Tesnor in Jetson Orin nano
Hello Nvidia Team,
I am working on an onboard AI project using a Jetson Orin device, and I am facing issues with PyTorch GPU detection and TensorRT model export.
System Information:
  • Device: NVIDIA Jetson Orin
  • JetPack Version: 6.2.2
  • OS: Ubuntu (JetPack default)
  • Python Version: 3.10
Project Context:
I developed a YOLO-based pipeline (classification + segmentation) for oil spill detection. I am trying to optimize inference using TensorRT and FP16 to utilize Tensor Cores.
Issue Description:
  1. PyTorch CUDA Not Detected:
  • After installing PyTorch using pip (including cu121 and NVIDIA index methods), CUDA is not detected.
Command:
python3 -c “import torch; print(torch.cuda.is_available())”
Output:
False
  1. TensorRT Export Fails:
  • When running:
    yolo export model=… format=engine half=True
I receive:
ValueError: Invalid CUDA ‘device=0’ requested
torch.cuda.is_available(): False
  1. NumPy Conflict (resolved partially):
  • Initially had NumPy 2.x incompatibility
  • Downgraded to numpy 1.26.x
  1. Installation Issues:
  • Standard pip torch installs CPU-only version
  • Attempted NVIDIA wheel installation, but some links returned 404 errors
  • Using virtual environment to avoid system conflicts
What I Need Help With:
  • Correct PyTorch installation method for JetPack 6.2.2 (with CUDA support)
  • Verified compatible versions of:
    • PyTorch
    • Torchvision
    • CUDA
  • Steps to ensure torch.cuda.is_available() returns True
  • Guidance for enabling TensorRT export on this setup
Additional Notes:
  • GPU is physically present and Jetson system is functioning normally
  • Issue seems specific to PyTorch/CUDA environment setup
I would appreciate detailed guidance or official installation instructions for this configuration.
Thank you.
Hello @hiii
You can check the Ultralytics guide for PyTorch installation on Jetson
Please find the comment below for installing PyTorch on JetPack 6.2:
