TensorRT 5.1.6-1+cuda10.0 jetson nano memory leakage
I tried tensorrt on jetson nano, mobile-yolo-tensorrt
  • jetson-nano-sd-r32.2-2019-07-16.zip, nv-jetson-nano-sd-card-image-0826-r32.2.1.zip
  • tensorrt : 5.1.6.1 + cuda10.0
When I running my program that has tensorrt, cuda library , Program down one day after may be 20 hours later.
memory increases gradually , And my program down one day after
I doubt the tensorrt+cuda memory has leakage problem.
How Can I Fix it???
I used system monitor to monitor memory and swap memory, top viewer.
and I catched log using Valgrind-3.13.0
10:45 52.9 13.2 <-system monitor
10:45 10.241g 1.105g 387324 <-top viewer
10:55 54.1 13.2
10:55 10.242g 1.148g 387324
11:35 58.1 13.2
11:35 10.242g 1.302g 387324
12:00 60.3 13.2
12:00 10.492g 1.396g 387324
13:10 67.1 13.2
13:10 10.742g 1.663g 388564
//////valgrind//////////////
==7980== Memcheck, a memory error detector
==7980== Copyright (C) 2002-2017, and GNU GPL’d, by Julian Seward et al.
==7980== Using Valgrind-3.13.0 and LibVEX; rerun with -h for copyright info
==7980== Command: ./install/runYolov3 --caffemodel=./models/mobilene==7978==
==7978== Process terminating with default action of signal 2 (SIGINT)
==7978== at 0x48CF4D8: raise (raise.c:51)
==7978== by 0x10EC47: ??? (in /bin/dash)
==7978==
==7978== HEAP SUMMARY:
==7978== in use at exit: 3,355 bytes in 73 blocks
==7978== total heap usage: 73 allocs, 0 frees, 3,355 bytes allocated
==7978==
==7978== LEAK SUMMARY:
==7978== definitely lost: 0 bytes in 0 blocks
==7978== indirectly lost: 0 bytes in 0 blocks
==7978== possibly lost: 0 bytes in 0 blocks
==7978== still reachable: 3,355 bytes in 73 blocks
==7978== suppressed: 0 bytes in 0 blocks
==7978== Reachable blocks (those to which a pointer was found) are not shown.
==7978== To see them, rerun with: --leak-check=full --show-leak-kinds=all
==7978==
==7978== For counts of detected and suppressed errors, rerun with: -v
==7978== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 0 from 0)
hread_timedjoin_ex (pthread_join_common.c:89)
==7980== by 0x12D82B: do_video_or_cam(Tn::trtNet&) (in /home/dkai/kmu/install/runYolov3)
==7980== by 0x1297CF: main (in /home/dkai/kmu/install/runYolov3)
==7980==
==7980== HEAP SUMMARY:
==7980== in use at exit: 636,039,319 bytes in 683,513 blocks
==7980== total heap usage: 1,091,271 allocs, 407,758 frees, 966,413,325 bytes allocated
==7980==
==7980== 4 bytes in 1 blocks are possibly lost in loss record 9 of 4,409
==7980== at 0x4844CC8: malloc (vg_replace_malloc.c:299)
==7980== by 0x2E5E035B: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E686ED7: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E691A87: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E69237B: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E7045FB: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E704AA3: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E70505B: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E705683: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E59472B: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E596AA7: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E4EC9C7: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980==
==7980== 4 bytes in 1 blocks are possibly lost in loss record 10 of 4,409
==7980== by 0x2E5BBC23: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E672DD3: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E594743: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E5FC6D3: cuDevicePrimaryCtxRetain (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2839F707: ??? (in /usr/local/cuda-10.0/targets/aarch64-linux/lib/libcudart.so.10.0.166)
==7980==
==7980== 4 bytes in 1 blocks are possibly lost in loss record 11 of 4,409
==7980== by 0x2E4E2617: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E5947E3: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980==
==7980== 4 bytes in 1 blocks are possibly lost in loss record 12 of 4,409
==7980== by 0x2E621FDF: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E6A0CB3: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E510D97: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E5137AF: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E513B2B: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E514377: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E594853: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980==
==7980== 4 bytes in 1 blocks are possibly lost in loss record 13 of 4,409
==7980== by 0x2E6E426F: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E621FFB: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980==
==7980== 4 bytes in 1 blocks are possibly lost in loss record 14 of 4,409
==7980== by 0x2E513C2B: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980==
==7980== 4 bytes in 1 blocks are possibly lost in loss record 15 of 4,409
==7980==
==7980== 4 bytes in 1 blocks are possibly lost in loss record 16 of 4,409
==7980== by 0x2E6E4B73: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E594A7F: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980==
==7980== 4 bytes in 1 blocks are possibly lost in loss record 17 of 4,409
==7980== by 0x2E594C5B: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980==
==7980== 4 bytes in 1 blocks are possibly lost in loss record 18 of 4,409
==7980== by 0x2E5D157F: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E5D24B7: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E5952C7: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980==
==7980== 4 bytes in 1 blocks are possibly lost in loss record 19 of 4,409
==7980== by 0x2E52CF0B: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E5D6103: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E59537B: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980==
==7980== 4 bytes in 1 blocks are possibly lost in loss record 20 of 4,409
==7980== by 0x2E52D047: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E5D615F: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980==
==7980== 4 bytes in 1 blocks are possibly lost in loss record 21 of 4,409
==7980== by 0x2E5932F3: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E5936EB: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E595347: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980==
==7980== 4 bytes in 1 blocks are possibly lost in loss record 22 of 4,409
==7980== by 0x2E4E7F07: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E5A29E3: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E5A1F5B: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E5C4197: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E530BEB: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x283989B3: ??? (in /usr/local/cuda-10.0/targets/aarch64-linux/lib/libcudart.so.10.0.166)
==7980==
==7980== 4 bytes in 1 blocks are possibly lost in loss record 23 of 4,409
==7980== by 0x2E5A366F: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980==
==7980== 4 bytes in 1 blocks are possibly lost in loss record 24 of 4,409
==7980== by 0x2E5BBDBF: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E6D85EB: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E5D2207: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E5C4227: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x101E3103: ??? (in /usr/lib/aarch64-linux-gnu/libcudnn.so.7.3.1)
==7980==
==7980== 4 bytes in 1 blocks are possibly lost in loss record 25 of 4,409
==7980== by 0x2E5BBCC7: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E6D86DF: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980==
==7980== 4 bytes in 1 blocks are possibly lost in loss record 26 of 4,409
==7980== by 0x2E66C48B: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E5CFBFB: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E505FFB: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E60617B: cuStreamCreate (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x101B8F8B: ??? (in /usr/lib/aarch64-linux-gnu/libcudnn.so.7.3.1)
==7980==
==7980== 4 bytes in 1 blocks are possibly lost in loss record 27 of 4,409
==7980== by 0x2E5BBE77: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E4F48DF: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E6003F7: cuMemHostAlloc (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x101F00C7: ??? (in /usr/lib/aarch64-linux-gnu/libcudnn.so.7.3.1)
==7980==
==7980== 4 bytes in 1 blocks are possibly lost in loss record 28 of 4,409
==7980== by 0x2E4F4737: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E4F4C03: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x2E5FFBB3: cuMemAlloc_v2 (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980== by 0x18DCA7: cudart::driverHelper::mallocPtr(unsigned long, void**) (in /home/dkai/kmu/install/runYolov3)
==7980==
==7980== 8 bytes in 2 blocks are possibly lost in loss record 696 of 4,409
==7980== by 0x101EFFC3: ??? (in /usr/lib/aarch64-linux-gnu/libcudnn.so.7.3.1)
==7980==
==7980== 8 bytes in 2 blocks are possibly lost in loss record 697 of 4,409
==7980== by 0x24330BCB: ??? (in /usr/local/cuda-10.0/targets/aarch64-linux/lib/libcublas.so.10.0.166)
==7980==
==7980== 8 bytes in 2 blocks are possibly lost in loss record 698 of 4,409
==7980== by 0x18DDAB: cudart::driverHelper::mallocHost(unsigned long, void**, unsigned int) (in /home/dkai/kmu/install/runYolov3)
==7980==
==7980== 12 bytes in 1 blocks are possibly lost in loss record 704 of 4,409
==7980== by 0x2F38AA0F: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.1.0)
==7980== by 0x2F38256B: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.1.0)
==7980== by 0x2F37FF47: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.1.0)
==7980== by 0x2F38012F: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.1.0)
==7980== by 0x2F3766BF: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.1.0)
==7980== by 0x2F377377: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.1.0)
==7980== by 0x2F3775B7: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.1.0)
==7980== by 0x2F377A37: gpuInfoRunsOn (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.1.0)
==7980== by 0x2E5A2617: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==7980==
==7980== 12 bytes in 1 blocks are possibly lost in loss record 705 of 4,409
==7980== by 0x2F386FFF: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.1.0)
==7980== by 0x2F3871E7: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.1.0)
==7980== by 0x2F37657F: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.1.0)
==7980== by 0x2F376703: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.1.0)
==7980==
==7980== 12 bytes in 1 blocks are possibly lost in loss record 706 of 4,409
==7980== by 0x2F376593: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.1.0)
==7980==
==7980== 12 bytes in 1 blocks are possibly lost in loss record 707 of 4,409
==7980== by 0x2F3765A7: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.1.0)
==7980==
==7980== 12 bytes in 1 blocks are possibly lost in loss record 708 of 4,409
==7980== by 0x2F376727: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.1.0)
==7980==
==7980== 12 bytes in 1 blocks are possibly lost in loss record 709 of 4,409
==7980==
==7980== 12 bytes in 1 blocks are possibly lost in loss record 710 of 4,409
==7980==
==7980== 12 bytes in 1 blocks are possibly lost in loss record 711 of 4,409
==7980== by 0x2F3767E3: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.1.0)
==7980==
==7980== 12 bytes in 1 blocks are possibly lost in loss record 712 of 4,409
==7980==
==7980== 12 bytes in 1 blocks are possibly lost in loss record 713 of 4,409
==7980==
==7980== 12 bytes in 1 blocks are possibly lost in loss record 714 of 4,409
==7980== by 0x2F37680F: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.1.0)
==7980==
==7980== 12 bytes in 1 blocks are possibly lost in loss record 715 of 4,409
==7980==
==7980== 12 bytes in 1 blocks are possibly lost in loss record 716 of 4,409
==7980==
==7980== 12 bytes in 1 blocks are possibly lost in loss record 717 of 4,409
==7980== by 0x2F3768B7: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.1.0)
==7980==
==7980== 12 bytes in 1 blocks are possibly lost in loss record 718 of 4,409
==7980==
==7980== 12 bytes in 1 blocks are possibly lost in loss record 719 of 4,409
==7980==
==7980== 12 bytes in 1 blocks are possibly lost in loss record 720 of 4,409
==7980== by 0x2F3768E3: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.1.0)
==7980==
==7980== 12 bytes in 1 blocks are possibly lost in loss record 721 of 4,409
==7980==
==7980== 12 bytes in 1 blocks are possibly lost in loss record 722 of 4,409
==7980==
==7980== 12 bytes in 1 blocks are possibly lost in loss record 723 of 4,409
==7980== by 0x2F376997: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.1.0)
==7980==
==7980== 12 bytes in 1 blocks are possibly lost in loss record 724 of 4,409
==7980==
==7980== 12 bytes in 1 blocks are possibly lost in loss record 725 of 4,409
==7980==
==7980== 12 bytes in 1 blocks are possibly lost in loss record 726 of 4,409
==7980== by 0x2F3769C7: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.1.0)
==7980==
==7980== 12 bytes in 1 blocks are possibly lost in loss record 727 of 4,409
==7980==
==7980== 12 bytes in 1 blocks are possibly lost in loss record 728 of 4,409
==7980==
==7980== 12 bytes in 1 blocks are possibly lost in loss record 729 of 4,409
==7980== by 0x2F376AA3: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.1.0)
==7980==
==7980== 12 bytes in 1 blocks are possibly lost in loss record 730 of 4,409
==7980==
==7980== 12 bytes in 1 blocks are possibly lost in loss record 731 of 4,409
==7980==
==7980== 12 bytes in 1 blocks are possibly lost in loss record 732 of 4,409
==7980== by 0x2F376ACB: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.1.0)
==7980==
==7980== 12 bytes in 1 blocks are possibly lost in loss record 733 of 4,409
==7980==
==7980== 12 bytes in 1 blocks are possibly lost in loss record 734 of 4,409
memcheck2.txt (1.3 MB)
===Another valgrind leakage log ===
==18626== Memcheck, a memory error detector
==18626== Copyright (C) 2002-2017, and GNU GPL’d, by Julian Seward et al.
