I am trying to convert the embedding from pyannote3.0 to TensorRT.
Environment
TensorRT Version: Docker → nvcr.io/nvidia/tensorrt:23.01-py3
GPU Type: A30
Nvidia Driver Version: 535.86.10
CUDA Version: 12.2
Explication
1) Load Model and Convert Model into tensorRT
The model “hbredin/wespeaker-voxceleb-resnet34-LM” is in ONNX format.
onnx_model_path= hf_hub_download(
repo_id= "hbredin/wespeaker-voxceleb-resnet34-LM",
filename="speaker-embedding.onnx",
trt_engine_path = onnx_model_path.replace('.onnx', '.trt')
command = ["trtexec", f"--onnx={onnx_model_path}", f"--saveEngine={trt_engine_path}", "--explicitBatch"]
process = subprocess.run(command, stdout=subprocess.PIPE, stderr=subprocess.PIPE, text=True)
2) Load data
waves = torch.load("data_waveforms.pt")
x = test.prepare_input(waves)
x.shape, x.nbytes
((1, 998, 80), 319360)
x is my input. I made an inference with the model to see the size of the output and to get an idea of my embedding.
embeddings = model.run(output_names=["embs"], input_feed={"feats": x})[0]
embeddings.shape, embeddings.nbytes
((1, 256), 1024)
x_shape = (1, 998, 80)
output_shape = (1, 256)
batch_size = 1
d_input = cuda.mem_alloc(batch_size * x.nbytes)
d_output = cuda.mem_alloc(batch_size * output_shape[1] * 4) # 4 bytes pour chaque float32
bindings = [int(d_input), int(d_output)]
cuda.memcpy_htod(d_input, x.ravel())
test.context.execute_v2(bindings)
output_data = np.empty(output_shape, dtype=np.float32)
cuda.memcpy_dtoh(output_data, d_output)
output_data
array([[nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan,
nan, nan, nan, nan, nan, nan, …]]
Does anyone have an idea about the problem?
