I have the following code (abstracted from the real thing). I can make it crash cudafe1 or give unresolved references, but can’t make it work.
// templated kernel
template
global void prim_kernel(float * dest, int n_elts,
float *a0, float *a1, T a2i);
float *a0, float *a1, float a2i)
float *a0, float *a1, float *a2)
// templated host side
template
void prim(float * d, float *a0, float *a1, T2 a2)
int n_elts = 1000000;
int block_size = 128;
int n_blocks = (n_elts / block_size) + ((n_elts % block_size) ? 1 : 0);
prim_kernel<<< n_blocks, block_size, 0>>>(d, n_elts, a0, a1, a2);
define USE_TEMPLATE
#ifdef USE_TEMPLATE // correct, but crashes cudafe1
template void prim(float *d, float *a0, float *a1, float *a2);
template void prim(float *d, float *a0, float *a1, float a2);
#else // gives unresolved externals because it generates non-templated versions
endif
main()
float f;
prim(&f, &f, &f, &f);
prim(&f, &f, &f, f);
If I compile it as is, it crashes cudafe1:
C:\tmp>nvcc --version
nvcc: NVIDIA ® Cuda compiler driver
Copyright © 2005-2007 NVIDIA Corporation
Built on Wed_Jul_16_12:57:50_PDT_2008
Cuda compilation tools, release 2.0, V0.2.1221
C:\tmp>nvcc -v cudabug.cu
#$ SPACE=
#$ MODE=DEVICE
#$ HERE=C:\CUDA\bin
#$ THERE=C:\CUDA\bin
#$ TOP=C:\CUDA\bin/..
#$ PATH=C:\CUDA\bin/../extools/bin;C:\CUDA\bin/../open64/bin;C:\CUDA\bin/../bin;
C:\CUDA\bin/../lib;C:\Program Files\Microsoft Visual Studio .NET 2003\Common7\ID
E;C:\Program Files\Microsoft Visual Studio .NET 2003\VC7\BIN;C:\Program Files\Mi
crosoft Visual Studio .NET 2003\Common7\Tools;C:\Program Files\Microsoft Visual
Studio .NET 2003\Common7\Tools\bin\prerelease;C:\Program Files\Microsoft Visual
Studio .NET 2003\Common7\Tools\bin;C:\Program Files\Microsoft Visual Studio .NET
2003\SDK\v1.1\bin;C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322;c:\ruby\bin;C:\P
erl\bin;c:\cygwin\bin;C:\Program Files\Intel\MKL\9.0\ia32\bin;C:\WINDOWS\system3
2;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\HTMLDoc;C:\Program Files
Common Files\Adobe\AGL;C:\Program Files\Common Files\Avid;C:\Program Files\Ratio
nal\common;c:\Program Files\Debugging Tools for Windows;C:\Program Files\GNU\Gnu
PG\pub;C:\PROGRA~1\DISKEE~1\DISKEE~1;C:\Program Files\TortoiseSVN\bin;C:\Progra
m Files\QuickTime\QTSystem;C:\CUDA\bin;C:\Program Files\Bitvise Tunnelier;c:\Pr
ogram Files\PuTTY;C:\Program Files\Lua\5.1;C:\Program Files\Lua\5.1\clibs;C:\Pro
gram Files\GTK2-Runtime\lib;
#$ INCLUDES=“-IC:\CUDA\bin/../include” “-IC:\CUDA\bin/../include/cudart”
#$ LIBRARIES= “/LIBPATH:C:\CUDA\bin/../lib” cudart.lib
#$ CUDAFE_FLAGS=
#$ OPENCC_FLAGS=
#$ PTXAS_FLAGS=
#$ VSINSTALLDIR=C:\Program Files\Microsoft Visual Studio .NET 2003\VC7\BIN/../..
#$ VCINSTALLDIR=C:\Program Files\Microsoft Visual Studio .NET 2003\VC7\BIN/../..
