Tensorflow running very slow on Nvidia Jetson AGX Orin
Description
TensorFlow models are running very slow on Nvidia Jetson Orin AGX 64GB module. FaceNet model for face recognition is running at 2-3 FPS whereas the same model is showing around 10FPS in windows CPU laptop. I want to increase the speed in terms of FPS on Nvidia controller. Similar issue (i.e. running very slow) is seen in PyTorch also.
Environment
TensorRT Version: 10.3
GPU Type:
Nvidia Driver Version: 540.4.0
CUDA Version: 12.6
CUDNN Version: 9.3
Operating System + Version: Ubuntu 22.04.5 LTS
Python Version (if applicable): 3.10
TensorFlow Version (if applicable): tensorflow-2.16.1+nv24.8.dist-info
PyTorch Version (if applicable): torch-2.5.0a0+872d972e41.nv24.8.dist-info
Baremetal or Container (if container which image + tag):
Steps To Reproduce
Running any TensorFlow model is so slow taking similar or more execution time than CPU devices.
Please support me in improving the speed of model inferences. I could not find TensorRT examples to optimize TensorFlow model. Also, please share the relevant examples information.
Here are some suggestions for the common issues:
1. Performance
Please run the below command before benchmarking deep learning use case:
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
2. Installation
Installation guide of deep learning frameworks on Jetson:
3. Tutorial
Startup deep learning tutorial:
4. Report issue
If these suggestions don’t help and you want to report an issue to us, please attach the model, command/step, and the customized app (if any) with us to reproduce locally.
As mentioned above, please maximize the device performance first:
More, could you monitor your device with tegrastats concurrently to check if the model is running on the GPU?
$ sudo tegrastats
