Any idea when we might get a Python API for TensorRT? I have some things I’d like to try, currently running in TensorRT 5 on a P4000, and I’d like to see how they perform with fp16 on the AGX Xavier.
Thanks,
-Randy
Thanks,
-Randy
TensorRT Python API doesn’t support Jetson yet.
But you can use the python parser as an alternative.
1. Python → [Wrapper] → C++ inference
2. TensorFlow-TensorRT
According to Jetpack 4.2 webpage (https://developer.nvidia.com/embedded/jetpack):
So, is this Python API what we need to do now, instead of “trtexec” command line in terminal? I’d like to accomplish the benchmarks shown here: https://developer.nvidia.com/embedded/jetson-agx-xavier-dl-inference-benchmarks
But this page just shows that you use, for example:
./trtexec --avgRuns=100 --deploy=resnet50.prototxt --int8 --batch=8 --iterations=10000 --output=prob --useSpinWait
I’ve tried trtexec with and without the ./ , and neither are recognized. I’ve flashed Jetpack 4.2 on my Jetson AGX Xavier. And I can confirm Cuda, cuDNN, and TensorRT by using dpkg -l | grep XXXX
Is there a new webpage documenting this (the Python API) that I missed? Thank you!
To answer my own question, there is indeed documentation of the Python API: TensorRT — NVIDIA TensorRT Standard Python API Documentation 8.4.3 documentation