#$ C:\Program Files\Microsoft Visual Studio .NET 2003\VC7\BIN/../../common7/Tool
s/vsvars32.bat
C:\tmp>call C:\DOCUME~1\garyo\LOCALS~1\Temp/tmpxft_00001328_00000000-2.bat
Setting environment for using Microsoft Visual Studio .NET 2003 tools.
(If you have another version of Visual Studio or Visual C++ installed and wish
to use its tools from the command line, run vcvars32.bat for that version.)
C:\tmp>set 1>C:\DOCUME~1\garyo\LOCALS~1\Temp/tmpxft_00001328_00000000-1
#$ DevEnvDir=C:\Program Files\Microsoft Visual Studio .NET 2003\VC7\BIN/../..
#$ INCLUDE=C:\Program Files\Microsoft Visual Studio .NET 2003\VC7\BIN/../..\VC7
ATLMFC\INCLUDE;C:\Program Files\Microsoft Visual Studio .NET 2003\VC7\BIN/../..
VC7\INCLUDE;C:\Program Files\Microsoft Visual Studio .NET 2003\VC7\BIN/../..\VC7
\PlatformSDK\include\prerelease;C:\Program Files\Microsoft Visual Studio .NET 20
03\VC7\BIN/../..\VC7\PlatformSDK\include;C:\Program Files\Microsoft Visual Studi
o .NET 2003\SDK\v1.1\include;C:\Program Files\Microsoft Visual Studio .NET 2003
VC7\ATLMFC\INCLUDE;C:\Program Files\Microsoft Visual Studio .NET 2003\VC7\INCLUD
E;C:\Program Files\Microsoft Visual Studio .NET 2003\VC7\PlatformSDK\include\pre
release;C:\Program Files\Microsoft Visual Studio .NET 2003\VC7\PlatformSDK\inclu
de;C:\Program Files\Microsoft Visual Studio .NET 2003\SDK\v1.1\include;C:\Progra
m Files\Intel\MKL\9.0\include;C:\Program Files\Microsoft Visual Studio .NET 2003
\SDK\v1.1\include
#$ LIB=C:\Program Files\Microsoft Visual Studio .NET 2003\VC7\BIN/../..\VC7\ATLM
FC\LIB;C:\Program Files\Microsoft Visual Studio .NET 2003\VC7\BIN/../..\VC7\LIB;
C:\Program Files\Microsoft Visual Studio .NET 2003\VC7\BIN/../..\VC7\PlatformSDK
\lib\prerelease;C:\Program Files\Microsoft Visual Studio .NET 2003\VC7\BIN/../..
\VC7\PlatformSDK\lib;C:\Program Files\Microsoft Visual Studio .NET 2003\SDK\v1.1
\lib;C:\Program Files\Microsoft Visual Studio .NET 2003\VC7\ATLMFC\LIB;C:\Progra
m Files\Microsoft Visual Studio .NET 2003\VC7\LIB;C:\Program Files\Microsoft Vis
ual Studio .NET 2003\VC7\PlatformSDK\lib\prerelease;C:\Program Files\Microsoft V
isual Studio .NET 2003\VC7\PlatformSDK\lib;C:\Program Files\Microsoft Visual Stu
dio .NET 2003\SDK\v1.1\lib;C:\Program Files\Intel\MKL\9.0\ia32\lib;C:\Program Fi
les\Microsoft Visual Studio .NET 2003\SDK\v1.1\Lib
#$ MSVCDir=C:\Program Files\Microsoft Visual Studio .NET 2003\VC7\BIN/../..\VC7
#$ Path=C:\Program Files\Microsoft Visual Studio .NET 2003\VC7\BIN/../..;C:\Prog
ram Files\Microsoft Visual Studio .NET 2003\VC7\BIN/../..\VC7\BIN;C:\Program Fil
es\Microsoft Visual Studio .NET 2003\VC7\BIN/../..\Common7\Tools;C:\Program File
s\Microsoft Visual Studio .NET 2003\VC7\BIN/../..\Common7\Tools\bin\prerelease;C
:\Program Files\Microsoft Visual Studio .NET 2003\VC7\BIN/../..\Common7\Tools\bi
n;C:\Program Files\Microsoft Visual Studio .NET 2003\SDK\v1.1\bin;C:\WINDOWS\Mic
rosoft.NET\Framework\v1.1.4322;C:\CUDA\bin/../extools/bin;C:\CUDA\bin/../open64/
bin;C:\CUDA\bin/../bin;C:\CUDA\bin/../lib;C:\Program Files\Microsoft Visual Stud
io .NET 2003\Common7\IDE;C:\Program Files\Microsoft Visual Studio .NET 2003\VC7
BIN;C:\Program Files\Microsoft Visual Studio .NET 2003\Common7\Tools;C:\Program
Files\Microsoft Visual Studio .NET 2003\Common7\Tools\bin\prerelease;C:\Program
Files\Microsoft Visual Studio .NET 2003\Common7\Tools\bin;C:\Program Files\Micro
soft Visual Studio .NET 2003\SDK\v1.1\bin;C:\WINDOWS\Microsoft.NET\Framework\v1.
