Questions Regarding the GPU Frequency of the Nvidia Jetson 32G
Hi everyone,
After setting up Jetson clocks, I noticed that the GPU frequency is not as described in the documentation (Jetson Orin NX Series and Jetson AGX Orin Series — Jetson Linux<br/>Developer Guide 34.1 documentation), where the maximum is stated to be 930.75 MHz. Instead, mine reaches 1.3 GHz. Could anyone help me understand why this is the case? I’ve confirmed that my device is the 32GB model.
Which jetpack version are you using here?
It’s jetpack 6
what is the result of cat /etc/nv_boot_control.conf?
here
This is devkit module which could be 1.3Ghz for gpu.
Where should I check the specifications? I also have a 64GB device, and I’d like to confirm how many power modes there are and the corresponding CPU and GPU frequencies for each mode.
Are you talking about how to check what module you are using or you are asking what would be the power modes for each module?
I have been referring to this webpage for relevant settings: Jetson Orin NX Series and Jetson AGX Orin Series — Jetson Linux<br/>Developer Guide 34.1 documentation. However, based on your recent response, it seems my Jetson might differ slightly from the specifications listed on the website. I would like to know similar information, as shown in the image
Your module is the oldest NV developer kit module which does not list on the page.
You could directly read nvpmodel.conf on your board for the detail.
