41,887 [INFO] root: Registry: [‘nvcr.io’]
2021-09-01 10:00:41,988 [WARNING] tlt.components.docker_handler.docker_handler:
terminal.
[NeMo W 2021-09-01 10:00:45 experimental:27] Module <class ‘nemo.collections.nlp.modules.common.megatron.megatron_bert.MegatronBertEncoder’> is experimental, not ready for production and is not fully supported. Use at your own risk.
[NeMo W 2021-09-01 10:00:48 experimental:27] Module <class ‘nemo.collections.nlp.modules.common.megatron.megatron_bert.MegatronBertEncoder’> is experimental, not ready for production and is not fully supported. Use at your own risk.
[NeMo I 2021-09-01 10:00:49 tlt_logging:20] Experiment configuration:
exp_manager:
task_name: infer
input_batch:
for the monster .
encryption_key: ‘****’
[NeMo W 2021-09-01 10:00:49 exp_manager:26] Exp_manager is logging to `/results/nlp/text_classification/infer/``, but it already exists.
[NeMo W 2021-09-01 10:00:51 modelPT:193] Using /tmp/tmppcfdktmo/tokenizer.vocab_file instead of tokenizer.vocab_file.
[NeMo W 2021-09-01 10:00:51 modelPT:1202] World size can only be set by PyTorch Lightning Trainer.
return func()
lambda: hydra.run(
return run_job(
p = os.fspath(p)
_run_hydra(
run_and_report(
AssertionError
2021-09-01 10:01:01,216 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
(taoenv) ubuntu@ip-172-31-14-240:~/jarvis_quickstart_v1.0.0-b.1$ echo $HOME
/home/ubuntu
(taoenv) ubuntu@ip-172-31-14-240:~/jarvis_quickstart_v1.0.0-b.1$ cd …/
(taoenv) ubuntu@ip-172-31-14-240:~$ tao text_classification infer -e /specs/nlp/text_classification/infer.yaml -r /results/nlp/text_classification/infer/ -m /results/nlp/text_classification/train/checkpoints/trained-model.tlt -g 1 -k $KEY2021-09-01 10:04:48,173 [INFO] root: Registry: [‘nvcr.io’]
2021-09-01 10:04:48,282 [WARNING] tlt.components.docker_handler.docker_handler:
terminal.
[NeMo W 2021-09-01 10:04:51 experimental:27] Module <class ‘nemo.collections.nlp.modules.common.megatron.megatron_bert.MegatronBertEncoder’> is experimental, not ready for production and is not fully supported. Use at your own risk.
[NeMo W 2021-09-01 10:04:54 experimental:27] Module <class ‘nemo.collections.nlp.modules.common.megatron.megatron_bert.MegatronBertEncoder’> is experimental, not ready for production and is not fully supported. Use at your own risk.
[NeMo I 2021-09-01 10:04:55 tlt_logging:20] Experiment configuration:
exp_manager:
task_name: infer
input_batch:
for the monster .
encryption_key: ‘***’
[NeMo W 2021-09-01 10:04:55 exp_manager:26] Exp_manager is logging to `/results/nlp/text_classification/infer/``, but it already exists.
[NeMo W 2021-09-01 10:04:57 modelPT:193] Using /tmp/tmp8yjsgse_/tokenizer.vocab_file instead of tokenizer.vocab_file.
[NeMo W 2021-09-01 10:04:57 modelPT:1202] World size can only be set by PyTorch Lightning Trainer.
return func()
lambda: hydra.run(
return run_job(
p = os.fspath(p)
_run_hydra(
run_and_report(
AssertionError
2021-09-01 10:05:07,560 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
(taoenv) ubuntu@ip-172-31-14-240:~$ cd tao/
(taoenv) ubuntu@ip-172-31-14-240:~/tao$ tao text_classification infer -e /specs/nlp/text_classification/infer.yaml -r /results/nlp/text_classification/infer/ -m /results/nlp/text_classification/train/checkpoints/trained-model.tlt -g 1 -k $KEY
2021-09-01 10:10:21,368 [INFO] root: Registry: [‘nvcr.io’]
2021-09-01 10:10:21,470 [WARNING] tlt.components.docker_handler.docker_handler:
terminal.
[NeMo W 2021-09-01 10:10:24 experimental:27] Module <class ‘nemo.collections.nlp.modules.common.megatron.megatron_bert.MegatronBertEncoder’> is experimental, not ready for production and is not fully supported. Use at your own risk.
[NeMo W 2021-09-01 10:10:28 experimental:27] Module <class ‘nemo.collections.nlp.modules.common.megatron.megatron_bert.MegatronBertEncoder’> is experimental, not ready for production and is not fully supported. Use at your own risk.
