Tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 32
Hi All:
please help!!
when use cheese or gst-launch-1.0 test camera, I got error:
[ 321.252263] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 32
[ 321.288770] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 321.307772] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 321.326684] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 321.345631] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 328.433271] imx185 30-0042: imx185_stop_streaming: debug info.
[ 328.437076] bwmgr API not supported
[ 328.448178] imx185 30-0042: imx185_power_off: power off
TEST_PATTERN picture look like
my Orin ver is “# R35 (release), REVISION: 3.1, GCID: 32827747, BOARD: t186ref, EABI: aarch64, DATE: Sun Mar 19 15:19:21 UTC 2023”
And dmesg log is
dmesg.log (137.2 KB)
And my dtsi file is :
tegra234-camera-imx185-a00.dtsi (15.3 KB)
tegra234-p3737-0000-camera-imx185-a00.dtsi (2.0 KB)
help me !! please .
I would suggest using v4l2-ctl to try and get the trace log if didn’t work.
https://elinux.org/Jetson/l4t/Camera_BringUp
Thanks for your help !
But now ,I change a sensor IMX390 to debug. I got same error.
dmesg log is :
[ 703.520578] imx185 30-001b: imx185_power_on: power on
[ 703.520592] imx185 30-001b: pw->reset_gpio = 394
[ 703.533053] bwmgr API not supported
[ 703.546228] imx185 30-001b: debug: func:imx185_set_mode, ++++++
[ 703.974325] imx185 30-001b: debug: func:imx185_set_mode, ------
[ 703.974341] imx185 30-001b: imx185_start_streaming: debug info.
[ 703.974348] imx185 30-001b: newcosemi:imx390 (0x0000)->0x00
[ 703.974488] imx185 30-001b: start_stream sucessful.
[ 706.051839] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 706.060995] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 706.071765] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 706.079478] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 706.090144] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 706.097861] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 706.108722] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 708.868015] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 708.877170] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 708.887960] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 708.895701] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 708.906353] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 708.914082] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 708.924896] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 711.683854] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 711.693029] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 711.703783] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 711.711506] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 711.722179] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 711.729892] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 711.740695] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 714.500024] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 714.509195] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 714.519793] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 714.527516] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 714.538156] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 714.545866] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 714.556680] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 717.315862] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 717.325030] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 717.334800] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 717.342507] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 717.353166] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 717.360880] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 717.371679] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 720.132047] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 720.141199] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 720.151921] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 720.159652] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 720.170316] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 720.178034] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 720.188823] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 722.948210] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 722.957394] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 722.967806] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 722.975573] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 722.986280] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 722.994100] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 723.005005] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 725.764203] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 725.773357] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 725.784262] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 725.792139] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 725.802828] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 725.810546] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 725.821347] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 728.579922] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 728.589087] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 728.599799] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 728.607577] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 728.618282] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 728.626001] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 728.636797] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 731.400064] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 731.409238] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 731.419967] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 731.427758] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 731.438449] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 731.446169] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 731.456962] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 734.212730] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 734.221886] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 734.231780] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 734.239657] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 734.250329] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 734.258049] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 734.268852] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 737.028729] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 737.037879] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 737.047786] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 737.055533] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 737.066210] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 737.073924] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 737.084715] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 739.844657] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 739.853817] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 739.864496] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 739.872518] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 739.883190] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 739.890908] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 739.901948] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 742.660655] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 742.669810] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 742.680521] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 742.688370] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 742.699031] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 742.706747] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 742.717784] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 745.476266] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 745.485418] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 745.496150] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 745.504033] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 