==18626== Using Valgrind-3.13.0 and LibVEX; rerun with -h for copyright info
==18626== Command: ./install/runYolov3 --caffemodel=./models/mobilenet_y==18623==
==18623== Process terminating with default action of signal 2 (SIGINT)
==18623== at 0x48B64D8: raise (raise.c:51)
==18623== by 0x10EC47: ??? (in /bin/dash)
==18623==
==18623== HEAP SUMMARY:
==18623== in use at exit: 1,595 bytes in 33 blocks
==18623== total heap usage: 33 allocs, 0 frees, 1,595 bytes allocated
==18623==
==18623== LEAK SUMMARY:
==18623== definitely lost: 0 bytes in 0 blocks
==18623== indirectly lost: 0 bytes in 0 blocks
==18623== possibly lost: 0 bytes in 0 blocks
==18623== still reachable: 1,595 bytes in 33 blocks
==18623== suppressed: 0 bytes in 0 blocks
==18623== Reachable blocks (those to which a pointer was found) are not shown.
==18623== To see them, rerun with: --leak-check=full --show-leak-kinds=all
==18623==
==18623== For counts of detected and suppressed errors, rerun with: -v
==18623== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 0 from 0)
xEB1F06F: std::__basic_file::xsputn_2(char const*, long, char const*, long) (in /usr/lib/aarch64-linux-gnu/libstdc++.so.6.0.25)
==18626== by 0xEB5C1F3: std::basic_filebuf<char, std::char_traits >::xsputn(char const*, long) (in /usr/lib/aarch64-linux-gnu/libstdc++.so.6.0.25)
==18626== by 0xEB7EE2B: std::ostream::write(char const*, long) (in /usr/lib/aarch64-linux-gnu/libstdc++.so.6.0.25)
==18626== by 0x131F6B: Tn::trtNet::saveEngine(std::__cxx11::basic_string<char, std::char_traits, std::allocator >) (in /home/dkai/kmu/install/runYolov3)
==18626== by 0x12994B: main (in /home/dkai/kmu/install/runYolov3)
==18626== Address 0x8015734c is 780 bytes inside a block of size 21,159,992 alloc’d
==18626== at 0x4845A84: operator new(unsigned long) (vg_replace_malloc.c:423)
==18626== by 0x4B84D27: nvinfer1::cudnn::serializeEngine(nvinfer1::rt::Engine const&) (in /usr/lib/aarch64-linux-gnu/libnvinfer.so.5.1.6)
==18626== by 0x131E73: Tn::trtNet::saveEngine(std::__cxx11::basic_string<char, std::char_traits, std::allocator >) (in /home/dkai/kmu/install/runYolov3)
==18626==
==18626==
==18626== Process terminating with default action of signal 2 (SIGINT)
==18626== at 0x488C320: __pthread_timedjoin_ex (pthread_join_common.c:89)
==18626== by 0x12FF9F: do_video_or_cam(Tn::trtNet&) (in /home/dkai/kmu/install/runYolov3)
==18626== by 0x129EFB: main (in /home/dkai/kmu/install/runYolov3)
==18626==
==18626== HEAP SUMMARY:
==18626== in use at exit: 724,028,912 bytes in 745,307 blocks
==18626== total heap usage: 2,750,033 allocs, 2,004,726 frees, 5,542,656,930 bytes allocated
==18626==
==18626== 4 bytes in 1 blocks are possibly lost in loss record 12 of 4,790
==18626== at 0x4844CC8: malloc (vg_replace_malloc.c:299)
==18626== by 0x3223B51B: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x322E2097: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x322ECC47: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x322ED53B: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x3235F7BB: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x3235FC63: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x3236021B: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x32360843: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x321EF77B: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x321F1AF7: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x32147A17: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626==
==18626== 4 bytes in 1 blocks are possibly lost in loss record 13 of 4,790
==18626== by 0x32216DE3: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x322CDF93: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x321EF793: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x32257893: cuDevicePrimaryCtxRetain (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x2B62E707: ??? (in /usr/local/cuda-10.0/targets/aarch64-linux/lib/libcudart.so.10.0.326)
==18626==
==18626== 4 bytes in 1 blocks are possibly lost in loss record 14 of 4,790
==18626== by 0x3213D667: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x321EF833: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626==
==18626== 4 bytes in 1 blocks are possibly lost in loss record 15 of 4,790
