Environment Overview
GPU: NVIDIA RTX PRO 2000 Blackwell
CUDA: 13.2 (required by driver 596.36)
cuDNN: 9.x
TensorRT: 10.x
TensorRT‑LLM: latest public release
OS: Windows 11 + WSL2 Ubuntu 22.04
Python: 3.10 / 3.11
Triton Inference Server: open-source build
We attempted multiple TensorRT‑LLM installation and execution paths (Python API, C++ build, engine generation, Triton backend). All attempts failed.
1. Python API Import Errors
ModuleNotFoundError: No module named 'tensorrt_llm.bindings' -
ImportError: libnvinfer.so: cannot open shared object file -
ImportError: cannot import name 'Mapping' from 'collections'
Indicates missing or incompatible TensorRT‑LLM bindings and ABI mismatch.
2. Engine Builder Failures
FP8/BF16 kernel generation crashes
Unsupported kernel errors for Blackwell
RuntimeError: Failed to build TensorRT engine
Suggests incomplete kernel support for Blackwell architecture.
3. CUDA / cuDNN / TensorRT Compatibility Issues
CUDA 13.2 not recognized by TensorRT‑LLM
cuDNN 9.x kernel mismatch
TensorRT 10.x shared library conflicts
Likely version matrix misalignment for Blackwell GPUs.
4. Triton Backend Failures
Backend unable to load TensorRT‑LLM engine
Model repository validation failures
Runtime crashes during warmup
Indicates backend instability with TensorRT‑LLM on RTX PRO 2000.
Request to NVIDIA Engineering
We kindly request clarification on:
Is TensorRT‑LLM currently compatible with CUDA 13.x?
Is TensorRT‑LLM fully supported on RTX PRO 2000 Blackwell?
Which versions of CUDA, cuDNN, TensorRT, and TensorRT‑LLM are required?
Are there known limitations or pending updates for Blackwell support?
Is there an internal build or patch available for TensorRT‑LLM on Blackwell GPUs?
We can provide full logs and reproduction steps if needed.
Thank you,
Vidmantas