745.514713] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 745.522428] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 745.533450] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 748.292406] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 748.301572] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 748.312344] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 748.320286] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 748.330968] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 748.338685] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 748.349467] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 751.108319] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 751.117475] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 751.127786] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 751.135517] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 751.146174] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 751.153892] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 751.164705] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 753.923917] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 753.933104] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 753.943779] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 753.951500] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 753.962167] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 753.969890] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 753.980688] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 756.739916] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 756.749070] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 756.759773] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 756.767493] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 756.778149] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 756.785860] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 756.796643] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 759.555927] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 759.565109] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 759.575799] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 759.583518] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 759.594174] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 759.601889] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 759.612689] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 762.371928] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 762.381114] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 762.391769] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 762.399494] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 762.410152] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 762.417869] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 762.428679] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 765.187932] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 765.197096] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 765.207795] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 765.215524] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 765.226198] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 765.233907] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 765.244707] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 768.003935] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 768.013089] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 768.023813] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 768.031557] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 768.042228] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 768.049947] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 768.060753] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 770.819942] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 770.829100] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 770.839802] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 770.847530] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 770.858182] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 770.865901] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 770.876704] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 773.635951] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 773.645119] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 773.656056] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 773.663784] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 773.674474] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 773.682185] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 773.693001] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 776.451949] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 776.461112] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 776.471821] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 776.479560] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 776.490219] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 776.497939] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 776.508767] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 779.268128] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 779.277298] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 779.287780] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 779.295483] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 779.306144] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 779.313865] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 779.324694] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 782.084136] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 782.093290] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 782.103789] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 782.111511] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 782.122190] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 782.129911] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 782.140725] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 784.900156] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 784.909312] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 784.919792] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 784.927513] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 784.938162] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 784.945881] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 784.956688] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
please help me .
beast wish .
What’s the trace log?
Hi ShanelCCC:
I use media-ctl command testing csi to vi got next log:
:~$ media-ctl -p -d /dev/media0
Media controller API version 5.10.104
Media device information
driver tegra-camrtc-ca
model NVIDIA Tegra Video Input Device
serial
bus info
hw revision 0x3
driver version 5.10.104
Device topology
  • entity 1: 13e40000.host1x:nvcsi@15a00000- (2 pads, 0 link)
    type V4L2 subdev subtype Unknown flags 0
    device node name /dev/v4l-subdev0
    pad0: Sink
    pad1: Source
  • entity 4: 13e40000.host1x:nvcsi@15a00000- (2 pads, 0 link)
    device node name /dev/v4l-subdev1
    pad0: Sink
    pad1: Source
  • entity 7: 13e40000.host1x:nvcsi@15a00000- (2 pads, 0 link)
    device node name /dev/v4l-subdev2
    pad0: Sink
    pad1: Source
  • entity 10: 13e40000.host1x:nvcsi@15a00000- (2 pads, 2 links)
    device node name /dev/v4l-subdev3
    pad0: Sink
    ← “imx185 33-001b”:0 [ENABLED]
    pad1: Source
    → “vi-output, imx185 33-001b”:0 [ENABLED]
  • entity 13: imx185 33-001b (1 pad, 1 link)
    type V4L2 subdev subtype Sensor flags 0
    device node name /dev/v4l-subdev4
    pad0: Source
    [fmt:UYVY8_1X16/1920x1080 field:none colorspace:srgb]
    → “13e40000.host1x:nvcsi@15a00000-”:0 [ENABLED]
  • entity 15: vi-output, imx185 33-001b (1 pad, 1 link)
    type Node subtype V4L flags 0
    device node name /dev/video0
    pad0: Sink
    ← “13e40000.host1x:nvcsi@15a00000-”:1 [ENABLED]
And I use dmesg command get next log:
dmesg_20230721.log (134.9 KB)
my dtsi file :
tegra234-camera-imx185-a00.dtsi (28.5 KB)
tegra234-p3737-0000-camera-imx185-a00.dtsi (3.6 KB)
please tell me what wrong i am . thanks!
Get the trace log by below command.
