TensorRT model cannot be built when at some layer's of the model, the output of Conv2D's height and/or width is odd
Hi Nvidia,
There is a bug in TensorRT. When at some stage in a layer of the model, the output of conv2d’s height or width becomes odd and not even, the last dense layer causes TensorRT to crash at the build stage when I run trt.utils.uff_to_trt_engine.
Here is the code:
config = {
    'x_width': 256,
    'x_height': 40,
    'num_channels': 1,
    'num_classes': 3,
def D(x, is_training = False, reuse = True):
    with tf.variable_scope('Disc', reuse = reuse) as scope:
        conv1 = tf.layers.conv2d(x, 32, [5, 5],
                                 strides = [2, 2],
                                 padding = 'same',
                                 data_format = 'channels_first')
        lrelu1 = tf.maximum(0.2 * conv1, conv1) # <= WON'T CRASH if you use this as output when building TensorRT
        # layer2
        conv2 = tf.layers.conv2d(lrelu1, 64, [3, 3],
                                 strides = [2, 2],
                                 padding = 'same',
        batch_norm2 = tf.layers.batch_normalization(conv2, training = is_training, axis = 1)
        lrelu2 = tf.maximum(0.2 * batch_norm2, batch_norm2) # <= WON'T CRASH if you use this as output when building TensorRT
        # layer3
        conv3 = tf.layers.conv2d(lrelu2, 128, [2, 2],
                                 strides = [2, 2],
                                 padding = 'same',
        batch_norm3 = tf.layers.batch_normalization(conv3, training = is_training, axis = 1)
        lrelu3 = tf.maximum(0.2 * batch_norm3, batch_norm3) # <= WON'T CRASH if you use this as output when building TensorRT
        # layer4
        conv4 = tf.layers.conv2d(lrelu3, 256, [2, 2],
                                 strides = [2, 2],
                                 padding = 'same',
        lrelu4 = tf.maximum(0.2 * conv4, conv4) # <= WON'T CRASH if you use this as output when building TensorRT
        # layer 5
        flatten_length = lrelu4.get_shape().as_list()[1] * \
                         lrelu4.get_shape().as_list()[2] * lrelu4.get_shape().as_list()[3]
        flatten5 = tf.reshape(lrelu4, (-1, flatten_length)) # <= WON'T CRASH if you use this as output when building TensorRT
        fc5 = tf.layers.dense(flatten5, config['num_classes'])
        output = tf.nn.softmax(fc5) # <= CRASHES if you use this as output when building TensorRT
        assert output.get_shape()[1:] == [config['num_classes']]
        return output
Please pay attention to comments in the code.
If you change config[‘x_height’] to 48. Then, it won’t crash and can build the model!
When config[‘x_height’]=40, the output of lrelu3 becomes [?, 128, 5, 32] (the output’s height is odd). This doesn’t cause problem if you use this output to build the tensorRT model. But, when you use the output of last layer, it crashes.
When config[‘x_height’]=48, the output height of all layers is even. So, you can build TensorRT model without any drama!
I tested this with a few other types of architectures and got the same result…
We have fixed a softmax issue few weeks ago.
Could you test if this error still occurs on our latest TensorRT package? (should be v3.0.4)
https://developer.nvidia.com/nvidia-tensorrt-download
Hi AastaLLL,
The TensorRT that I’m using is v3.0.4.
We have checked this issue in detail today.
This is a known issue and is already fixed internally.
The fix will be included in our next TensorRT release.
Root cause is the incorrect handling of ‘Same’ padding option in conv2d op.
A simple reproduce source is:
inputs = tf.placeholder(dtype=tf.float32, shape=[1,225,300,3])
output = tf.layers.conv2d(inputs=inputs, filters=32, kernel_size=[3, 3], strides=[2, 2], padding='SAME')
output = tf.nn.relu(output,name='output')
TensorFlow output is (113, 150, 32)
TensorRT output is (112, 150, 32). ---------> incorrect
Checking your use case with following log, we confirm that you are facing the same issue as above:
output_name = 'Disc/out'
def D(x, is_training = False, reuse = False):
        lrelu4 = tf.maximum(0.2 * conv4, conv4, name='out')
        return lrelu4
inputs = tf.placeholder(dtype=tf.float32, shape=[1, num_channels, x_height, x_width])
output = D(inputs)
uff_model = uff.from_tensorflow(tf_model, [output_name])
engine = trt.utils.uff_to_trt_engine(G_LOGGER, uff_model, parser, MAX_BATCHSIZE, MAX_WORKSPACE)
print 'TensorFlow tensor dimension:'
print output
print 'TensorRT tensor dimension:'
print '(C,H,W)=(%d,%d,%d)' % (engine.get_binding_dimensions(1).to_DimsCHW().C(), engine.get_binding_dimensions(1).to_DimsCHW().H(), engine.get_binding_dimensions(1).to_DimsCHW().W())
Tensor(“Disc/out:0”, shape=(1, 256, 3, 16), dtype=float32)
(C,H,W)=(256,2,16) ---------------------------------------------> incorrect
Please wait for our next release for the fix of this issue.
Bye the way, we also use GAN with RNN model for chat-bot use case here:
https://github.com/NVIDIA-Jetson/JEP_ChatBot
Hi AstaLLL,
Thanks for your detailed feedback. Glad that it’s a known bug and that next release won’t have this issue!
May I ask when is your next release (roughly)?! Is it going to be during the ICML conference?!
Also, thanks for the GAN link. I’ll have a look at it… :)
Sorry that we cannot disclosure our schedule and plan here.
Please pay attention to our announcement and update for the latest information.
Hi AastaLLL,
Thanks. I heard about the announcement at GTC18. I’ll give it a go next week!
In general, would be good if you could provide some timeline. I think us and many others are at the evaluation phase at this stage. Knowing when (roughly) could help us with our planning/production phase as well… :)
Thanks for sharing your situation with us.
We have passed your request to our internal team to check what we can share.
Thanks AastaLL, appreciate. :-)
