Tao TF1 classification export issue
• Hardware Xavier
• Network Type Classification
• TLT Version 5.0.0
• Training spec file: model_config {
#Model Architecture can be chosen from:
#[‘resnet’, ‘vgg’, ‘googlenet’, ‘alexnet’]
arch: “resnet”
#for resnet → n_layers can be [10, 18, 50]
#for vgg → n_layers can be [16, 19]
n_layers: 18
use_batch_norm: True
use_bias: False
all_projections: False
use_pooling: True
retain_head: True
resize_interpolation_method: BICUBIC
#if you want to use the pretrained model,
#image size should be “3,224,224”
#otherwise, it can be “3, X, Y”, where X,Y >= 16
input_image_size: “3,224,224”
train_config {
train_dataset_path: “/workspace/tao_classification/example_dataset/train”
val_dataset_path: “/workspace/tao_classification/example_dataset/val”
pretrained_model_path: “/workspace/tao_classification/resnet_18.hdf5”
#Only [‘sgd’, ‘adam’] are supported for optimizer
optimizer {
sgd {
lr: 0.01
decay: 0.0
momentum: 0.9
nesterov: False
batch_size_per_gpu: 50
n_epochs: 150
#Number of CPU cores for loading data
n_workers: 16
#regularizer
reg_config {
#regularizer type can be “L1”, “L2” or “None”.
type: “L2”
#if the type is not “None”,
#scope can be either “Conv2D” or “Dense” or both.
scope: “Conv2D,Dense”
#0 < weight decay < 1
weight_decay: 0.000015
#Learning_rate
lr_config {
cosine {
learning_rate: 0.04
soft_start: 0.0
enable_random_crop: True
enable_center_crop: True
enable_color_augmentation: True
mixup_alpha: 0.2
label_smoothing: 0.1
preprocess_mode: “caffe”
image_mean {
key: ‘b’
value: 103.9
image_mean {
key: ‘g’
value: 116.8
image_mean {
key: ‘r’
value: 123.7
eval_config {
eval_dataset_path: “/workspace/tao_classification/example_dataset/test”
model_path: “/workspace/tao_classification/results/resnet_18.tlt”
top_k: 3
batch_size: 256
n_workers: 8
• How to reproduce the issue: tao model classification_tf1 export -m /workspace/tao_classification/results/weights/resnet_150.hdf5 -o ‘/workspace/tao_classification/export/final_model’ -k TLT --classmap_json /workspace/tao_classification/results/weights/classmap.json
Everytime I run the above command I get this error:
File “/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/scripts/export.py”, line 70, in
main()
File “/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/scripts/export.py”, line 66, in main
raise e
File “/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/scripts/export.py”, line 50, in main
run_export(Exporter, args=args, backend=backend)
File “/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/common/export/app.py”, line 277, in run_export
exporter = Exporter(model_path, key,
File “/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/makenet/export/classification_exporter.py”, line 95, in init
if os.path.exists(experiment_spec_path):
File “/usr/lib/python3.8/genericpath.py”, line 19, in exists
os.stat(path)
TypeError: stat: path should be string, bytes, os.PathLike or integer, not NoneType
Execution status: FAIL
2023-08-17 11:48:46,735 [TAO Toolkit] [INFO] nvidia_tao_cli.components.docker_handler.docker_handler 337: Stopping container.
This was on a different post earlier as well but adding --classmap_json did not fix the issue for me. Please help
Please add “-e your_spec_file” in the command line.
Refer to https://github.com/NVIDIA/tao_tutorials/blob/cdbafd28fec9da67fbfc4db9288ec0805076ce29/notebooks/tao_launcher_starter_kit/classification_tf1/tao_voc/classification.ipynb
Thank you that worked.
The documentation Image Classification (TF1) - NVIDIA Docs
marks -e as an optional argument. Maybe update the documentation accordingly.
Thanks again.
Yes, we will improve the document. Thanks for the finding.