==18626== by 0x3227D19F: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x322FBE73: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x3216BDE7: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x3216E7FF: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x3216EB7B: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x3216F3C7: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x321EF8A3: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626==
==18626== 4 bytes in 1 blocks are possibly lost in loss record 16 of 4,790
==18626== by 0x3233F42F: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x3227D1BB: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626==
==18626== 4 bytes in 1 blocks are possibly lost in loss record 17 of 4,790
==18626== by 0x3216EC7B: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626==
==18626== 4 bytes in 1 blocks are possibly lost in loss record 18 of 4,790
==18626==
==18626== 4 bytes in 1 blocks are possibly lost in loss record 19 of 4,790
==18626== by 0x3233FD33: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x321EFACF: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626==
==18626== 4 bytes in 1 blocks are possibly lost in loss record 20 of 4,790
==18626== by 0x321EFCAB: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626==
==18626== 4 bytes in 1 blocks are possibly lost in loss record 21 of 4,790
==18626== by 0x3222C73F: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x3222D677: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x321F0317: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626==
==18626== 4 bytes in 1 blocks are possibly lost in loss record 22 of 4,790
==18626== by 0x32187F5B: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x322312C3: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x321F03CB: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626==
==18626== 4 bytes in 1 blocks are possibly lost in loss record 23 of 4,790
==18626== by 0x32188097: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x3223131F: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626==
==18626== 4 bytes in 1 blocks are possibly lost in loss record 24 of 4,790
==18626== by 0x321EE343: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x321EE73B: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x321F0397: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626==
==18626== 4 bytes in 1 blocks are possibly lost in loss record 25 of 4,790
==18626== by 0x32142F57: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x321FDBA3: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x321FD11B: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x3221F357: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x3218BC3B: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x2B6279B3: ??? (in /usr/local/cuda-10.0/targets/aarch64-linux/lib/libcudart.so.10.0.326)
==18626==
==18626== 4 bytes in 1 blocks are possibly lost in loss record 26 of 4,790
==18626== by 0x32216F7F: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x323337AB: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x3222D3C7: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x3221F3E7: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626==
==18626== 4 bytes in 1 blocks are possibly lost in loss record 27 of 4,790
==18626== by 0x32216E87: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x3233389F: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626==
==18626== 4 bytes in 1 blocks are possibly lost in loss record 28 of 4,790
==18626== by 0x322C764B: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x3222ADBB: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x3216104B: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x3226133B: cuStreamCreate (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0xFC5FE8B: ??? (in /usr/lib/aarch64-linux-gnu/libcudnn.so.7.5.0)
==18626==
==18626== 4 bytes in 1 blocks are possibly lost in loss record 29 of 4,790
==18626== by 0x32217037: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x3214F92F: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x3225B5B7: cuMemHostAlloc (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0xFC96FC7: ??? (in /usr/lib/aarch64-linux-gnu/libcudnn.so.7.5.0)
==18626==
==18626== 4 bytes in 1 blocks are possibly lost in loss record 30 of 4,790
==18626== by 0x321FE82F: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x26609993: ??? (in /usr/local/cuda-10.0/targets/aarch64-linux/lib/libcublas.so.10.0.326)
==18626==
==18626== 4 bytes in 1 blocks are possibly lost in loss record 31 of 4,790