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
echo 3 > /sys/kernel/debug/camrtc/log-level
echo 1 > /sys/kernel/debug/tracing/events/camera_common/enable
echo > /sys/kernel/debug/tracing/trace
cat /sys/kernel/debug/tracing/trace
Hi ShaneCCC:
please help!
root@newcosemi-desktop:/home/newcosemi# cat /sys/kernel/debug/tracing/trace
tracer: nop
entries-in-buffer/entries-written: 21/21 #P:8
_-----=> irqs-off
/ _----=> need-resched
| / _—=> hardirq/softirq
|| / _–=> preempt-depth
||| / delay
TASK-PID CPU# |||| TIMESTAMP FUNCTION
 kworker/2:5-200     [002] ....    53.123754: rtcpu_string: tstamp:2722400383 id:0x04010000 str:"VM0 deactivating."
gst-launch-1.0-2935 [003] … 100.338786: tegra_channel_open: vi-output, imx185 33-001b
nvv4l2camerasrc-2938 [005] … 100.365760: tegra_channel_set_power: imx185 33-001b : 0x1
nvv4l2camerasrc-2938 [005] … 100.365779: camera_common_s_power: status : 0x1
nvv4l2camerasrc-2938 [005] … 100.366382: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1
nvv4l2camerasrc-2938 [005] … 100.366387: csi_s_power: enable : 0x1
nvv4l2camerasrc-2938 [005] … 100.367786: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/2:5-200 [002] … 100.372118: rtcpu_string: tstamp:4198882338 id:0x04010000 str:“VM0 activating.”
nvv4l2camerasrc-2938 [006] … 100.375157: tegra_channel_set_stream: enable : 0x1
nvv4l2camerasrc-2938 [006] … 100.390949: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
nvv4l2camerasrc-2938 [006] … 100.390951: csi_s_stream: enable : 0x1
nvv4l2camerasrc-2938 [006] … 100.391297: tegra_channel_set_stream: imx185 33-001b : 0x1
kworker/2:5-200 [002] … 100.428082: rtcpu_vinotify_event: tstamp:4199537212 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:134368993280 data:0x399d580010000000
kworker/2:5-200 [002] … 100.428083: rtcpu_vinotify_event: tstamp:4199537370 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:134368999776 data:0x0000000031000001
kworker/2:5-200 [002] … 100.428083: rtcpu_vinotify_event: tstamp:4199537527 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:134369056064 data:0x399d550010000000
kworker/2:5-200 [002] … 100.428083: rtcpu_vinotify_event: tstamp:4199537662 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:134369062688 data:0x0000000031000002
vi-output, imx1-2941 [005] … 102.972617: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 13
kworker/2:5-200 [002] … 103.008135: rtcpu_vinotify_event: tstamp:4280375760 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:136966763648 data:0x399d580010000000
kworker/2:5-200 [002] … 103.008138: rtcpu_vinotify_event: tstamp:4280375899 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:136966806336 data:0x0000000031000001
kworker/2:5-200 [002] … 103.008139: rtcpu_vinotify_event: tstamp:4280376056 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:136966823840 data:0x399d550010000000
kworker/2:5-200 [002] … 103.008140: rtcpu_vinotify_event: tstamp:4280376190 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:136966884224 data:0x0000000031000002
trace_log.log (551.0 KB)
The trace log tell didn’t receive any validate data.
Please probe the MIPI signal to make sure the output signal match MIPI spec.
I measured CSI0 with an oscilloscope and there is data information. The circuit diagram is shown in the table. If I want to receive a mipi signal in FPC_1, how do I configure my dtsi file。 I use the FPC_1 、PFC_2、PFC_3、FPC_4 ,the results are the same. no images.
beast wish!
Check the programing guide to configure your dts.
https://docs.nvidia.com/jetson/archives/r35.3.1/DeveloperGuide/text/SD/CameraDevelopment/CameraDriverPorting.html
Hi NvIdia
I change CSI 2-line to 4line mode. now can gei little frame data.
I get picture ,and trace log 。
At end of trace log :
kworker/3:12-219 [003] … 240.436952: rtcpu_vinotify_event: tstamp:8630246037 cch:0 vi:0 tag:FE channel:0x00 frame:192 vi_tstamp:276162314656 data:0x000000c000000020
kworker/3:12-219 [003] … 240.436956: rtcpu_vinotify_event: tstamp:8630246186 cch:0 vi:0 tag:FS channel:0x00 frame:193 vi_tstamp:276162683328 data:0x000000c100000010
kworker/3:12-219 [003] … 240.436956: rtcpu_vinotify_event: tstamp:8630246316 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:193 vi_tstamp:276162715424 data:0x0000000000000249
kworker/3:12-219 [003] … 240.436957: rtcpu_vinotify_event: tstamp:8631003264 cch:-1 vi:0 tag:FE channel:0x00 frame:193 vi_tstamp:276188601568 data:0x0000000000000020
kworker/3:12-219 [003] … 246.673254: rtcpu_string: tstamp:8825654577 id:0x04010000 str:“VM0 deactivating.”
