When I use Python to call the tensorrt model for reasoning, I get an error prompt,My code is as follows:
import tensorrt as trt
import pycuda.driver as cuda
import pycuda.autoinit
from torchvision import transforms
import numpy as np
from PIL import Image
import time
import argparse
def loadEngine2TensorRT(filepath):
G_LOGGER = trt.Logger(trt.Logger.WARNING)
# 反序列化引擎
with open(filepath, “rb”) as f, trt.Runtime(G_LOGGER) as runtime:
engine = runtime.deserialize_cuda_engine(f.read())
return engine
def do_inference(engine, batch_size, input, output_shape):
context = engine.create_execution_context()
output = np.empty([1,12600,16], dtype=np.float32)#output_shape
# 分配内存
d_input = cuda.mem_alloc(1 * input.size * input.dtype.itemsize)
d_output = cuda.mem_alloc(1 * output.size * output.dtype.itemsize)
bindings = [int(d_input), int(d_output)]
# pycuda操作缓冲区
stream = cuda.Stream()
# 将输入数据放入device
cuda.memcpy_htod_async(d_input, input, stream)
start = time.time()
# 执行模型
context.execute_async(batch_size, bindings, stream.handle, None)
# 将预测结果从从缓冲区取出
cuda.memcpy_dtoh_async(output, d_output, stream)
end = time.time()
# 线程同步
stream.synchronize()
print("\nTensorRT {} test:".format(engine_path.split('/')[-1].split('.')[0]))
print("trt-output:", output.sum())
print("time cost:", end - start)
def get_shape(engine):
li =
for binding in engine:
if engine.binding_is_input(binding):#input (1, 3, 480, 640)
input_shape = engine.get_binding_shape(binding)
else:
output_shape= engine.get_binding_shape(binding)
li.append(output_shape)
return input_shape, li#,output_shape1,output_shape2
if name == “main”:
parser = argparse.ArgumentParser(description = “TensorRT do inference”)
parser.add_argument(“–batch_size”, type=int, default=1, help=‘batch_size’)
parser.add_argument(“–img_path”, type=str, default=‘zqj.jpg’, help=‘cache_file’)
parser.add_argument(“–engine_file_path”, type=str, default=‘torch_retina7.trt’, help=‘engine_file_path’)#default = test.engine
args = parser.parse_args()
engine_path = args.engine_file_path
engine = loadEngine2TensorRT(engine_path)
img = Image.open(args.img_path)
input_shape, output_shape = get_shape(engine)
print('output_shape:',output_shape[0])
transform = transforms.Compose([
transforms.Resize([input_shape[1], input_shape[2]]), # [h,w]
transforms.ToTensor()
img = transform(img).unsqueeze(0)
img = img.numpy()
do_inference(engine, args.batch_size, img, output_shape[0])
