Software versions:
CUDA: 10.2/11.4
TensorRT: 8.0.1.6/8.4.0.11
Valgrind: 3.19.0
Problem description
We use valgrind to test memory leaks on our programs, and valgrind reports 72704 bytes of memory leakage, the problem is caused by libnvrtc.so.
Here is a minimal example to reproduce the problem. This small example just dlopen the shared library and close it immediately.
#include <cstdio>
#include <dlfcn.h>
int main() {
void* handle = dlopen("/usr/local/cuda/targets/aarch64-linux/lib/libnvrtc.so", RTLD_NOW);
if (!handle) {
fprintf(stderr, "load failed");
return -2;
dlclose(handle);
and compile using
g++ main.cpp -o main -ldl
and run valgrind memory leak check
valgrind --tool=memcheck --leak-check=full --keep-debuginfo=yes -- ./main
The result is
==451089== 72,704 bytes in 1 blocks are definitely lost in loss record 6 of 6
==451089== at 0x4849D8C: malloc (in /usr/lib/aarch64-linux-gnu/valgrind/vgpreload_memcheck-arm64-linux.so)
==451089== by 0x4FCD33B: ??? (in /usr/local/cuda-11.4/targets/aarch64-linux/lib/libnvrtc.so.11.4.166)
==451089==
==451089== LEAK SUMMARY:
==451089== definitely lost: 72,704 bytes in 1 blocks
==451089== indirectly lost: 0 bytes in 0 blocks
==451089== possibly lost: 0 bytes in 0 blocks
==451089== still reachable: 3,189 bytes in 10 blocks
==451089== suppressed: 0 bytes in 0 blocks
==451089== Reachable blocks (those to which a pointer was found) are not shown.
==451089== To see them, rerun with: --leak-check=full --show-leak-kinds=all