1.4322;c:\ruby\bin;C:\Perl\bin;c:\cygwin\bin;C:\Program Files\Intel\MKL\9.0\ia32
\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\HT
MLDoc;C:\Program Files\Common Files\Adobe\AGL;C:\Program Files\Common Files\Avid
;C:\Program Files\Rational\common;c:\Program Files\Debugging Tools for Windows;C
:\Program Files\GNU\GnuPG\pub;C:\PROGRA~1\DISKEE~1\DISKEE~1;C:\Program Files\To
rtoiseSVN\bin;C:\Program Files\QuickTime\QTSystem;C:\CUDA\bin;C:\Program Files
Bitvise Tunnelier;c:\Program Files\PuTTY;C:\Program Files\Lua\5.1;C:\Program Fil
es\Lua\5.1\clibs;C:\Program Files\GTK2-Runtime\lib;;
#$ PATH=C:/Program Files/Microsoft Visual Studio .NET 2003/VC7/BIN;C:\Program Fi
les\Microsoft Visual Studio .NET 2003\VC7\BIN/../..;C:\Program Files\Microsoft V
isual Studio .NET 2003\VC7\BIN/../..\VC7\BIN;C:\Program Files\Microsoft Visual S
tudio .NET 2003\VC7\BIN/../..\Common7\Tools;C:\Program Files\Microsoft Visual St
udio .NET 2003\VC7\BIN/../..\Common7\Tools\bin\prerelease;C:\Program Files\Micro
soft Visual Studio .NET 2003\VC7\BIN/../..\Common7\Tools\bin;C:\Program Files\Mi
crosoft Visual Studio .NET 2003\SDK\v1.1\bin;C:\WINDOWS\Microsoft.NET\Framework
v1.1.4322;C:\CUDA\bin/../extools/bin;C:\CUDA\bin/../open64/bin;C:\CUDA\bin/../bi
n;C:\CUDA\bin/../lib;C:\Program Files\Microsoft Visual Studio .NET 2003\Common7
IDE;C:\Program Files\Microsoft Visual Studio .NET 2003\VC7\BIN;C:\Program Files
Microsoft Visual Studio .NET 2003\Common7\Tools;C:\Program Files\Microsoft Visua
l Studio .NET 2003\Common7\Tools\bin\prerelease;C:\Program Files\Microsoft Visua
l Studio .NET 2003\Common7\Tools\bin;C:\Program Files\Microsoft Visual Studio .N
ET 2003\SDK\v1.1\bin;C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322;c:\ruby\bin;C:
\Perl\bin;c:\cygwin\bin;C:\Program Files\Intel\MKL\9.0\ia32\bin;C:\WINDOWS\syste
m32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\HTMLDoc;C:\Program File
s\Common Files\Adobe\AGL;C:\Program Files\Common Files\Avid;C:\Program Files\Rat
ional\common;c:\Program Files\Debugging Tools for Windows;C:\Program Files\GNU\G
nuPG\pub;C:\PROGRA~1\DISKEE~1\DISKEE~1;C:\Program Files\TortoiseSVN\bin;C:\Prog
ram Files\QuickTime\QTSystem;C:\CUDA\bin;C:\Program Files\Bitvise Tunnelier;c:
Program Files\PuTTY;C:\Program Files\Lua\5.1;C:\Program Files\Lua\5.1\clibs;C:\P
#$ cl -D__CUDA_ARCH__=100 -nologo -E -TP -DCUDA_FLOAT_MATH_FUNCTIONS -DCUDA_NO_S
M_11_ATOMIC_INTRINSICS -DCUDA_NO_SM_13_DOUBLE_INTRINSICS -DCUDA_NO_SM_12_ATOMIC_
