Hi @Arumugamdeepakkumar — going from 420 ms (PyTorch) to 200 ms (TensorRT FP16) is already a solid win. Here are the next levers to pull on Jetson AGX Orin without sacrificing much accuracy.
**1. INT8 quantization**
This is usually the biggest next step. On Jetson, INT8 can be 1.5–2x faster than FP16 with minimal accuracy loss for object detection.
- Use TensorRT’s calibration with a few hundred representative images.
- If accuracy drops, try per-channel quantization or partial INT8 (keep sensitive layers in FP16).
- On Jetson Orin, INT8 uses the DPX/Tensor Cores effectively.
**2. Reduce input resolution**
If your model is running at 640x640, try 512x512 or 416x416. For 3-class detection, you can often drop resolution significantly with only a small mAP hit. Measure mAP@50 on your actual dataset, not just COCO.
**3. Prune the backbone**
If you’re using YOLOv8/YOLO11 or similar:
- Switch to a smaller variant (YOLOv8n instead of YOLOv8s/m).
- Use neural architecture search or structured pruning tools like Torch-Pruning.
- A smaller backbone in FP16 often beats a larger backbone in INT8.
**4. Optimize the TensorRT build**
```bash
/usr/src/tensorrt/bin/trtexec \
–onnx=model.onnx \
–fp16 --int8 \
–workspace=4096 \
–minShapes=images:1x3x416x416 \
–optShapes=images:1x3x416x416 \
–maxShapes=images:1x3x416x416 \
–saveEngine=model.plan
Use static shapes for single-image inference — dynamic shapes add overhead.
**5. CUDA Graphs**
For fixed-shape, single-image inference, capture a CUDA graph around the `enqueueV3` call. This removes per-launch CPU overhead and can give another 10–30% depending on model size.
**6. Pipeline preprocessing on GPU**
If you’re still doing resize/letterbox/normalize on CPU, move it to CUDA with NPP or a custom kernel. On Jetson, CPU→GPU copies are often a hidden bottleneck.
**7. Power mode**
Make sure you’re in MAXN mode:
```bash
sudo nvpmodel -m 0
sudo jetson_clocks
**Realistic target**
For a 3-class detector on AGX Orin, I’d expect:
- FP16 + 416x416: ~80–120 ms
- INT8 + 416x416: ~50–80 ms
- INT8 + 320x320: ~30–50 ms
Your actual numbers depend heavily on backbone choice. If you share which model architecture you’re using, I can give more specific advice.