==18626== by 0x3214F787: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x3214FC53: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x3225AD73: cuMemAlloc_v2 (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x26616853: ??? (in /usr/local/cuda-10.0/targets/aarch64-linux/lib/libcublas.so.10.0.326)
==18626==
==18626== 4 bytes in 1 blocks are possibly lost in loss record 32 of 4,790
==18626== by 0x18F5BF: cudart::driverHelper::mallocPtr(unsigned long, void**) (in /home/dkai/kmu/install/runYolov3)
==18626==
==18626== 8 bytes in 1 blocks are possibly lost in loss record 693 of 4,790
==18626== at 0x4847084: memalign (vg_replace_malloc.c:857)
==18626== by 0x48471AB: posix_memalign (vg_replace_malloc.c:1020)
==18626== by 0xE94A567: cv::fastMalloc(unsigned long) (in /usr/lib/libopencv_core.so.3.3.1)
==18626== by 0xE8D5017: cv::String::allocate(unsigned long) (in /usr/lib/libopencv_core.so.3.3.1)
==18626== by 0xDED1B17: cv::BmpDecoder::BmpDecoder() (in /usr/lib/libopencv_imgcodecs.so.3.3.1)
==18626== by 0xDEBCDDB: cv::ImageCodecInitializer::ImageCodecInitializer() (in /usr/lib/libopencv_imgcodecs.so.3.3.1)
==18626== by 0xDEB5D5F: _GLOBAL__sub_I_loadsave.cpp (in /usr/lib/libopencv_imgcodecs.so.3.3.1)
==18626== by 0x400D8E3: call_init.part.0 (dl-init.c:72)
==18626== by 0x400D9E7: call_init (dl-init.c:118)
==18626== by 0x400D9E7: _dl_init (dl-init.c:119)
==18626== by 0x4001243: ??? (in /lib/aarch64-linux-gnu/ld-2.27.so)
==18626==
==18626== 8 bytes in 1 blocks are possibly lost in loss record 694 of 4,790
==18626== by 0xDECC35B: cv::JpegDecoder::JpegDecoder() (in /usr/lib/libopencv_imgcodecs.so.3.3.1)
==18626== by 0xDEBCFDB: cv::ImageCodecInitializer::ImageCodecInitializer() (in /usr/lib/libopencv_imgcodecs.so.3.3.1)
==18626==
==18626== 8 bytes in 2 blocks are possibly lost in loss record 695 of 4,790
==18626== by 0xFC96EC3: ??? (in /usr/lib/aarch64-linux-gnu/libcudnn.so.7.5.0)
==18626==
==18626== 8 bytes in 2 blocks are possibly lost in loss record 696 of 4,790
==18626== by 0x18F6C3: cudart::driverHelper::mallocHost(unsigned long, void**, unsigned int) (in /home/dkai/kmu/install/runYolov3)
==18626==
==18626== 12 bytes in 1 blocks are possibly lost in loss record 700 of 4,790
==18626== by 0xDED22EF: cv::HdrDecoder::HdrDecoder() (in /usr/lib/libopencv_imgcodecs.so.3.3.1)
==18626== by 0xDEBCEDB: cv::ImageCodecInitializer::ImageCodecInitializer() (in /usr/lib/libopencv_imgcodecs.so.3.3.1)
==18626==
==18626== 12 bytes in 1 blocks are possibly lost in loss record 701 of 4,790
==18626== by 0xDED72B7: cv::SunRasterDecoder::SunRasterDecoder() (in /usr/lib/libopencv_imgcodecs.so.3.3.1)
==18626== by 0xDEBD1DB: cv::ImageCodecInitializer::ImageCodecInitializer() (in /usr/lib/libopencv_imgcodecs.so.3.3.1)
==18626==
==18626== 12 bytes in 1 blocks are possibly lost in loss record 702 of 4,790
==18626== by 0x32FE6A0F: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.2.0)
==18626== by 0x32FDE56B: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.2.0)
==18626== by 0x32FDBF47: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.2.0)
==18626== by 0x32FDC12F: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.2.0)
==18626== by 0x32FD26BF: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.2.0)
==18626== by 0x32FD3377: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.2.0)
==18626== by 0x32FD35B7: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.2.0)
==18626== by 0x32FD3A37: gpuInfoRunsOn (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.2.0)
==18626== by 0x321FD7D7: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626==
==18626== 12 bytes in 1 blocks are possibly lost in loss record 703 of 4,790
==18626== by 0x32FE2FFF: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.2.0)
==18626== by 0x32FE31E7: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.2.0)
==18626== by 0x32FD257F: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.2.0)
==18626== by 0x32FD2703: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.2.0)
==18626==
==18626== 12 bytes in 1 blocks are possibly lost in loss record 704 of 4,790
==18626== by 0x32FD2593: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.2.0)
==18626==
==18626== 12 bytes in 1 blocks are possibly lost in loss record 705 of 4,790
==18626== by 0x32FD25A7: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.2.0)
==18626==
==18626== 12 bytes in 1 blocks are possibly lost in loss record 706 of 4,790
==18626== by 0x32FD2727: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.2.0)
==18626==
==18626== 12 bytes in 1 blocks are possibly lost in loss record 707 of 4,790
