Are the GM204GL (Tesla M60) and NVidiaTesla M60 different boards, that require different drivers? I have both in our VMWare environments, and both were working in v6.0 with the same driver, but only the NVidiaTesla M60 boards are working since we upgraded to ESXi 6.5
not sure what you mean. We only have 1 Tesla product line. GM204 is the chip on the M60. So what should be the difference between the boards you mention? And we only have 1 driver so it needs to work for all M60 boards.
Regards
Simon
I understand the only current issue might be with ESXi 6.7, but as stated above, this should all work find and the same, uniform way under 6.5.
