I have cuda template class as
cuda_class.hcu
template <class T>
class cuda_class
cuda_class.cu
#include "cuda_class.cuh"
template <class T>
cuda_class<T>::cuda_class()
main.cc
#include "cuda_class.cu"
int main()
cuda_class<int> obj;
I use the following CMakeLists.txt
to compile the code
cmake_minimum_required(VERSION 3.21.3)
project(FasNasmGpu
VERSION 0.1
DESCRIPTION "FAS With NASM on GPU"
LANGUAGES CXX C)
set(CMAKE_THREAD_LIBS_INIT "-lpthread")
set(CMAKE_HAVE_THREADS_LIBRARY 1)
set(CMAKE_USE_WIN32_THREADS_INIT 0)
set(CMAKE_USE_PTHREADS_INIT 1)
set(THREADS_PREFER_PTHREAD_FLAG ON)
if (NOT CMAKE_BUILD_TYPE)
set(CMAKE_BUILD_TYPE "Release")
endif()
if (CMAKE_BUILD_TYPE STREQUAL "Debug")
set (CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -g -fsanitize=address ")
endif()
if (CMAKE_BUILD_TYPE STREQUAL "RelWithDebInfo")
set (CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -g")
endif()
include(CheckCXXSourceCompiles)
set (CMAKE_CXX_FLAGS "-Wsign-compare -Wno-unused-variable -Wno-unused-parameter -Wdeprecated-copy -std=c++17 ")
set (CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -ltbb")
find_package(MPI)
# CUDA
include(CheckLanguage)
check_language(CUDA)
if(CMAKE_CUDA_COMPILER)
set(FASNASMGPU_USE_CUDA ON CACHE BOOL "Use CUDA")
endif()
if (FASNASMGPU_USE_CUDA)
enable_language(CUDA)
endif()
set (CUDA_SEPARABLE_COMPILATION ON)
set (CMAKE_CUDA_HOST_COMPILER "${CMAKE_CUDA_FLAGS}")
find_package(Eigen3 3.3 REQUIRED NO_MODULE)
# VTK library
find_package(VTK REQUIRED COMPONENTS
vtkCommonColor
vtkCommonCore
vtkCommonDataModel
vtkInteractionStyle
vtkRenderingContextOpenGL2
vtkRenderingCore
vtkRenderingFreeType
vtkRenderingGL2PSOpenGL2
vtkRenderingOpenGL2
vtkCommonCore
vtkCommonDataModel
vtkIOXML
QUIET
if (NOT VTK_FOUND)
message("Skipping StructuredGrid: ${VTK_NOT_FOUND_MESSAGE}")
return ()
endif()
message (STATUS "VTK_VERSION: ${VTK_VERSION}")
if (VTK_VERSION VERSION_LESS "8.90.0")
# old system
INCLUDE_DIRECTORIES(include ${VTK_USE_FILE} ${VTK_INCLUDE_DIRS} ${CMAKE_CUDA_TOOLKIT_INCLUDE_DIRECTORIES} ${EIGEN3_INCLUDE_DIRS})
target_compile_options(lib PRIVATE $<$<COMPILE_LANGUAGE:CUDA>: --expt-extended-lambda -lcudadevrt;
vtk_module_autoinit(
TARGETS lib
MODULES ${VTK_LIBRARIES}
TARGET_LINK_LIBRARIES(lib ${VTK_LIBRARIES} ${CUDA_LIBRARIES})
add_executable(${PROJECT_NAME} MACOSX_BUNDLE "test/main.cc")
TARGET_LINK_LIBRARIES(${PROJECT_NAME} lib ${VTK_LIBRARIES} ${CUDA_LIBRARIES})
else ()
# include all components
INCLUDE_DIRECTORIES(include ${VTK_INCLUDE_DIRS} ${CUDA_LIBRARIES} ${CMAKE_CUDA_TOOLKIT_INCLUDE_DIRECTORIES} ${EIGEN3_INCLUDE_DIRS})
FILE (GLOB CXX_LIB "src/*.cc")
FILE (GLOB CUDA_LIB "src/*.cu")
ADD_LIBRARY(lib SHARED ${CXX_LIB} ${CUDA_LIB})
TARGETS lib
TARGET_LINK_LIBRARIES(lib ${VTK_LIBRARIES} ${CUDA_LIBRARIES} )
TARGET_LINK_LIBRARIES(${PROJECT_NAME} lib ${VTK_LIBRARIES} ${CUDA_LIBRARIES} )
# vtk_module_autoinit is needed
TARGETS ${PROJECT_NAME}
endif ()
When I compile it I get the following error
Building CXX object CMakeFiles/FasNasmGpu.dir/test/main.cc.o
/usr/bin/c++ -Dkiss_fft_scalar=double -DvtkRenderingContext2D_AUTOINIT_INCLUDE=\"/home/mehdi/myFolder/programming/domain_decomposition/gpu_mg_asm/build/CMakeFiles/vtkModuleAutoInit_04d683062bbc5774e34e8c62b13e1a5a.h\" -DvtkRenderingCore_AUTOINIT_INCLUDE=\"/home/mehdi/myFolder/programming/domain_decomposition/gpu_mg_asm/build/CMakeFiles/vtkModuleAutoInit_04d683062bbc5774e34e8c62b13e1a5a.h\" -DvtkRenderingOpenGL2_AUTOINIT_INCLUDE=\"/home/mehdi/myFolder/programming/domain_decomposition/gpu_mg_asm/build/CMakeFiles/vtkModuleAutoInit_04d683062bbc5774e34e8c62b13e1a5a.h\" -I/home/mehdi/myFolder/programming/domain_decomposition/gpu_mg_asm/include -I/opt/cuda/targets/x86_64-linux/include -I/usr/include/eigen3 -isystem /usr/include/vtk -isystem /usr/include/freetype2 -Wsign-compare -Wno-unused-variable -Wno-unused-parameter -Wdeprecated-copy -std=c++17 -ltbb -O3 -DNDEBUG -fopenmp -MD -MT CMakeFiles/FasNasmGpu.dir/test/main.cc.o -MF CMakeFiles/FasNasmGpu.dir/test/main.cc.o.d -o CMakeFiles/FasNasmGpu.dir/test/main.cc.o -c /home/mehdi/myFolder/programming/domain_decomposition/gpu_mg_asm/test/main.cc
/opt/cuda/targets/x86_64-linux/include/thrust/system/detail/generic/for_each.h:48:69: error: static assertion failed: unimplemented for this system
48 | (thrust::detail::depend_on_instantiation<InputIterator, false>::value)
/opt/cuda/targets/x86_64-linux/include/thrust/detail/static_assert.h:50:58: note: in definition of macro ‘THRUST_STATIC_ASSERT_MSG’
50 | # define THRUST_STATIC_ASSERT_MSG(B, msg) static_assert(B, msg)
Do you have any Idea what I should change in cmake file?
