How to check gpu cores for an Jetson orin nx baord
how to check the how many cores are there for an gpu and how to get the how many cores are acvtivated? please resolve this!
Hi kckumar,
Are you using the devkit or custom board for Orin NX?
You can use “Jetson Power GUI” to check the current running CPU/GPU and power usage.
dev kit with 6.0 jet pack
not for monitoring i nedd how many cuda cores are there in gpu and in that how many are activated
can any one respond for this query?
You get 1024 CUDA cores with Orin NX.
They are all activated; the only difference is their frequency limit may change with differnt nvpmodel profile.
how to change the frequency limit, my board is working at 306mhz only how can i change to maximum?
https://docs.nvidia.com/jetson/archives/r36.3/DeveloperGuide/SD/PlatformPowerAndPerformance/JetsonOrinNanoSeriesJetsonOrinNxSeriesAndJetsonAgxOrinSeries.html?highlight=nvpmodel#power-mode-controls
that one we can change in the top right corner with power mode right? , but i keep in different modes but my gpu frequency is 306 mhz only and also my gpu is using more than 70% for playing normal video of 1080p resolution, what i need to do?
Change to MAXN.
in maxn only it was using that much of gpu!
I cannot really understand your English usage.
sorry!, I mean i have tested the gpu in maxn mode only. The frequency was 306mhz only
Frequency is dynamically changed according to the workload.
You don’t need GPU to work at 100% speed when you just play some video.
If you do want it to always run at the highest frequency, do:
sudo jetson_clocks
now the frequency changed to 918 mhz
can u please tell me how to enable the torch compiled with cuda?
I asked you in another post for the log but you didn’t give any useful information.
i have sent that errors when i am using that commands right?
