Description
I am trying to optimise my Mask-RCNN model using the ONNX parser. For this, I converted my model from h5 to pb (frozen graph): resnet50-coco-epoch1.pb
Next, I converted this pb file to ONNX model: resnet50-coco-epoch1.onnx.
During this step, I had to explicitly mention the input layer dims but not for the outputs:
$ python -m tf2onnx.convert --input '/content/resnet50-coco-epoch1.pb' --inputs input_image:0[2,480,480,3] --outputs mrcnn_class/Reshape:0 --output resnet50-imagenet-epoch5.onnx --opset 12
Even though I got the model, I noticed that its outputs still have unclear dimensions.
Next, I try to generate a tensorrt engine using
onnx_path = "resnet50-coco-epoch1.onnx"
batch_size = 1
model = ModelProto()
with open(onnx_path, "rb") as f:
model.ParseFromString(f.read())
d0 = model.graph.input[0].type.tensor_type.shape.dim[1].dim_value
d1 = model.graph.input[0].type.tensor_type.shape.dim[2].dim_value
d2 = model.graph.input[0].type.tensor_type.shape.dim[3].dim_value
shape = [batch_size , d0, d1 ,d2]
engine = eng.build_engine(onnx_path, shape= shape)
eng.save_engine(engine, engine_name)
But I get the error:
[TensorRT] ERROR: Parameter check failed at: ../builder/Network.cpp::addInput::671, condition: isValidDims(dims, hasImplicitBatchDimension())
[TensorRT] ERROR: Network must have at least one output
On going through past discussions, I noticed that I had to specify network output manually. On doing so,
network.mark_output(network.get_layer(network.num_layers - 1).get_output(0))
I get the error:
False
python3: ../builder/Network.cpp:863: virtual nvinfer1::ILayer* nvinfer1::Network::getLayer(int) const: Assertion `layerIndex >= 0' failed.
Aborted
Any help is highly appreciated 🤠.
Environment
TensorRT Version: ‘6.0.1.10’
GPU Type: NVIDIA JETSON Xavier AGX inbuilt CUDA cores
L4T info: # R32 (release), REVISION: 3.1, GCID: 18186506, BOARD: t186ref, EABI: aarch64, DATE: Tue Dec 10 07:03:07 UTC 2019
Nvidia Driver Version:
CUDA Version: 10.0
CUDNN Version: 7.6.3
Operating System + Version: Ubuntu 18.04.5 LTS
Python Version (if applicable): 3.6.9
TensorFlow Version (if applicable): 1.15-gpu
Baremetal or Container (if container which image + tag): Baremetal
Steps To Reproduce
Obtain the onnx model using the google collaboratory notebook HERE
