When the monitor is off, I get a ton of errors about i2c and HDMI.
Would there be a way to eliminate these errors?
All of these repeat every 5 seconds. I put them in a separate log file at least so as not to clutter my syslog, but I like to keep my Jetson AGX Xaview running without the monitor (so no HDMI signal…)
Jun 5 11:09:16 ve1 kernel: [166526.291345] tegra-i2c 31c0000.i2c: no acknowledge from address 0x54
Jun 5 11:09:16 ve1 kernel: [166526.291612] Switching i2c_ddc sclk rate: from 100000, to 50000
Jun 5 11:09:16 ve1 kernel: [166526.294307] tegra-i2c 31c0000.i2c: no acknowledge from address 0x54
Jun 5 11:09:16 ve1 kernel: [166526.294496] Switching i2c_ddc sclk rate: from 50000, to 25000
Jun 5 11:09:16 ve1 kernel: [166526.296531] tegra-i2c 31c0000.i2c: no acknowledge from address 0x54
Jun 5 11:09:16 ve1 kernel: [166526.296720] Switching i2c_ddc sclk rate: from 25000, to 12500
Jun 5 11:09:16 ve1 kernel: [166526.298500] tegra-i2c 31c0000.i2c: no acknowledge from address 0x54
Jun 5 11:09:16 ve1 kernel: [166526.298698] Switching i2c_ddc sclk rate: from 12500, to 6250
Jun 5 11:09:16 ve1 kernel: [166526.301575] tegra-i2c 31c0000.i2c: no acknowledge from address 0x54
Jun 5 11:09:16 ve1 kernel: [166526.301756] Cannot change the i2c_ddc rate, the rate:3125 cannotbe below minimum rate:5000 or above maxim
Jun 5 11:09:16 ve1 kernel: [166526.301943] Switching i2c_ddc sclk rate: from 6250, to 100000
Jun 5 11:09:16 ve1 kernel: [166526.302098] tegradc 15200000.nvdisplay: hdmi: scdc scrambling status is reset, trying to reconfigure.
Jun 5 11:09:16 ve1 kernel: [166526.306264] tegra-i2c 31c0000.i2c: no acknowledge from address 0x54
Jun 5 11:09:16 ve1 kernel: [166526.310199] tegra-i2c 31c0000.i2c: no acknowledge from address 0x54