the program is end.
please help!
best wish!
camera_trace-20230724.log (151.1 KB)
Make sure the sensor output meta data to modify the embedded_metadata_height in dts
Hi ShaneCCC:
when I have done next debug :
sudo su
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
echo 2 > /sys/kernel/debug/camrtc/log-level
I got the next video:
And got log more info like : " kworker/7:0-50 [007] … 299.594232: rtcpu_vinotify_event: tstamp:10478850660 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:335317101408 data:0x00000000000003c9
kworker/7:0-50 [007] … 299.594233: rtcpu_vinotify_error: tstamp:10479222688 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:335335104320 data:0x0000000000400060
kworker/7:0-50 [007] … 299.594234: rtcpu_vinotify_error: tstamp:10479253990 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:335336103968 data:0x00000000000003c9
kworker/7:0-50 [007] … 299.594234: rtcpu_vinotify_event: tstamp:10479526534 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:335335104320 data:0x0000000000400060"
tracing_20230725.log (2.1 MB)
please help me, next can I . and get 30 fps videos . thanks.
Did you confirm the embedded data output by sensor??
yes , sensor no embedded data. so I set “embedded_metadata_height = “0”;”
Thnks!
CRC error on payload. It could be CRC error at frame end package.
kworker/7:0-50 [007] … 299.874221: rtcpu_vinotify_event: tstamp:10489025519 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:335639145056 data:0x0000000000400060
Hi nvidia team:
when I test my sensor driver , I get a picture.
but When I use the Debug inof like "
then Orin can get next picture
I get the trace inof.
trace_log-20280807.log (150.5 KB)
please help me! where i wrong.thanks!!
by the way , Is Orin have PRBS( Pseudo-Random Binary Sequences ,中文 : 伪随机码). to test between my sensor and Orin channel whether there is continuity
Boost the clocks to try.
sudo nvpmodel -m 2
sudo jetson_clocks
sudo su
echo 1 > /sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee  /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
cat /sys/kernel/debug/bpmp/debug/clk/emc/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/emc/rate
echo userspace > /sys/devices/13e10000.host1x/15340000.vic/devfreq/15340000.vic/governor
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vic/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vic/state
cat /sys/kernel/debug/bpmp/debug/clk/vic/max_rate > /sys/kernel/debug/bpmp/debug/clk/vic/rate
Hi ShanmeCCC:
I used your method from yesterday and there are some changes in the picture Please refer to the following file.
but not get trace info when i “cat /sys/kernel/debug/tracing/trace”
And when I use run_camera shell script to test sensor , I get next info
$ run_camera
kernel version is:
Linux version 5.10.104-tegra (harrison@harrison) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #146 SMP PREEMPT Tue Aug 8 09:52:38 CST 2023
l4t version is:R35.3.1
Jetson AGX Orin
display=1920 x 1080
camera count=1 :
/dev/video0
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
WARNING: from element /GstPipeline:pipeline0/GstNv3dSink:nv3dsink0: Pipeline construction is invalid, please add queues.
Additional debug info:
gstbasesink.c(1209): gst_base_sink_query_latency (): /GstPipeline:pipeline0/GstNv3dSink:nv3dsink0:
Not enough buffering available for the processing deadline of 0:00:00.015000000, add enough queues to buffer 0:00:00.015000000 additional data. Shortening processing latency to 0:00:00.000000000.
Got EOS from element “pipeline0”.
Execution ended after 0:00:06.520399270
Setting pipeline to NULL …
Freeing pipeline …
please help me what wrong I done. thanks!
How about run the v4l2-ctl to collect the trace log.
v4l2-ctl --set-fmt-video=width=1920,height=1080 --set-ctrl bypass_mode=0 --stream-mmap
