TAO Toolkit Google Colab YOLO4 Training file not found
I am getting a error when I run Google colab training script for YOLO 4
I noticed that the file paths in the spec file have some extra slashes.
example: tfrecords_path: “/content/drive/MyDrive/kitti_data///training/tfrecords/train*”
Here is script:
!tao yolo_v4 train -e $SPECS_DIR/yolo_v4_train_resnet18_kitti.txt
-r $EXPERIMENT_DIR/experiment_dir_unpruned
-k $KEY
–gpus 1
Here is result with error:
INFO: No files match pattern /content/drive/MyDrive/kitti_data///training/tfrecords/train*.
File “</usr/local/lib/python3.6/dist-packages/iva/yolo_v4/scripts/train.py>”, line 3, in
File “”, line 152, in
File “”, line 707, in return_func
File “”, line 695, in return_func
File “”, line 148, in main
File “”, line 133, in main
File “”, line 78, in run_experiment
File “”, line 67, in build_training_pipeline
File “”, line 299, in init
File “”, line 806, in build_dataloader
File “”, line 719, in build_data_source_lists
File “”, line 65, in _pattern_to_files
AssertionError: No files match pattern /content/drive/MyDrive/kitti_data///training/tfrecords/train*.
Telemetry data couldn’t be sent, but the command ran successfully.
[WARNING]: <urlopen error [Errno -2] Name or service not known>
Execution status: FAIL
Here is SPEC file:
random_seed: 42
yolov4_config {
big_anchor_shape: “[(114.94, 60.67), (159.06, 114.59), (297.59, 176.38)]”
mid_anchor_shape: “[(42.99, 31.91), (79.57, 31.75), (56.80, 56.93)]”
small_anchor_shape: “[(15.60, 13.88), (30.25, 20.25), (20.67, 49.63)]”
box_matching_iou: 0.25
matching_neutral_box_iou: 0.5
arch: “resnet”
nlayers: 18
arch_conv_blocks: 2
loss_loc_weight: 1.0
loss_neg_obj_weights: 1.0
loss_class_weights: 1.0
label_smoothing: 0.0
big_grid_xy_extend: 0.05
mid_grid_xy_extend: 0.1
small_grid_xy_extend: 0.2
freeze_bn: false
#freeze_blocks: 0
force_relu: false
training_config {
batch_size_per_gpu: 8
num_epochs: 80
enable_qat: false
checkpoint_interval: 10
learning_rate {
soft_start_cosine_annealing_schedule {
min_learning_rate: 1e-7
max_learning_rate: 1e-4
soft_start: 0.3
regularizer {
type: L1
weight: 3e-5
optimizer {
adam {
epsilon: 1e-7
beta1: 0.9
beta2: 0.999
amsgrad: false
pretrain_model_path: “/content/drive/MyDrive/results/yolo_v4//pretrained_resnet18/pretrained_object_detection_vresnet18/resnet_18.hdf5”
eval_config {
average_precision_mode: SAMPLE
batch_size: 8
matching_iou_threshold: 0.5
nms_config {
confidence_threshold: 0.001
clustering_iou_threshold: 0.5
force_on_cpu: true
top_k: 200
augmentation_config {
hue: 0.1
saturation: 1.5
exposure:1.5
vertical_flip:0
horizontal_flip: 0.5
jitter: 0.3
output_width: 1248
output_height: 384
output_channel: 3
randomize_input_shape_period: 0
mosaic_prob: 0.5
mosaic_min_ratio:0.2
dataset_config {
data_sources: {
image_directory_path: “/content/drive/MyDrive/kitti_data///training”
include_difficult_in_training: true
image_extension: “png”
target_class_mapping {
key: “car”
value: “car”
key: “pedestrian”
value: “pedestrian”
key: “cyclist”
value: “cyclist”
key: “van”
value: “car”
key: “person_sitting”
value: “pedestrian”
validation_fold: 0
Could you help check if what is inside the tfrecords folder?
!tao yolo_v4 run ls /content/drive/MyDrive/kitti_data/training/tfrecords/
The issue seems to be google drive. It is very slow to transfer any type of file.
I guess patience is the key when running from google colab