==18626==
==18626== 12 bytes in 1 blocks are possibly lost in loss record 708 of 4,790
==18626==
==18626== 12 bytes in 1 blocks are possibly lost in loss record 709 of 4,790
==18626== by 0x32FD27E3: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.2.0)
==18626==
==18626== 12 bytes in 1 blocks are possibly lost in loss record 710 of 4,790
==18626==
==18626== 12 bytes in 1 blocks are possibly lost in loss record 711 of 4,790
==18626==
==18626== 12 bytes in 1 blocks are possibly lost in loss record 712 of 4,790
==18626== by 0x32FD280F: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.2.0)
==18626==
==18626== 12 bytes in 1 blocks are possibly lost in loss record 713 of 4,790
==18626==
==18626== 12 bytes in 1 blocks are possibly lost in loss record 714 of 4,790
==18626==
==18626== 12 bytes in 1 blocks are possibly lost in loss record 715 of 4,790
==18626== by 0x32FD28B7: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.2.0)
==18626==
==18626== 12 bytes in 1 blocks are possibly lost in loss record 716 of 4,790
==18626==
==18626== 12 bytes in 1 blocks are possibly lost in loss record 717 of 4,790
==18626==
==18626== 12 bytes in 1 blocks are possibly lost in loss record 718 of 4,790
==18626== by 0x32FD28E3: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.2.0)
==18626==
==18626== 12 bytes in 1 blocks are possibly lost in loss record 719 of 4,790
==18626==
==18626== 12 bytes in 1 blocks are possibly lost in loss record 720 of 4,790
==18626==
==18626== 12 bytes in 1 blocks are possibly lost in loss record 721 of 4,790
==18626== by 0x32FD2997: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.2.0)
==18626==
==18626== 12 bytes in 1 blocks are possibly lost in loss record 722 of 4,790
==18626==
==18626== 12 bytes in 1 blocks are possibly lost in loss record 723 of 4,790
==18626==
==18626== 12 bytes in 1 blocks are possibly lost in loss record 724 of 4,790
==18626== by 0x32FD29C7: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.2.0)
==18626==
==18626== 12 bytes in 1 blocks are possibly lost in loss record 725 of 4,790
==18626==
==18626== 12 bytes in 1 blocks are possibly lost in loss record 726 of 4,790
==18626==
==18626== 12 bytes in 1 blocks are possibly lost in loss record 727 of 4,790
==18626== by 0x32FD2AA3: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.32.2.0)
==18626==
==18626== 12 bytes in 1 blocks are possibly lost in loss record 728 of 4,790
valgrid log huge so file cut
last tailing log
==18626== by 0x322ED237: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626==
==18626== 235,416 bytes in 1,731 blocks are possibly lost in loss record 4,704 of 4,790
==18626== at 0x4846D54: calloc (vg_replace_malloc.c:711)
==18626== by 0x32292E77: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x322ED427: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626==
==18626== 235,416 bytes in 1,731 blocks are possibly lost in loss record 4,705 of 4,790
==18626== by 0x3223C457: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626== by 0x322ED69F: ??? (in /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1)
==18626==
==18626== 274,856 bytes in 2,021 blocks are possibly lost in loss record 4,713 of 4,790
==18626== by 0xFC8A003: ??? (in /usr/lib/aarch64-linux-gnu/libcudnn.so.7.5.0)
==18626==
==18626== 274,856 bytes in 2,021 blocks are possibly lost in loss record 4,714 of 4,790
==18626==
==18626== 274,856 bytes in 2,021 blocks are possibly lost in loss record 4,715 of 4,790
==18626==
==18626== 21,159,992 bytes in 1 blocks are possibly lost in loss record 4,782 of 4,790
==18626==
==18626== LEAK SUMMARY:
==18626== definitely lost: 88 bytes in 2 blocks
==18626== indirectly lost: 0 bytes in 0 blocks
==18626== possibly lost: 23,677,468 bytes in 18,990 blocks
==18626== still reachable: 700,258,732 bytes in 725,878 blocks
==18626== of which reachable via heuristic:
==18626== stdstring : 53,006 bytes in 876 blocks
==18626== length64 : 1,384 bytes in 22 blocks
==18626== newarray : 3,208 bytes in 26 blocks
==18626== suppressed: 0 bytes in 0 blocks
==18626== Reachable blocks (those to which a pointer was found) are not shown.
==18626== To see them, rerun with: --leak-check=full --show-leak-kinds=all
==18626==
==18626== For counts of detected and suppressed errors, rerun with: -v
==18626== Use --track-origins=yes to see where uninitialised values come from
==18626== ERROR SUMMARY: 1106 errors from 1106 contexts (suppressed: 0 from 0)
