Tesla K80 overheating
We are running an app on a K80 that for the first 2-3 minutes does just fine - but the temperature of one of the GPUs goes up steadily to 90C after 3 minutes and the clock speeds then throttle to between a third to an eighth of what they were. There is only a passive heat sink. Has anyone else overcome this hurdle?
TIA.
$ nvidia-smi
| NVIDIA-SMI 340.32 Driver Version: 340.32 |
| 0 Tesla K80 Off | 0000:05:00.0 Off | 0 |
| N/A 91C P0 110W / 149W | 940MiB / 11519MiB | 98% Default |
| 1 Tesla K80 Off | 0000:06:00.0 Off | 0 |
| N/A 63C P0 120W / 149W | 940MiB / 11519MiB | 64% Default |
this is how it looks in normal operation before throttling induces overruns:
| N/A   75C    P0   118W / 149W |    793MiB / 11519MiB |     76%      Default |
| N/A   55C    P0   128W / 149W |    793MiB / 11519MiB |     73%      Default |
Are you running it inside a certified server configuration?
Please read this thread and the links in them:
https://devtalk.nvidia.com/default/topic/830470/?comment=4522937
We have an iHawk GPU Workbench CUDA server built up [including the K80] by Concurrent Computer Corp and we are doing only CUDA, not graphics on the K80.
One of the links mentions:
So “certified” by who?
Maybe I picked the wrong word. As you saw the first question when K80 server boards are involved on this developer forum is always if the server system was built to support the passive cooling solution, the required monitoring, BIOS, etc.
If you bought a full server system configuration from one vendor and the machine is not behaving like expected, then you should contact the system vendor first to determine if there isn’t any defect involved.
I have an ‘encorr. ecc’ problem on my K80 that is preventing its use:
root@x:~# nvidia-smi
Sun Feb 12 11:00:53 2017
| NVIDIA-SMI 367.57                 Driver Version: 367.57                    |
|   0  Tesla K80           Off  | 0000:83:00.0     Off |                    0 |
| N/A   66C    P0   105W / 149W |  10819MiB / 11439MiB |     94%      Default |
|   1  Tesla K80           Off  | 0000:84:00.0     Off |                    0 |
| N/A   53C    P0   145W / 149W |  10819MiB / 11439MiB |     85%      Default |
|   2  Tesla K80           Off  | 0000:87:00.0     Off |                    2 |
| N/A   43C    P8    29W / 149W |      2MiB / 11439MiB |      0%      Default |
|   3  Tesla K80           Off  | 0000:88:00.0     Off |                    0 |
| N/A   54C    P0   151W / 149W |  10819MiB / 11439MiB |     93%      Default |
| Processes:                                                       GPU Memory |
|  GPU       PID  Type  Process name                               Usage      |
|    0     14252    C   python solve_jr.py 0                         10815MiB |
|    1      9625    C   python solve_jr.py 1                         10815MiB |
|    3     15555    C   python solve_jr.py 3                         10815MiB |
Apparently some sort of errror has occurred on gpu #2, should i turn off ecc , reboot the machine, or what?
