i meet with some strange question. that is
when declare a template function in .h file like bellow
template<int32_t BLOCK_SIZE> __global__ void test_shabal_with_share_mem(shabal_info);
and realize it in cu file
template<int32_t BLOCK_SIZE> __global__ void shabal256::test_shabal_with_share_mem(shabal256::shabal_info info){
but when compiler the symbol is not found
void __cdecl shabal256::test_shabal_with_share_mem<8>(struct shabal256::shabal256_chunk_data)" (??$test_shabal_with_share_mem@$07@shabal256@@YAXUshabal256_chunk_data@0@@Z)
However, if define the function just in the .h file
template<int32_t BLOCK_SIZE> __global__ void test_shabal_with_share_mem(shabal_info info){
the compiler will find that symbol, and pass normally , why ?
