we successfully build the libtensorflow_cc.so on the Drive-PX2 and on the host system (Ubuntu 16.04, Driveinstall 5.0.5.0 with Driveworks-0.6, tensorflow version 1.4.1).
But we were not able to cross-compile anything that used this libraries on the host for the Drive-PX2.
This are the steps we have done:
- Compiling libtensorflow_cc.so (and libtensorflow_framwork.so) on the drive-PX2 with the following command (Successfull, also tested with the ‘hello_tf’ example from the tensorflow-webpage):
bazel build -c opt --local_resources 8192,2.0,1.0 --verbose_failures --config=cuda --incompatible_load_argument_is_label=false //tensorflow:libtensorflow_cc.so
- Copy compiled files libtensorflow_cc.so and libtensorflow_framwork.so to the host-PC to the folder <VIBRANTE_PDK>/targetfs/lib/aarch64-linux-gnu
- Copy c_api.h file from <tensorflow_source>/tensorflow/c/c_api.h to <VIBRANTE_PDK>/include/tensorflow/c/c_api.h
Then our cross-compile test with the ‘hello_world’-sample from the driveworks/samples folder:
-modified main.c: Add
printf("Hello from TensorFlow C library version %s\n", TF_Version());
in main()
and
#include <tensorflow/c/c_api.h>
to the include-section
- added
target_link_libraries(${PROJECT_NAME} PRIVATE ${LIBRARIES} tensorflow_cc tensorflow_framework)
to the CMakeLists.txt in the ‘hello_world’ - Folder.
This is the output of the make-command:
Scanning dependencies of target sample_hello_world
[ 70%] Building CXX object src/hello_world/CMakeFiles/sample_hello_world.dir/main.cpp.o
[ 70%] Linking CXX executable sample_hello_world
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_cc.so: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::assign(char const*)@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_cc.so: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_replace_aux(unsigned long, unsigned long, unsigned long, char)@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_framework.so: undefined reference to `std::basic_istream<char, std::char_traits<char> >& std::operator>><char, std::char_traits<char>, std::allocator<char> >(std::basic_istream<char, std::char_traits<char> >&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&)@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_cc.so: undefined reference to `std::__cxx11::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >::~basic_stringstream()@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_framework.so: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::rfind(char, unsigned long) const@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_cc.so: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::reserve(unsigned long)@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_cc.so: undefined reference to `vtable for std::__cxx11::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_cc.so: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::find(char, unsigned long) const@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_framework.so: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::substr(unsigned long, unsigned long) const@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_cc.so: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_replace(unsigned long, unsigned long, char const*, unsigned long)@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_cc.so: undefined reference to `std::__cxx11::basic_stringbuf<char, std::char_traits<char>, std::allocator<char> >::_M_sync(char*, unsigned long, unsigned long)@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_framework.so: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::compare(unsigned long, unsigned long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) const@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_cc.so: undefined reference to `VTT for std::__cxx11::basic_stringstream<char, std::char_traits<char>, std::allocator<char> >@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_framework.so: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::append(char const*)@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_cc.so: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::compare(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) const@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_cc.so: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::find(char const*, unsigned long, unsigned long) const@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_framework.so: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_cc.so: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_erase(unsigned long, unsigned long)@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_cc.so: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_append(char const*, unsigned long)@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_cc.so: undefined reference to `typeinfo for std::__cxx11::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_cc.so: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::compare(unsigned long, unsigned long, char const*) const@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_cc.so: undefined reference to `VTT for std::__cxx11::basic_istringstream<char, std::char_traits<char>, std::allocator<char> >@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_cc.so: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::resize(unsigned long, char)@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_framework.so: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::find_last_of(char const*, unsigned long, unsigned long) const@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_cc.so: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_mutate(unsigned long, unsigned long, char const*, unsigned long)@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_cc.so: undefined reference to `vtable for std::__cxx11::basic_istringstream<char, std::char_traits<char>, std::allocator<char> >@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_framework.so: undefined reference to `std::thread::_M_start_thread(std::shared_ptr<std::thread::_Impl_base>, void (*)())@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_framework.so: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::find_first_of(char const*, unsigned long, unsigned long) const@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_cc.so: undefined reference to `std::__cxx11::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::~basic_ostringstream()@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_framework.so: undefined reference to `std::basic_istream<char, std::char_traits<char> >& std::getline<char, std::char_traits<char>, std::allocator<char> >(std::basic_istream<char, std::char_traits<char> >&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, char)@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_cc.so: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::swap(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&)@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_framework.so: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::find_first_not_of(char const*, unsigned long, unsigned long) const@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_cc.so: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_assign(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_cc.so: undefined reference to `lgammaf@GLIBC_2.23'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_cc.so: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::compare(char const*) const@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_cc.so: undefined reference to `vtable for std::__cxx11::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_framework.so: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_construct(unsigned long, char)@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_cc.so: undefined reference to `std::random_device::_M_init(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_cc.so: undefined reference to `VTT for std::__cxx11::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_cc.so: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_create(unsigned long&, unsigned long)@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_cc.so: undefined reference to `vtable for std::__cxx11::basic_stringbuf<char, std::char_traits<char>, std::allocator<char> >@GLIBCXX_3.4.21'
/home/avlsfr/NVIDIA/Drive/5050L_SDK/DriveSDK/drive-t186ref-linux/targetfs/lib/aarch64-linux-gnu/libtensorflow_cc.so: undefined reference to `lgamma@GLIBC_2.23'
collect2: error: ld returned 1 exit status
src/hello_world/CMakeFiles/sample_hello_world.dir/build.make:107: recipe for target 'src/hello_world/sample_hello_world' failed
make[2]: *** [src/hello_world/sample_hello_world] Error 1
CMakeFiles/Makefile2:2295: recipe for target 'src/hello_world/CMakeFiles/sample_hello_world.dir/all' failed
make[1]: *** [src/hello_world/CMakeFiles/sample_hello_world.dir/all] Error 2
Makefile:127: recipe for target 'all' failed
make: *** [all] Error 2
Any hint how to solve this problem? Any hint how to compile/link tensorflow for cross-compiling?
We also successfully builded the libtensorflow_cc.so on the host-system for the host system, but using this file gives architecture-errors, as expected.
