riyang1
December 1, 2023, 11:13am
1
• Hardware (T4/V100/Xavier/Nano/etc): T4 AWS SageMaker Studio
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc): TrafficCamNet, LPD, LPR, VehicleMake, VehicleType
Hi NV team,
Following in from the successful implementation of TAO Toolkit in SageMaker Studio, helped by @Morganh here - NVIDIA-TAO-Deploy -pycocotools-fix issue - Python Wheels TAO implementation porting from Collab to AWS SageMaker Studio - #10 by riyang1
I aim to deploy the model to AWS SageMaker and seek support in developing a REST API endpoint for operational use. Is there any guidance/examples to help with this?
For AWS EKS, please refer to AWS EKS setup. Setup - NVIDIA Docs
For AWS SageMaker, please check if above guide works. Also, you can try to use bare-metal-setup Setup - NVIDIA Docs . The steps are as below.
Steps:
local-morganh@ipp1-1080:~/getting_started_v5.0.0/setup/quickstart_api_bare_metal$ history
1 . .bashrc
2 nvidia-smi
3 cat /etc/lsb-release
4 nvidia-smi
5 sudo apt install nvidia-driver-535
6 nvidia-smi
7 sudo reboot
8 . .bashrc
9 nvidia-smi
10 nvidia-smi -L
11 wget --content-disposition https://ngc.nvidia.com/downloads/ngccli_linux.zip && unzip ngccli_linux.zip && chmod u+x ngc-cli/ngc
12 ls
13 find ngc-cli/ -type f -exec md5sum {} + | LC_ALL=C sort | md5sum -c ngc-cli.md5
14 echo "export PATH=\"\$PATH:$(pwd)/ngc-cli\"" >> ~/.bash_profile && source ~/.bash_profile
15 ln -s $(pwd)/ngc-cli/ngc ./ngc
16 ngc config set
17 wget --content-disposition https://api.ngc.nvidia.com/v2/resources/nvidia/tao/tao-getting-started/versions/5.0.0/zip -O getting_started_v5.0.0.zip
18 unzip -u getting_started_v5.0.0.zip -d ./getting_started_v5.0.0 && rm -rf getting_started_v5.0.0.zip && cd ./getting_started_v5.0.0
19 cd setup/quickstart_api_bare_metal/
20 vim gpu-operator-values.yml
21 cat gpu-operator-values.yml
22 vim hosts
23 sudo nano /etc/sudoers
24 vim tao-toolkit-api-ansible-values.yml
25 cat gpu-operator-values.yml
$ cat gpu-operator-values.yml
enable_mig: no
mig_profile: all-disabled
mig_strategy: single
nvidia_driver_version: "525.85.12"
install_driver: false #true
26 bash setup.sh check-inventory
27 bash setup.sh install
28 kubectl get pods
29 history
After installation,
local-morganh@ipp1-1080:~/getting_started_v5.0.0/setup/quickstart_api_bare_metal$ kubectl get pods
NAME READY STATUS RESTARTS AGE
ingress-nginx-controller-55794ccb68-sldjn 1/1 Running 0 2m48s
nfs-subdir-external-provisioner-cb9798d4-tp5hx 1/1 Running 0 2m38s
nvidia-smi-ipp1-1080 1/1 Running 0 2m32s
tao-toolkit-api-app-pod-55c5d88d86-79vpj 1/1 Running 0 2m29s
tao-toolkit-api-jupyterlab-pod-5db94dd6cc-7w4lg 1/1 Running 0 2m29s
tao-toolkit-api-workflow-pod-55db5b9bf9-747jf 1/1 Running 0 2m29s
