• Hardware Platform: Jetson orin nano
• DeepStream Version: 7.1
• JetPack Version 6.2.1
• TensorRT Version: 10.3.0.30
• NVIDIA GPU Driver Version: 540.4.0
Hi
I’m running a DeepStream application inside the official deepstream-l4t:7.1-triton-multiarch container on a Jetson
Orin device. The issue is that the TensorRT version inside the container (10.3.0.26) differs from the host system
(10.3.0.30).
This causes my YOLOv8 models to regenerate .engine files every time the container starts, because TensorRT engine files are version-specific and not compatible between 10.3.0.26 and 10.3.0.30.
Docker Image: nvcr.io/nvidia/deepstream-l4t:7.1-triton-multiarch
And also i am getting this when i run container:
== Triton Inference Server ==
NVIDIA Release 24.08 (build 107631426)
Triton Server Version 2.49.0
Copyright (c) 2018-2024, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
Various files include modifications (c) NVIDIA CORPORATION & AFFILIATES. All rights reserved.
This container image and its contents are governed by the NVIDIA Deep Learning Container License.
By pulling and using the container, you accept the terms and conditions of this license:
https://developer.nvidia.com/ngc/nvidia-deep-learning-container-license
ERROR: This container was built for NVIDIA Driver Release 560.28 or later, but
version 540.4.0 was detected and compatibility mode is UNAVAILABLE.
/bin/bash: line 1: lsmod: command not found
/bin/bash: line 1: modprobe: command not found
(gst-plugin-scanner:137): GStreamer-WARNING **: 03:10:16.835: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstmpeg2enc.so': libmjpegutils-2.1.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:137): GStreamer-WARNING **: 03:10:16.845: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstvoaacenc.so': libvo-aacenc.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:137): GStreamer-WARNING **: 03:10:16.916: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstfluidsynthmidi.so': libFLAC.so.8: cannot open shared object file: No such file or directory
(gst-plugin-scanner:137): GStreamer-WARNING **: 03:10:16.971: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlibav.so': libmp3lame.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:137): GStreamer-WARNING **: 03:10:17.031: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstlame.so': libmp3lame.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:137): GStreamer-WARNING **: 03:10:17.047: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstsndfile.so': libFLAC.so.8: cannot open shared object file: No such file or directory
(gst-plugin-scanner:137): GStreamer-WARNING **: 03:10:17.048: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstopenh264.so': libopenh264.so.6: cannot open shared object file: No such file or directory
(gst-plugin-scanner:137): GStreamer-WARNING **: 03:10:17.127: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstchromaprint.so': libmp3lame.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:137): GStreamer-WARNING **: 03:10:17.146: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstmplex.so': libmjpegutils-2.1.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:137): GStreamer-WARNING **: 03:10:17.157: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstpulseaudio.so': libFLAC.so.8: cannot open shared object file: No such file or directory
(gst-plugin-scanner:137): GStreamer-WARNING **: 03:10:17.163: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstfaad.so': libfaad.so.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:137): GStreamer-WARNING **: 03:10:17.167: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstflac.so': libFLAC.so.8: cannot open shared object file: No such file or directory
(gst-plugin-scanner:137): GStreamer-WARNING **: 03:10:17.504: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:137): GStreamer-WARNING **: 03:10:17.523: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
Questions
- Is there an updated deepstream-l4t:7.1 image with TensorRT 10.3.0.30?
- Can I safely upgrade TensorRT inside the container to match the host version, or will this break DeepStream compatibility?
- How can i fix driver version mismatch and plugin load issue
