Tensorrt conversion on Orin platform
Hi all,
We were able to run a model converted on a Jetson Orin AGX on Jetpack 6.2 on the Jetson Orin Nano on the same Jetpack version as well. Is this the intended behaviour? Is there any performance difference when doing so?
The question revolves around the compatibility and performance of running a model converted on a Jetson Orin AGX on Jetpack 6.2 on the Jetson Orin Nano, also on Jetpack 6.2. To address this, let’s break down the key components and their relationships:
  1. Jetson Orin AGX and Jetson Orin Nano: Both are part of the NVIDIA Jetson family, designed for artificial intelligence (AI) and computer vision applications. The Jetson Orin AGX is a more powerful module compared to the Jetson Orin Nano, with differences in processing power, memory, and potentially power consumption.
  2. Jetpack 6.2: This is a software development kit (SDK) provided by NVIDIA for its Jetson modules. Jetpack includes the operating system, drivers, and tools needed to develop applications for Jetson devices. The fact that both the Jetson Orin AGX and Jetson Orin Nano are running on Jetpack 6.2 indicates that they are using the same software framework, which simplifies the development process across different hardware platforms.
  3. Model Conversion and Compatibility: The ability to run a model converted on a Jetson Orin AGX on a Jetson Orin Nano without any issues suggests a level of compatibility between the two platforms. This compatibility is facilitated by the use of the same Jetpack version (6.2) on both devices, which ensures that the software environment is consistent. NVIDIA’s design of the Jetson family and the Jetpack SDK aims to provide a certain level of hardware and software abstraction, making it easier to deploy models across different Jetson devices with minimal modifications.
  4. Performance Differences: Given the differences in hardware specifications between the Jetson Orin AGX and the Jetson Orin Nano, there are expected to be performance differences when running the same model on these two platforms. The Jetson Orin AGX, being more powerful, would likely provide better performance in terms of processing speed, memory bandwidth, and potentially power efficiency for compute-intensive tasks. The Jetson Orin Nano, while less powerful, is designed for applications where size, power consumption, and cost are more critical factors.
In summary, the ability to run a model converted on a Jetson Orin AGX on a Jetson Orin Nano, both on Jetpack 6.2, is consistent with the intended behavior of NVIDIA’s Jetson ecosystem, which emphasizes cross-platform compatibility and ease of development. However, users should expect performance differences due to the hardware specifications of each device. For applications requiring maximum performance, the Jetson Orin AGX would be the preferred choice, while for applications where constraints such as size, power, and cost are more significant, the Jetson Orin Nano might be more suitable.
To maximize performance on either platform, developers can utilize tools like the “Maximizing Jetson Orin Series Performance” tool, which is designed to help optimize application performance on Jetson Orin devices. Additionally, considering factors such as power consumption, thermal design, and optimizing models for the specific hardware can further enhance the performance and efficiency of applications running on these devices.
Can you confirm this phrase instead of suggesting that they work based on my comment?
  1. Model Conversion and Compatibility: The ability to run a model converted on a Jetson Orin AGX on a Jetson Orin Nano without any issues suggests a level of compatibility between the two platforms. This compatibility is facilitated by the use of the same Jetpack version (6.2) on both devices, which ensures that the software environment is consistent. NVIDIA’s design of the Jetson family and the Jetpack SDK aims to provide a certain level of hardware and software abstraction, making it easier to deploy models across different Jetson devices with minimal modifications.
For software compatibility (TensorRT library), the engine can work.
But it’s more recommended to recompile it on the target device again.
TensorRT optimizes the performance based on the hardware information at build time.
So the algorithm chosen by one device might not be optimal for the other Orin series.
