I am loading a Tensorflow 2 version of EfficientDet D2 from here: http://download.tensorflow.org/models/object_detection/tf2/20200711/efficientdet_d2_coco17_tpu-32.tar.gz
I run the following script:
#!/usr/bin/python3
import tensorflow as tf
import time
from object_detection.utils import label_map_util
from object_detection.utils import visualization_utils as viz_utils
PATH_TO_SAVED_MODEL = "./efficientdet_d2_coco17_tpu-32/saved_model/"
print('Loading model...')
start_time = time.time()
# Load saved model and build the detection function
detect_fn = tf.saved_model.load(PATH_TO_SAVED_MODEL)
end_time = time.time()
elapsed_time = end_time - start_time
print('Done! Took {} seconds'.format(elapsed_time))
However, the performance results is a loading time of more than 13 minutes. This is the output after the command has been executed:
./test.py
2021-07-04 10:58:58.074413: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.10.2
2021-07-04 10:59:05.375568: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.10.2
Loading model...
2021-07-04 11:00:54.337115: I tensorflow/compiler/jit/xla_cpu_device.cc:41] Not creating XLA devices, tf_xla_enable_xla_devices not set
2021-07-04 11:00:54.342226: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcuda.so.1
2021-07-04 11:00:54.347726: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:908] ARM64 does not support NUMA - returning NUMA node zero
2021-07-04 11:00:54.347959: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1720] Found device 0 with properties:
pciBusID: 0000:00:00.0 name: Xavier computeCapability: 7.2
coreClock: 1.377GHz coreCount: 8 deviceMemorySize: 31.17GiB deviceMemoryBandwidth: 82.08GiB/s
2021-07-04 11:00:54.348037: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.10.2
2021-07-04 11:00:54.353788: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcublas.so.10
2021-07-04 11:00:54.354040: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcublasLt.so.10
2021-07-04 11:00:54.358471: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcufft.so.10
2021-07-04 11:00:54.359514: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcurand.so.10
2021-07-04 11:00:54.364904: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcusolver.so.10
2021-07-04 11:00:54.369140: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcusparse.so.10
2021-07-04 11:00:54.369861: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudnn.so.8
2021-07-04 11:00:54.370262: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:908] ARM64 does not support NUMA - returning NUMA node zero
2021-07-04 11:00:54.370843: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:908] ARM64 does not support NUMA - returning NUMA node zero
2021-07-04 11:00:54.371060: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1862] Adding visible gpu devices: 0
2021-07-04 11:00:54.375404: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:908] ARM64 does not support NUMA - returning NUMA node zero
2021-07-04 11:00:54.375623: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1720] Found device 0 with properties:
2021-07-04 11:00:54.375714: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudart.so.10.2
2021-07-04 11:00:54.375823: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcublas.so.10
2021-07-04 11:00:54.375908: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcublasLt.so.10
2021-07-04 11:00:54.376011: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcufft.so.10
2021-07-04 11:00:54.376090: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcurand.so.10
2021-07-04 11:00:54.376167: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcusolver.so.10
2021-07-04 11:00:54.376287: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcusparse.so.10
2021-07-04 11:00:54.376369: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudnn.so.8
2021-07-04 11:00:54.376673: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:908] ARM64 does not support NUMA - returning NUMA node zero
2021-07-04 11:00:54.376972: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:908] ARM64 does not support NUMA - returning NUMA node zero
2021-07-04 11:00:54.377093: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1862] Adding visible gpu devices: 0
2021-07-04 11:05:01.847060: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1261] Device interconnect StreamExecutor with strength 1 edge matrix:
2021-07-04 11:05:01.847174: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1267] 0
2021-07-04 11:05:01.847226: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1280] 0: N
2021-07-04 11:05:01.847710: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:908] ARM64 does not support NUMA - returning NUMA node zero
2021-07-04 11:05:01.848589: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:908] ARM64 does not support NUMA - returning NUMA node zero
2021-07-04 11:05:01.848911: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:908] ARM64 does not support NUMA - returning NUMA node zero
2021-07-04 11:05:01.849096: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1406] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 19271 MB memory) -> physical GPU (device: 0, name: Xavier, pci bus id: 0000:00:00.0, compute capability: 7.2)
2021-07-04 11:05:01.850298: I tensorflow/compiler/jit/xla_gpu_device.cc:99] Not creating XLA devices, tf_xla_enable_xla_devices not set
WARNING:absl:Importing a function (__inference_EfficientDet-D2_layer_call_and_return_conditional_losses_130857) with ops with custom gradients. Will likely fail if a gradient is requested.
WARNING:absl:Importing a function (__inference___call___38449) with ops with custom gradients. Will likely fail if a gradient is requested.
WARNING:absl:Importing a function (__inference_EfficientDet-D2_layer_call_and_return_conditional_losses_145024) with ops with custom gradients. Will likely fail if a gradient is requested.
WARNING:absl:Importing a function (__inference_bifpn_layer_call_and_return_conditional_losses_99017) with ops with custom gradients. Will likely fail if a gradient is requested.
WARNING:absl:Importing a function (__inference_EfficientDet-D2_layer_call_and_return_conditional_losses_139687) with ops with custom gradients. Will likely fail if a gradient is requested.
WARNING:absl:Importing a function (__inference_EfficientDet-D2_layer_call_and_return_conditional_losses_125520) with ops with custom gradients. Will likely fail if a gradient is requested.
WARNING:absl:Importing a function (__inference_bifpn_layer_call_and_return_conditional_losses_101605) with ops with custom gradients. Will likely fail if a gradient is requested.
Done! Took 793.8719098567963 seconds
With the computing power of the Xavier I would expect much better performance? Anybody knows what the cause to this could be?
Note that I have not converted this model to trt using TF-TRT or TensorRT since I have had issues converting it to a onnx-model first and then converting that to TensorRT (some layers that are used in the EfficientDet is not supported) .
Thanks for any help or input!
