Divide the matrix multiplication task into two parts, create two CUDA streams, one utilizing Tensor Cores for computation and the other using CUDA Cores for computation. Can Tensor Cores and CUDA Cores compute simultaneously? How can we prove they are computing simultaneously?
I have read this paper, and it involves simultaneous computation through hardware. However, is there any way to modify the hardware without changing it.
Related topics
| Run Parallel Tensor Cores GEMM and Cuda GEMM | 9 | 2952 | August 14, 2022 | |
| Tensor Cores | 7 | 1677 | May 5, 2020 | |
| Is it possible to use cuda core and tensorcore concurrently ? | 0 | 1730 | October 13, 2019 | |
| How to use cuda core and tensor core simultaneously? | 4 | 802 | August 16, 2022 | |
| Multiple Streams on Tensor Cores | 4 | 959 | February 14, 2019 | |
| Programming Tensor Cores in CUDA 9 | 0 | 319 | August 21, 2022 | |
| Parallel execution on tensor cores and cuda cores on the same SM | 3 | 1440 | September 21, 2021 | |
| Use cuda core & tensor core at the same time | 5 | 1137 | September 15, 2024 | |
| CUDA cores vs Tensor Cores | 15 | 5282 | July 15, 2020 | |
| Concurrent execution of CUDA and Tensor cores | 34 | 10496 | November 3, 2024 |