INTRINSICS “-IC:\CUDA\bin/../include” “-IC:\CUDA\bin/../include/cudart” -I. -
D__CUDACC__ -C -FI “cuda_runtime.h” > “C:\DOCUME~1\garyo\LOCALS~1\Temp/tmpxft_0
0001328_00000000-6_cudabug.cpp1.ii” “cudabug.cu”
cudabug.cu
#$ cudafe --m32 --microsoft_version=1310 --msvc_target_version=1310 --compiler_b
indir “C:/Program Files/Microsoft Visual Studio .NET 2003/VC7/BIN” --diag_error=
host_device_limited_call -tused --gen_c_file_name “C:\DOCUME~1\garyo\LOCALS~1\Te
mp/tmpxft_00001328_00000000-3_cudabug.cudafe1.c” --stub_file_name “C:\DOCUME~1\g
aryo\LOCALS~1\Temp/tmpxft_00001328_00000000-3_cudabug.cudafe1.stub.c” --stub_hea
der_file_name “C:\DOCUME~1\garyo\LOCALS~1\Temp/tmpxft_00001328_00000000-3_cudabu
g.cudafe1.stub.h” --gen_device_file_name "C:\DOCUME~1\garyo\LOCALS~1\Temp/tmpxft
00001328_00000000-3_cudabug.cudafe1.gpu" --include_file_name C:\DOCUME~1\garyo
LOCALS~1\Temp/tmpxft_00001328_00000000-5_cudabug.fatbin.c “C:\DOCUME~1\garyo\LOC
ALS~1\Temp/tmpxft_00001328_00000000-6_cudabug.cpp1.ii”
cudabug.cu(34): internal error: assertion failed: get_scope_for_routine_definiti
on: scope is NULL (D:/Bld/rel/gpgpu/toolkit/r2.0/compiler/edg/EDG_3.9/src/c_gen
be.c, line 8887)
1 catastrophic error detected in the compilation of “C:\DOCUME~1\garyo\LOCALS~1
Temp/tmpxft_00001328_00000000-6_cudabug.cpp1.ii”.
Compilation aborted.
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application’s support team for more information.
–error 0x3 –
If I toggle the define USE_TEMPLATE to turn off the template decls near the end, it compiles OK, but won’t link due to unresolved refs:
(just the tail of nvcc -v here, showing the invocation of cl to link):
#$ cl -D__CUDA_ARCH__=100 -nologo -Fe"a.exe" “C:\DOCUME~1\garyo\LOCALS~1\Temp/tm
pxft_00001548_00000000-13_cudabug.obj” -link -INCREMENTAL:NO “/LIBPATH:C:\CUDA
tmpxft_00001548_00000000-13_cudabug.obj : error LNK2019: unresolved external sym
bol “void __cdecl prim(float *,float *,float *,float)” (?prim@@YAXPAM00M@Z) refe
renced in function _main
bol “void __cdecl prim(float *,float *,float *,float *)” (?prim@@YAXPAM000@Z) re
ferenced in function _main
a.exe : fatal error LNK1120: 2 unresolved externals
–error 0x2 –
The reason for this latter error is a name mangling issue. But I think the correct code is to use the “template” keyword anyway, and that’s the main problem – it crashes cudafe1. Is there any workaround? I need this kind of thing to work, and on a fairly large scale.
– Gary
