Hi,Nvidia Developer
I has a Jetson AGX Orin Developer Kit 32GB 200top version, first version.I Set MaxN Mode, but can’t overthan 40W. Can I make CPU Freq improve to 2.2GHz?
Hi 2486621459,
It seems the temperature on your board is too high at this moment.
Have you tried to run jetson_clocks?
Please refer to the following instruction for details.
Maximizing Jetson Orin Series Performance
Thanks to reply!
How Can I Get This Dev Kit Orin Module Datasheet? I can Find lasted in Nvidia Web ,but it’s CPU is 2.2GHz, My Dev Kit Is First Version. Bought it 2022 Q1.Is There Can Update JetpackSDK to improve CPU Max Freq to 2.2GHz.
My Current JetPack is 5.0.2
Please share the result of the following command on your devkit.
cat /etc/nv_boot_control.conf
Could you help to verify with the latest R35.4.1 for your AGX Orin devkit?
Please run the jetson_clocks and share the result of sudo jetson_clocks --show.
