You can set the nvpmodel to MANX to turn on all the CPUs.
Please try below command to maximize the perf for Orin NX.
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
| On the same AI task Orin NX 16GB works worse than Orin Nano 8GB | 2 | 1760 | October 6, 2023 | |
| Pace same on ORIN nano AND nano | 6 | 788 | October 25, 2023 | |
| Orin NX performances - comparing with Xavier NX | 6 | 3111 | August 2, 2023 | |
| Anyway to boost yolo performance on Jetson Orin? | 17 | 1716 | December 31, 2024 | |
| How to check gpu cores for an Jetson orin nx baord | 18 | 1147 | June 14, 2024 | |
| Orin NX performance issue | 6 | 1323 | February 28, 2023 | |
| Orin NX existing module have 100 tops | 1 | 119 | January 31, 2025 | |
| The batch inference does not work on the jetson Orin NX 16G | 17 | 236 | March 12, 2025 | |
| Jetson ORIN NX 16 GB does not use CUDA Core | 4 | 801 | December 15, 2023 | |
| Expected performance of the Jetson Orin NX 16GB | 4 | 2444 | July 26, 2023 |