[NeMo I 2021-09-01 10:10:28 tlt_logging:20] Experiment configuration:
exp_manager:
task_name: infer
input_batch:
for the monster .
encryption_key: ‘*****’
[NeMo W 2021-09-01 10:10:28 exp_manager:26] Exp_manager is logging to `/results/nlp/text_classification/infer/``, but it already exists.
[NeMo W 2021-09-01 10:10:30 modelPT:193] Using /tmp/tmpal82qy6u/tokenizer.vocab_file instead of tokenizer.vocab_file.
[NeMo W 2021-09-01 10:10:30 modelPT:1202] World size can only be set by PyTorch Lightning Trainer.
return func()
lambda: hydra.run(
return run_job(
p = os.fspath(p)
_run_hydra(
run_and_report(
AssertionError
2021-09-01 10:10:40,688 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
(taoenv) ubuntu@ip-172-31-14-240:~/tao$ tao text_classification infer -e /specs/nlp/text_classification/infer.yaml -r /results/nlp/text_classification/infer/ -m /results/nlp/text_classification/train/checkpoints/trained-model.tlt -g 1 -k $KEY^C
(taoenv) ubuntu@ip-172-31-14-240:~/tao$ tao text_classification infer -e /specs/nlp/text_classification/infer.yaml -m /results/nlp/text_classification/train/checkpoints/trained-model.tlt -k $KEY
2021-09-01 10:25:38,664 [INFO] root: Registry: [‘nvcr.io’]
2021-09-01 10:25:38,765 [WARNING] tlt.components.docker_handler.docker_handler:
terminal.
[NeMo W 2021-09-01 10:25:42 experimental:27] Module <class ‘nemo.collections.nlp.modules.common.megatron.megatron_bert.MegatronBertEncoder’> is experimental, not ready for production and is not fully supported. Use at your own risk.
usage: text_classification [-h] -r RESULTS_DIR [-k KEY] [-e EXPERIMENT_SPEC_FILE] [-g GPUS] [-m RESUME_MODEL_WEIGHTS] [-o OUTPUT_SPECS_DIR] {dataset_convert,evaluate,export,finetune,infer,infer_onnx,train,download_specs}
text_classification: error: the following arguments are required: -r/–results_dir
2021-09-01 10:25:43,076 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
(taoenv) ubuntu@ip-172-31-14-240:~/tao$ tao text_classification infer -e /specs/nlp/text_classification/infer.yaml -r /results/nlp/text_classification/infer -m /results/nlp/text_classification/train/checkpoints/trained-model.tlt -g 1 -k $KEY
2021-09-01 10:27:38,950 [INFO] root: Registry: [‘nvcr.io’]
2021-09-01 10:27:39,055 [WARNING] tlt.components.docker_handler.docker_handler:
terminal.
[NeMo W 2021-09-01 10:27:42 experimental:27] Module <class ‘nemo.collections.nlp.modules.common.megatron.megatron_bert.MegatronBertEncoder’> is experimental, not ready for production and is not fully supported. Use at your own risk.
[NeMo W 2021-09-01 10:27:45 experimental:27] Module <class ‘nemo.collections.nlp.modules.common.megatron.megatron_bert.MegatronBertEncoder’> is experimental, not ready for production and is not fully supported. Use at your own risk.
[NeMo I 2021-09-01 10:27:46 tlt_logging:20] Experiment configuration:
exp_manager:
task_name: infer
input_batch:
for the monster .
[NeMo W 2021-09-01 10:27:46 exp_manager:26] Exp_manager is logging to `/results/nlp/text_classification/infer``, but it already exists.
[NeMo W 2021-09-01 10:27:48 modelPT:193] Using /tmp/tmptv7d8fn6/tokenizer.vocab_file instead of tokenizer.vocab_file.
[NeMo W 2021-09-01 10:27:48 modelPT:1202] World size can only be set by PyTorch Lightning Trainer.
return func()
lambda: hydra.run(
return run_job(
p = os.fspath(p)
_run_hydra(
run_and_report(
AssertionError
2021-09-01 10:27:58,400 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
infer.yaml
Copyright (c) 2020, NVIDIA CORPORATION. All rights reserved.
TLT Spec file for inference using a previously pretrained BERT model for a text classification task.
“Simulate” user input: batch with four samples.
input_batch:
- “by the end of no such thing the audience , like beatrice , has a watchful affection for the monster .”
- “director rob marshall went out gunning to make a great one .”
- “uneasy mishmash of styles and genres .”
- “I love exotic science fiction / fantasy movies but this one was very unpleasant to watch . Suggestions and images of child abuse , mutilated bodies (live or dead) , other gruesome scenes , plot holes , boring acting made this a regretable experience , The basic idea of entering another person’s mind is not even new to the movies or TV (An Outer Limits episode was better at exploring this idea) . i gave it 4 / 10 since some special effects were nice .”
