TensorRT Version: 5.1.5.0
GPU Type: Tesla T4
Nvidia Driver Version: 418.87.01
CUDA Version: 10.1.243
CUDNN Version: 7.6.3
Python Version (if applicable): 3.7.4
TensorFlow Version (if applicable):1.14.1
Operating System + Version: Ubuntu 16.04.6 LTS (GNU/Linux 4.4.0-142-generic x86_64)
external/org_tensorflow/tensorflow/compiler/tf2tensorrt/kernels/trt_engine_op.cc:632] Building a new TensorRT engine for TRTEngineOp_0 input shapes: [[1,168,512]]
external/org_tensorflow/tensorflow/compiler/tf2tensorrt/utils/trt_logger.cc:37] DefaultLogger Tensor DataType is determined at build time for tensors not marked as input or output.
external/org_tensorflow/tensorflow/compiler/tf2tensorrt/convert/convert_nodes.cc:1467] Quantization range was not found for Tacotron_model/inference/encoder_convolutions/conv_layer_1_encoder_convolutions/conv1d/conv1d. This is okay if TensorRT does not need the range (e.g. due to node fusion).
external/org_tensorflow/tensorflow/compiler/tf2tensorrt/convert/convert_nodes.cc:1467] Quantization range was not found for (Unnamed ITensor* 6). This is okay if TensorRT does not need the range (e.g. due to node fusion).
external/org_tensorflow/tensorflow/compiler/tf2tensorrt/convert/convert_nodes.cc:1467] Quantization range was not found for Tacotron_model/inference/encoder_convolutions/conv_layer_1_encoder_convolutions/conv1d/conv1d/ExpandDims. This
