Description
a simple audio classifier model. First extracts Mel spectrogram with torchaudio on GPU. Second do the model inference on the same GPU, but get the wrong result.
it is strange that if I extract the Mel spectrogram on the CPU and inference on GPU, the result is correct.
HERE is my code:
def wav_to_frames(wave_data, win_len=int(16000 * 6.5)):
num_frames = round(len(wave_data) / win_len)
frame_len, wave_len = num_frames * win_len, len(wave_data)
if frame_len > wave_len:
x = F.pad(wave_data, (0, frame_len - wave_len))
elif frame_len < wave_len:
x = wave_data[:frame_len]
else:
x = wave_data
return x.view(-1, 1, win_len)
def torchaudio_extract(waveform):
torchaudio_melspec = torchaudio.transforms.MelSpectrogram(
sample_rate=16000,
n_fft=512,
win_length=512,
hop_length=160,
center=True,
pad_mode="reflect",
power=2.0,
norm='slaney',
onesided=True,
n_mels=64,
).to(torch.device('cuda'))(waveform)
return torchaudio_melspec.transpose(1, 2)
classTRTGPUdev():
def __init__(self, model_path, onnx_path=None):
self.TRT_LOGGER = trt.Logger(trt.Logger.WARNING)
self.engine = self.get_engine(model_path)
self.context = self.engine.create_execution_context()
self.inputs, self.outputs, self.bindings, self.stream = self.allocate_buffers()
def allocate_buffers(self):
inputs, outputs, bindings = [], [], []
stream = cuda.Stream()
for binding in self.engine:
size = trt.volume(self.engine.get_binding_shape(binding)) * self.engine.max_batch_size
trt_dtype = trt.nptype(self.engine.get_binding_dtype(binding))
host_mem = cuda.pagelocked_empty(size, trt_dtype)
device_mem = cuda.mem_alloc(host_mem.nbytes)
bindings.append(int(device_mem))
if self.engine.binding_is_input(binding):
inputs.append(HostDeviceMem(host_mem, device_mem))
else:
outputs.append(HostDeviceMem(host_mem, device_mem))
return inputs, outputs, bindings, stream
def get_engine(self, trt_path):
with open(trt_path, "rb") as f, trt.Runtime(self.TRT_LOGGER) as runtime:
return runtime.deserialize_cuda_engine(f.read())
def do_inference_v2(self):
[cuda.memcpy_htod_async(inp.device, inp.host, self.stream) for inp in self.inputs]
self.context.execute_async_v2(bindings=self.bindings, stream_handle=self.stream.handle)
[cuda.memcpy_dtoh_async(out.host, out.device, self.stream) for out in self.outputs]
self.stream.synchronize()
return [out.host for out in self.outputs]
def trt_engine(self, audio_path):
# 1. move data to GPU
wave_data, sr = torchaudio.load(audio_path)
wave_data = wave_data.to(torch.device('cuda'))
wavs = wav_to_frames(wave_data[0], int(6.5 * 16000))
# 2. extract features with torchaudio on GPU
feats = [torchaudio_extract(i).reshape(1, 1, 651, 64) for i in waves]
# 3. do inference with trt
result, msg = [], []
for index, data in enumerate(feats):
feed_data = data.cpu().detach().numpy()
self.inputs[0].host = feed_data
trt_outputs = self.do_inference_v2()
if trt_outputs[0][1] > 0.8 and index < 6:
msg.append(self.time_tagging[index])
result.append(copy.deepcopy(trt_outputs[0]))
return result
result :
[01/06/2022-17:51:41] [TRT] [W] TensorRT was linked against cuBLAS/cuBLAS LT 11.6.3 but loaded cuBLAS/cuBLAS LT 11.5.1
[01/06/2022-17:51:42] [TRT] [W] TensorRT was linked against cuDNN 8.2.1 but loaded cuDNN 8.2.0
[01/06/2022-17:51:42] [TRT] [W] TensorRT was linked against cuBLAS/cuBLAS LT 11.6.3 but loaded cuBLAS/cuBLAS LT 11.5.1
[01/06/2022-17:51:48] [TRT] [E] 1: [scaleRunner.cpp::execute::144] Error Code 1: Cuda Runtime (invalid resource handle)
trt: [array([0., 0.], dtype=float32), array([0., 0.], dtype=float32), array([0., 0.], dtype=float32)] []
BUT when I extract feature on CPU, just change the code .to(torch.device(‘cuda’)) to .to(torch.device(‘cpu’)) will get the correct result as the follow:
[01/06/2022-18:18:46] [TRT] [W] TensorRT was linked against cuBLAS/cuBLAS LT 11.6.3 but loaded cuBLAS/cuBLAS LT 11.5.1
[01/06/2022-18:18:46] [TRT] [W] TensorRT was linked against cuDNN 8.2.1 but loaded cuDNN 8.2.0
trt: [array([9.9998915e-01, 1.1265278e-05], dtype=float32), array([0.9989116 , 0.00110829], dtype=float32), array([9.9990976e-01, 8.9466572e-05], dtype=float32)] []
Environment
TensorRT Version: 8.2.1
GPU Type: Tesla P100-PCIE-16GB
Nvidia Driver Version: 450.80.02
CUDA Version: 11.0
CUDNN Version:
Operating System + Version: Centos
Python Version (if applicable): 3.6
PyTorch Version (if applicable): 1.10 , torchaudio:0.10.1
So, What went wrong or how should I fix it?
