issue: I am trying to install tensorrt 8.2.2 and the following file seems to be missing. I removed the tag and OS and placed the correct ones.
“/var/nv-tensorrt-local-repo-${os}-${tag}/*-keyring.gpg /usr/share/keyrings/” . I followed this document to upgrade tensorrt.
Environment
TensorRT Version: 8.2.2 CUDA Version: 10.2 Python Version (if applicable): 3.6.9 PyTorch Version (if applicable): 1.8.0
We recommend you to please use the latest TensorRT version for better performance and stability.
Could you please share with us the error you’re facing?
You can also try the TensorRT NGC container to avoid setup related issues.
The error was “/var/nv-tensorrt-local-repo-${os}-${tag}/*-keyring.gpg /usr/share/keyrings/” is not found.
I will now try to install the latest version of the Tensorrt.
