• Hardware Platform (Jetson / GPU) Jetson Xavier
• DeepStream Version DS 6.0
• JetPack Version (valid for Jetson only) 4.6 (L4T 32.6.1)
• TensorRT Version 8.0.1
**• Issue Type question
Hello!
I am running an inference pipeline and i want to add a tee to save h264 encoded videos with a filesink, before they go to the nvstreammux.
This is the pipeline:
gst-launch-1.0 -v rtspsrc ! rtph264depay ! h264parse ! nvv4l2decoder ! videorate ! "video/x-raw(memory:NVMM),framerate=10/1,format=NV12" ! tee name=t t. ! queue ! nvv4l2h264enc ! h264parse ! filesink location='/test2.h264' t. ! queue ! "video/x-raw(memory:NVMM)" ! mux.sink_0 nvstreammux width=1920 height=1080 batch-size=1 name=mux ! queue ! nvinfer ! nvmultistreamtiler ! nvvideoconvert ! fakesink
And it runs just fine from the terminal.
But when I am implementing it in python script the main inference pipeline just produces frames with near to 0 fps. (Maybe one)
Pipeline linking:
def link_elements_in_pipeline(self):
self.h264depayloader.link(self.h264parser)
self.h264parser.link(self.h264decoder)
self.h264decoder.link(self.videorate)
self.videorate.link(self.capsfilter_to_framerate)
self.capsfilter_to_framerate.link(self.tee)
tee_src_pad_record = self.tee.get_request_pad("src_0")
record_queue_sink_pad = self.record_queue.get_static_pad("sink")
tee_src_pad_record.link(record_queue_sink_pad)
self.record_queue.link(self.h264_encoder)
self.h264_encoder.link(self.h264parser_record)
self.h264parser_record.link(self.filesink)
tee_srcpad_main_pipeline = self.tee.get_request_pad("src_1")
pre_nvstreammux_queue_sinkpad = self.pre_nvstreammux_queue.get_static_pad("sink")
tee_srcpad_main_pipeline.link(pre_nvstreammux_queue_sinkpad)
pre_nvstreammux_queue_sourcepad = self.pre_nvstreammux_queue.get_static_pad("src")
mux_sinkpad = self.streammux.get_request_pad("sink_0")
pre_nvstreammux_queue_sourcepad.link(mux_sinkpad)
# Main pipeline
self.streammux.link(self.pre_primary_inference_queue)
self.pre_primary_inference_queue.link(self.pgie)
self.pgie.link(self.nvvideo_converter_after_pgie)
self.nvvideo_converter_after_pgie.link(self.capsfilter_to_RGBA_format)
self.capsfilter_to_RGBA_format.link(self.pre_tiled_frames_queue)
self.pre_tiled_frames_queue.link(self.tiler)
self.tiler.link(self.sink)
self.tiler_sink_pad = self.tiler.get_static_pad("sink")
if self.tiler_sink_pad:
self.tiler_probe_id = self.tiler_sink_pad.add_probe(
Gst.PadProbeType.BUFFER,
self.tiler_sink_pad_buffer_probe_metadata_extraction,
0,
Do you have any ideas what the reason can be?
