Using onnx=1.6.0 i can generate the .onnx file successfuly. And I can export the engine using tnesorrt=6.0 , However when change the tensorrt to 7, the trt.OnnxParser not work, the network.num_layers is zeros.
SunilJB
2
Similar to below Dev talk topic:
https://devtalk.nvidia.com/default/topic/1068661/tensorrt/tensorrt7-parse-error
Related topics
| Tensorrt7 parse error | 4 | 1310 | December 20, 2019 | |
| Recurrent convolution | 8 | 1337 | January 17, 2020 | |
| TensoRT ONNX parser | 2 | 918 | April 24, 2020 | |
| TensorRT's OnnxParser problem | 5 | 2595 | December 7, 2020 | |
| Trtexec from tensorRT 6.5.0.7 fails to parse onnx file; but trtexec from tensorRT 7.2 succeeds | 4 | 1488 | November 4, 2021 | |
| Error while parseing pre-trained Onnx model with Tensorrt on jetson nano | 2 | 1079 | October 30, 2019 | |
| tensorrt's onnx parser can't parse the output layer correctly | 12 | 5147 | November 24, 2021 | |
| Failing to parse onnx file generated by pytorch | 4 | 5389 | June 19, 2019 | |
| tensorrt 6.0.1.5 torch1.3 onnx, build engine from onnx file fail, Network must have at least one out... | 1 | 859 | November 15, 2019 | |
| ONNX to TensorRT does not load final layer. | 3 | 1558 | January 15, 2019 |
