[ 11.771315] tc358743 9-000f: failed to get refclk: -2
[ 11.771321] tc358743: probe of 9-000f failed with error -2
[ 11.771356] tc358743 10-000f: failed to get refclk: -2
[ 11.771359] tc358743: probe of 10-000f failed with error -2
Im trying to port tc358743 camera drive on r36.4.
When I boot up the probe fails in my probe_of function with the error “failed to get refclk: -2”.
The code below fails.
tc358743.c
refclk = devm_clk_get(dev, "refclk");
if (IS_ERR(refclk)) {
if (PTR_ERR(refclk) != -EPROBE_DEFER)
dev_err(dev, "failed to get refclk: %ld\n",
PTR_ERR(refclk));
return PTR_ERR(refclk);
I gave refclk in device tree related code but still got error.
// SPDX-License-Identifier: GPL-2.0-only
// SPDX-FileCopyrightText: Copyright (c) 2023-2024, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
include <dt-bindings/clock/tegra234-clock.h> include <dt-bindings/gpio/tegra234-gpio.h>
What does ‘Confirm the refclk by checking /proc/device-tree/’ mean?
I did check the path.
test@test-desktop:/proc/device-tree$ grep -r refclk
grep: bus@0/cam_i2cmux/i2c@0/toshiba_tc358743_a@0f/clock-names: binary file matches
grep: bus@0/cam_i2cmux/i2c@1/toshiba_tc358743_c@0f/clock-names: binary file matches
test@test-desktop:/proc/device-tree$ cat bus@0/cam_i2cmux/i2c@0/toshiba_tc358743_a@0f/clock-names
refclk
Add the Config below in the file location ‘arch/amr64/configs/defconfig’
CONFIG_EMBEDDED=y
make ARCH=arm64 menuconfig
D Device Drivers
=> u Multimedia support
=> eeee Media ancillary drivers
==> v Video decoders
=> t TC358743 : set to ‘M’
make ARCH=arm64 savedefconfig
19. export CROSS_COMPILE=$HOME/l4t-gcc/aarch64–glibc–stable-2022.08-1/bin/aarch64-buildroot-linux-gnu-
20. make ARCH=arm64 -C kernel
21. export INSTALL_MOD_PATH=$PWD/rootfs/
22. sudo -E make ARCH=arm64 install -C kernel
23. cp kernel/kernel-jammy-src/arch/arm64/boot/Image …/kernel/Image
24. build modules of nvidia out-of-tree
export KERNEL_HEADERS=$PWD/kernel/kernel-jammy-src
make ARCH=arm64 modules
25. sudo -E make ARCH=arm64 modules_install
26. sudo ./tools/l4t_update_initrd.sh
27. Before building dtb, I blocked ‘//include "tegra234-p3768-camera-rbpcv2-imx219.dtsi’ in the ‘tegra234-p3768-0000+p3767-0000-dynamic.dts’ file and added the following ‘include "tegra234-p3768-camera-toshiba-tc358743.dtsi’.
When I run this, I get an error like ‘[ 11.771315] tc358743 9-000f: failed to get refclk: -2
[ 11.771359] tc358743: probe of 10-000f failed with error -2’.
This is clk in the tc358743_probe_of function.
static int tc358743_probe_of(struct tc358743_state *state)
struct clk *refclk;
u32 bps_pr_lane;
int ret;
PTR_ERR(refclk));
ep = of_graph_get_next_endpoint(dev->of_node, NULL);
if (!ep) {
dev_err(dev, "missing endpoint node\n");
return -EINVAL;
If i block clk, an error will occur right after ‘missing endpoint node’.
This problem was solved with the help of anomad, but the video comes in normally from CAM1, but not from CAM0.
Can you check if there is something wrong with the DTS file? tc358743.dtsi.txt (7.6 KB)
